Question about TCL LE32HDF3300 32 Inch LED LCD HDTV
You turn the tv on and then turns straight off its lcd tv
Hi i have a 42" lcd hannspree tv HSG1102. The
maybe the inventor board,also check no wires are loose at the joint to the backlight.
Mar 24, 2013 | Televison & Video
Tv won't power up straight away
when lcd tv`s fail to power up, but stay on standby. It is usually because of bad capacitors on the power board. My 22" lcd monitor did the same. It would not come off of standby. It starts with them being slow to turn on. "Sound familiar"? I fixed mine by changing the bad caps. There were two of them.
Jan 31, 2013 | Wharfedale LP160DTRHDMI
Easy touch 42inch lcd tv black screen
replace power supply and mainboard
Jan 21, 2013 | Televison & Video
Can't turn off the closed captioning
I had the same problem. Okay, First get the TV remote. not a cable box remote. Next, switch the input to an Analog input. (TV or input one if you have the RC red, white and yellow hook up. or, just hook up the coax cable straight to the TV..
Now, use the TV remote to operate the closed caption. It will work like it should.\
Briefly, closed caption works on the TV with a straight hook up to the TV. It will not work with a cable box.
Good LUCk
Monty
Aug 21, 2011 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
I just bought a new 40 in. philips LCD television. I plugged the power cord into the tv then into the wall outlet. the tv will not turn on or make any sounds when trying to turn it on with remote and...
Hello, make sure power cord is pushed in all the way in to the tv. Also make sure you have power at your outlet. I know it sounds dumb, but I've seen people chase their tail for hours before coming to the conclusion that a circuit breaker was tripped. Make sure you have good batteries in the remote. If the TV has a power button on the tv, try turning it on there instead of the remote. You can check to see if there is an on/off switch in the back. Besides this it should be pretty straight forward. You might have a defective tv
Hope this helps
Thank you in advance for your feedback
Mar 04, 2011 | Philips 19PFL3403D/27 19 in. LCD TV
Turn LCD tv on but picture does not come on straight away - it's as though it needs to warm up - after turning on and off several times for about 5 minutes the picture comes on
it is possible that the ballas on your tv is week and not sending enough power to turn your tv set on, you may need to replace it if this is the problem, i can recoment to pay attention to any strange mechanical noises on you tv, like buzzing or clicking sounds if so you may need to replace it, I can recomend a page called discount-merchant.com for your parts
Dec 17, 2009 | Televison & Video
HDMI conneection wont override tv picture
I am a sky engineer (not a subby)
the reason this does not come on straight away is because a Scart lead send power upto your telly when it is turned on. Telling the telly that this is what you want.
Unfortunately HDMI does not send power upto the telly. There are ways around this. ON Samsung, Panasonic and Lg tellys you can go into a secret menu and apply something called HOTEL MODE this allows you to change the av input so it would automatically come on your hdmi 1,2,3, etc
In your case follow my instructions below
go to the hdmi you are using for your Hd
on the sky remote
Press SELECT and GREEN until LED flashes twice.
Press HELP then SELECT and the LED will flash Twice. what this mean is when you press your Sky button, tv guide, services or interactive button to turn the sky on this will automatically change your av/source on your telly to the sky HD for you
You owe me a pint
Have a good one
Little Dish Fitter
Jul 19, 2009 | Microsoft Xbox 360 Console
Tv won't turn on
you might want to hook it straight to the wall plus the surger may be fried even though it turns on it may of messed your tv up so i would try that if not then get back with me and i'll try to help more
Jun 07, 2009 | Toshiba REGZA 47WLG66 47 in. HD-Ready LCD...
TCL LE32HDF3300 32 Inch LED LCD HDTV Logo
19 people viewed this question
Top TCL Televison & Video Experts
MegaByteMe
MegaByteMe
Back2life...
Are you a TCL Televison and Video Expert? Answer questions, earn points and help others
