Question about Home
Leak from the flush control valve ecoflush part b8100-04
3 Suggested Answers
  • 659 Answers
SOURCE: Champion4 leaks water through flush valve
You have replaced the flush valve completely? If so and the unit is still leaking, you may have a small crack in the tank or your just not getting the tank to bowl fittings tight enough. Also, they make two different thicknesses in the tank to bowl gasket. Make sure you are using the thicker of the two. You posted this under the American Std. thread, so if this is correct, give them a call. There could be a recall on this particular toilet due to a flaw.
Posted on Apr 08, 2009
kachbibi1
  • 979 Answers
SOURCE: everytime we flush the ecoflush toilet, the water came out from the handle
Have you fixed it yet.
Posted on Feb 27, 2013
Ecoflush Model B8104 toilet leaks from handle when flushing.
The manual and troubleshooting information is here. This is a plumbing feature I have never come across before.
https://wdiecoflush.files.wordpress.com/2013/05/b8104-service-manual.pdf
Amazon will sell you a replacement module;
http://www.amazon.com/EcoFlush-B8104-Pressure-Assisted-Control/dp/B00FHB8CAM
Jan 06, 2013 | Home
Flush Valve leaking
replace the whole valve. It's cheap and easy to do. Probably you can install a universal valve. Look on e-bay or amozon
Dec 05, 2012 | Toto Aquia II Dual Flush Toilet
I have a EcoFlush B8100 and it does not want to flush even if i turn the knobs.
First check the filter in the supply line ( this is where the hose from your house hooks into the tank ( inside the tube( tank side) (youll need needle nose pliers) pull out screen and flush screen with water. if that doesn't work ....change the flush cartrage with a B8106 replacment( its the thing in the middle under the tank lid that has hoses comeing out). You have a ecoflush system that is covered for 10 years from the manufactorer. call 1-800391-9821...I have 301 of these in a hotel and im the chief engineer.. good luck... there easy to change
Jan 02, 2012 | Coffee Makers & Espresso Machines
Replaced the seals because it was running. Water is still leaking from the tank somewhere so it keeps refilling....it's constantly leaking and refilling. how can I repair this.
You say you have replaced seals. I assume that you are refering to the flaper valve that controls dumping water from tank to bowl to flush. To make sure you have a good seal put a dozen or so drops of food coloring directly into tank when it's full and observe for a hour or so to see if water in bowl is discoloring. If it is then you are still leaking there. You can shut off water supply off or flush toilet and manually hold flush valve closed. Check to see if there are any rough spots on flapper seal that could stop flapper from sealing good. If you find rough spot then make sure the surface is dry and sand lightly with medium grit sandpaper.120 grit or finer.
One other thing to check is if your toilet has the plastic or rubber tube that goes from the flush valve into the overflow. Make sure that this tube does not set below water level in tank when it is full as this can create a suction or syphon,
Hope this helps you. Thanks
Jan 10, 2011 | American Standard Home
Igenium Flushing valve will not shut off.
THE WHITE PIECE IS LOCKED IN YOU MUST PUSH DOWN AND TURN A HALF OF TURN .THEN LIFT IT OUT,DON'T DAMAGE YOUR O RING
Apr 05, 2010 | Kohler K-3422 - Wellworth Elongated...
1997grand voyager is blowing cold air new thermostate water pump and the raditor and heater core has been back flushed it started blowing hot air again then went back to blowing cold air again
I would look for a vacum leak on the control valve for the heater. There are 2 lines from the radiator leading back to the firewall. One has a control valve on it that should be vacum controlled. When you back flushed to the heater core you may have forced this valve open temporarily. The control may have low vacum or insufficient vacum to open a stuck valve. The good news is you can actually manually open this valve and tie it in the open position which will at least temporarily solve the problem. Check your vacum lines for leaks and check the valve to make sure it isn't sticking.
Jan 21, 2010 | 1999 Plymouth Grand Voyager
Water level in bowl too hogh
Try bendig the float rod down so th resivor dont fill so much
Oct 19, 2009 | Elements Of Design EVWC320 EcoFlush Close...
Apr 04, 2009 | American Standard AMERICAN STD 12 RGH...
Home Logo
252 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
