Question about Tascam CD-302 Version 4.0 Dual Deck CD Player
302 cd dual instructions player tascam 9109030600
Where can I buy a Tascam cd 302 remote cable with part number 9109030600
  • 3422 Answers
SOURCE: Tascam CD A500 'No Disc' error message
The first thing i would suggest you to do is a hard reset by unpluging the the player for 30min and then try again.
If this does not solve your problem then please see if the player tries to read the disc.
Load a disc and listen.Does the player make squealing noises or is it totally quiet? Squealing noises may indicate that the player is trying to synchronize with the disc but can't due to an obstruction on the lens or in the laser path inside the pickup or a defect in the pickup. This can also be caused by an intermittent signal problem due to a faulty ribbon cable.
Totally silent means that the photo sensor is not getting any usable input from the laser at all, meaning that the pickup is "blind" for lack of a better word.
This can be caused by an obstruction of the beam by foreign matter on the lens or inside the pickup all the way to a marginal or failed laser diode and/or photosensor array. This can also be caused by a bad ribbon cable with one or more severed traces.
You could try to clean the optics. This is the most common malfunction as far as i know in all disc players. It would involve taking the cover off and finding a way to expose the lense, and then cleaning it with a very gentle brush. some players have a cover for the lense that swings to the side during playing, this greatly reduces the chance of dust accumulating, but its still worth the try.
If you actually see dust on the lense, then its just that simple. clean, close, play.
It may also be worth your while to check on the small shafting that guides the carriage of the laser pickup. Dirt, grome, dust and solidified lubricant can cause stoppage of the carriage and the laser eye then fails to read the next track.
If the problem does not get solved then you have to get it repaired.
Goodluck..
Please don't forget to rate the solution.
Posted on May 01, 2008
  • 3 Answers
SOURCE: what cables for yamaha keyboard psr295 to connect with tascam 144
There are different options depending on what you want to achieve. If you want to send only MIDI data to your PC (for example, to run a VST instrument), then you can use a standard MIDI cable to connect the "out" on your keyboard to the "in" on your Tascam. You should also be able to use the Yamaha USB cable to connect directly to your computer, which would then bypass the Tascam (still giving you the same outcome, but without the need to buy any extra cables.
However, if you want to send the audio data (i.e. the actual sound) of the keyboard to your PC, you would simply use a standard guitar lead from the line out of the keyboard into the line in (both, if your keyboard has stereo outs) of your Tascam. This will eliminate any need for VST instruments, as you will be recording the audio signal directly.
Posted on Sep 10, 2008
SOURCE: Tascam CD-A500 'no disk' problem
How hard is it to replace optical lens on the Tascam CD-A500?
Posted on Oct 14, 2008
  • 189 Answers
SOURCE: tascam 788
The 788 can be used to play music from a SCSI attached CD-RW drive, but the record (and all other mixing functions) are disabled so you are not able to record the CD output onto a track using the SCSI attached drive.
Your options are:
1.) Rip tracks files from the CD onto you PC as wav files. You'll have rip (or later convert) those files to mono 16 or 24 bit wav files at 44.1kHz, use the old dos 8.3 naming convention for the filenames, and them burn them onto a CD-R or CD-RW as data files which can then be taken and imported into the 788.
2.) Play the CD through with an external CD player or stereo and route the output into an input on the 788. Assign the input to a track and record. Be careful to use a line level output, like an aux out (or try the CD player's outputs directly into the 788) if you are using a stereo. Avoid using a speaker output as the signal from a speaker output will be too strong and can damage the 788.
Hope this helps.
Cheers.
bd.
Posted on Oct 23, 2008
  • 189 Answers
SOURCE: Tascam DP-02 cd player...
You cannot rip a CD directly into the DP-02 using the unit's CD drive.
Your choices for doing what you want are:
1.) Rip the CD into .wav files onto your PC using ripper of your choice. Then you'll have to edit the resulting .wav file using a program like 'Audacity' (which is a free one) and convert the stereo wav files into 2 mono wav files. You'll have to save the mono files with dos 8.3 filenames and then import them into the DP02 using the instructions for importing wav files in the manual. To preserve the stereo, import each mono wav file to a separate adjacent track on the DP02 and then pan one left and one right.
2.) You could play the CD on a stereo and connect the stereo outs to the two inputs on the DP02 to record the CD track. You'll need patch cords which are RCA (mini phono 1/8" jack) to regular phono (1/4") to do this.
Cheers,
bd.
Posted on Nov 10, 2008
Where can I purchase a replacement cue button switch in the UK?
You would have to get a repair shop, Order one for you ,Or get them to repair it for you. Have you tried to contact, Customer support if the company has it?
Nov 07, 2012 | Tascam CD-302 Version 4.0 Dual Deck CD...
My tascam cd-1500 dj left side only display good day while the right side is fine
how can i b deck going on my tascam x1700 from gd day when i got deck a working i cant remmber what i pressed can any one help
Aug 25, 2011 | Tascam Cdx1500 Dual CD Player CD Player
The left hand deck has difficulty playing CDR discs.
the lens wants to be clean.if that does not correct the problem.the lens needs to be replace.good luck.
Feb 28, 2010 | Tascam CD-302 Version 4.0 Dual Deck CD...
Need cords
8-pin mini din cables p/n: 9109030600, you can buy them from any authorized TASCAM/TEAC dealer.
Jan 11, 2010 | Tascam CD-302 Version 4.0 Dual Deck CD...
How can I find this optical laser ?? , please
hello somebody help found this optical laser for TASCAM CD-RW 750 . who can i find , what is the number ??? thanks
Jul 15, 2009 | Tascam CD-RW750 CD Recorder
Cd rewritable player recorder tascam cdrw4u
I never had that problems. I have been using it over five years. Does it play commercially made CDs (the ones you bought at the store)? Panel shows track numbers and sound volume? Can you hear it by using a head set (phone volume control turned up? If so, now recording part, do you have input select correct (analog or digital)? Input cable(s) into right connector(s)? When you press "record" button, does it put into "pause" mode? Can you watch the incoming sound levels when it is on "pause" mode? Can you start the recording with remote's fader button or play/pause button on the machine? Good luck.
Jun 09, 2008 | Tascam CD-RW4U CD Recorder
Tascam cd-rw 750
The manufacturer has manuals on their web site. This is where I got mine here: http://www.tascam.com/details;9,18,26,19.html
Dec 04, 2007 | Tascam CD-RW750 CD Recorder
Tascam CD-302 Version 4.0 Dual Deck CD Player Logo
Top Tascam Audio Players & Recorders Experts
Sam Palermo
Sam Palermo
Michial Gueffroy
 Grubhead
Grubhead
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
