Question about Olivetti Office Equipment & Supplies
Printer hangs network - Olivetti Office Equipment & Supplies
How to cancel print task hangs on printer from many users
go control panel ,click on-devices and printers , right click on default printer
that will show the list of tasks for the printer
highlight the non required tasks and end task
or highlight each line at a time and end task the lot
Nov 19, 2015 | Office Equipment & Supplies
T644 Default Paper Source Problem
On the left side, near the pichup roller, of the tray there should be a "flag" hanging down in the elips hole. See if it is hanging down or stuck in the "up"position.
If so pul it down and the machine should work fine again.
Jun 26, 2013 | Lexmark T644 Laser Printer
On my home wireless network, my notebook computer's print jobs go to the correct printer but won't stop printing until it is canceled from the device manager. The PC that is on the network wor
sounds like the print job queue is overloading the wireless network, causing a hang on that side
big print jobs do that even on wired systems might consider adding more printer memory
May 26, 2012 | HP P2035n Laserjet Printer Monochrome
Why printer 4515 this error MANUALLY FEED OUTPUT STACK for duplex pritnting
HP P4515n is not a duplex printer by default. It is a network printer. ('n' suggests it is a network printer. Duplex printers have 'd' in the model number).
If you want to print both sides, manually feed sheet by sheet. Or else you can do the following:
If you are using, say MS Word, print only the odd pages (Print the normal way. No need to manually feed paper). Then arrange the printed papers in the proper order and keep the printed side as back side. Insert the set of papers in the printer and print only the even pages.
First print a document of about 6 pages to get the hang of it.
May 12, 2011 | HP P4515n LaserJet Printer
Suddenly our company have customers who can no longer print to HP networked printers (NDPS queue based). Their neighbor can print to a printer, but they cannot print to the same printer - cannot print test...
Hi, Apart from the print drivers setup, there is the print server which usually hangs due to overflow for requests.The priority of the print plays a major role here as the highest priority print occupies the first place, and thereby prolongs the successive prints and due to the volume of the network it hangs. Solution: Restart the print server and delete the prints in the queue Restart the printer as well and check the spool process
Hope this helps
Nov 04, 2009 | Microsoft Windows 2000 Professional for PC
Laserjet p3005n hangs at boot
Hold down the green button while turning the machine on for a cold reset.
If it has a network card, remove it and try again.
Jun 16, 2009 | HP LaserJet P3005n Printer
Itunes stops
This could be a lot of things, but I would wager it is the result of network traffic congestion, if this is truly being used for a WiFi network... First thing to troubleshoot this would be to take the WiFI out of the mix and just use a hardwired solution to see if it still hangs.. if so, then the problem may be drivers for your system, and you may need to upgrade them..
May even be software.. might try seeing if any newer versions of your player are available.
Dec 11, 2007 | Computers & Internet
Data Light comes on - boots up but stays on wait - please help!
Network printing was optional. The network connection is misleading; it is there for scanning. You may have to use it as a local printer and share it.
Dec 08, 2007 | Canon imageRUNNER 3300 All-In-One Laser...
Sharing the printer over network
Can you print from the print server? If so that eliminates the drives. Are you sure permissions are correct?
Oct 30, 2007 | Lexmark T642 Laser Printer
Dell 1710n printers hang
Try using the Lexmark Print Server instead of the generic print server (if you use a Windows Server to share the printers). Also a new driver V2.0 was just released. Additionaly you can try to set 100 full duplex, but this is complex and has to be done at the printer, pressing a serie of buttons. These printers are crap, we have constant problems with them.
Mar 27, 2007 | Dell 1710n Laser Printer
18 people viewed this question
Top Olivetti Office Equipment & Supplies Experts
James Cagle
James Cagle
Jim Keysor
Are you an Olivetti Office Equipment and Supply Expert? Answer questions, earn points and help others
