Question about Vehicle Parts & Accessories
Compustar rf 2w4500fmr
How can I program it to start car when temp drops below -20c
2 Suggested Answers
  • 64 Answers
SOURCE: 2010 5.7L Dodge Ram sport 1500 4x4 crew cab may or may not start when the temp drops below -20c. Had to have the TIPM changed once already. The problem that time was that when the key was turned there
you got electric problem most likely ground or the remote start will cause that
Posted on Jan 04, 2015
2004xtype 2.5. When car is started ext temp is shown as 20c.After driving for10 mins it rises to40c plus,
the external temp sensor has failed common problem its located behind lower front bumper vent rhs looking from front of car easy to fit remove from connector and fit new one
Mar 07, 2017 | 2004 Jaguar X-Type
I have a 2013 Honda Accord with push start and ever time i unlock the car and open the door after it is remote started it shuts off. Is there a fix for this?
Yes, you must have the remote start reprogrammed, probably can only be done at dealership if factory or by the installer if aftermarket.
Jan 22, 2016 | Honda Cars & Trucks
How do I reprogram my key bob
Remote Programming Troubleshooting Guide - Compustar
https://support.compustar.com/.../202839770-Remote-Programming-Tro...
How do I add/remove a DroneMobile unit from my account? ... (Do not start the engine, simply move the key to the final position before start); Immediately following the key ... Holding the button down will cause the remote programming to fail.
How do I program a remote to a Compustar system ...
https://support.compustar.com/.../202232840-How-do-I-program-a-rem...
How do I add/remove a DroneMobile unit from my account? ... Insert your vehicle keyinto the ignition and cycle the key to the 'ON' position and back ... Valet mode will be activated if the system does not identify a remote during programming.
Programing a Compustar 1Way 4 Button Remote - YouTube
Jan 12, 2016 | Vehicle Remote Starter and Security Kit
I have a compustar from-2w9000-ss remote and a button was pressed,locked me out ,what buttons do I press to get it to work again
PRIME 9000 1-Mile Range, 2-Way Select - Compustar
www.compustar.com/product/prime-9000/
Compustar1-Mile Range, 2-Way Model: RF-2W9000-SS ... The classic Compustar look that made us the top remote start brand in North America. ... The screen keeps you updated on whether your doors are locked and in the event of an alarm trigger, the ...
Compustar RF-2W9000-SS remote kit failure? - 8th Generation Honda ...
www.8thcivic.com > ... > ICE, Electrical, Security, & Navigation
Jan 8, 2015 - 4 posts
I have had my Compustar RF-2W9000-SS remote kit and secondary remote ... on my 2008 Honda Civic SI Coupe, FG2, at a compustar authorized dealer. ... my remote was not responding to my car (the unlock/lock, autostart, ...
CompuSTAR Starters - TheCarSalon.com
www.thecarsalon.com/home/automotive/remote-starters/compustar/
Either tap buttons I and III or Lock and Trunk simultaneously on your remote. ... The introduction of the RF-2W9000-SS in 2010 ushered in a new generation of .
RF-2W9000-SS by Compustar from Remotely Started MN
remotelystartedmn.com/product-details.php?product-id=40
Jan 07, 2016 | Cars & Trucks
Cold weather battery drain
Cold temperature is discharging power from battery. There must be a temp differential between shop and outside. Regardless to where the battery is it should not discharge power that quickly you may need a new battery
Robert
Mar 04, 2015 | Cars & Trucks
Manual transmission won't remote start even though Ive followed all the steps to leave it in reservation mode and car remains running until Ive exited and closed driver door. Error code is Sta
If your getting 7 flashes from a Compustar brain there is something not working right with the manual reservation mode. Double check to make sure it is 7. If it is then go see an authorized Compustar dealer and have them go over the installation and programming of the unit.
Nov 07, 2014 | 2-way Remote Transmitter - Dark Navy/gray
We have a honeywell cm921 and we cant set the therm astat to come on in the mornijng and then go off then come on again in the afternoon on timer please can you help
Your CM921 has 6 built in temperature settings based on time of day:
1 - 6:30 AM
2 - 8:00 AM
3 - 12:00 PM
4 - 2:00 PM
5 - 4:00 PM
6 - 10:30 PM
meaning that at 6:30 AM the themostat will change its temperature setting to setting 1, at 8:00 AM it will change the temperature setting to setting 2, and so on. To schedule temperature settings which best fit you, determine which time periods you would like more or less heat.
For instance, to fit what you requested in your question you could program a temperature you would like to maintain in the morning and afternoon times when you would like it to be on, and in the time periods in between set a lower temperature as follows:
1 - 20C
2 - 16C
3 - 16C
4 - 20C
5 - 20C
6 - 16C
With this example your thermostat would turn on at 6:30 AM as long as the temperature was below 20C and maintain that temperature until 8:00 AM. At 8 it would change its setting to 16C allowing temperature to drop from 8 AM to 2 PM to a lower setting to conserve energy until afternoon time when the setting would change back to 20C from 2 PM to 10:30 and then change back to 16C to save energy throughout the night. The actual temperatures would be at your discretion based on your individual comfort level.
Pages 5 and 6 of the following link will guide you in setting each of the 6 temperature settings.
http://www.wolseleysbc.co.uk/_STEPData/Assets/Honeywell%20CM921%20Room%20Thermostat.pdf
I hope this helps. Let me know if you have any additional questions.
Dec 10, 2010 | Honeywell Programmable Thermostat Heater
Error C4 or CA
Turn off the heatpump. Start it again when temperature gets hotter than -20c.... Error C4 or CA (overheated compressor) often strikes after C2 error (and this error you often get when temp is belov -25c)
I had the same error myself, temperature was below -27. I turned the heatpump OFF. Turned it on again when temp was at -8c. No errors in display, and runs great! :-)
Jan 07, 2010 | LG Heating & Cooling
Vehicle Parts & Accessories Logo
32 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
