Question about Sony Handycam Video Cameras
Sony Handycam display screen flashing E:95:00 message
My Sony Handycam HDR-CX560 has a message flashing on its display screen. Message says E:95:00. The message will not appear at first, but after a minute or so, the flashing message always returns. Closing the screen and opening it up again makes the message disappear temporarily. The same thing happens if I power the Handycam on and off by using the POWER button. E:95:00 always appears after a minute in both scenarios.
5 Suggested Answers
  • 5 Answers
SOURCE: Blank screen
Hi: Check and see if there is an X as in escape out of the Menu Mode. If there is no X,then look fo OK. Good Luck. zeffy57.
Posted on May 29, 2007
  • 13 Answers
SOURCE: Error Message Reconect Power even if power is connected
It sounds like the tape door is out of alignment, causing stress on the tape and the inside mechanical system.  Requires a visit to the service shop.
Posted on Jan 28, 2008
SOURCE: Cannot turn off Auto Adjustment... message.
i has same problem and I have no idea how to disable. :(
Hope someone know how to help us out!
Posted on Mar 01, 2008
SOURCE: When I press the power button LG displaying chars for 1 second
Had the same problem, turned out it was due to a faulty capacitor on the inverter board, 680uF 25V (105 celsius rated). Simple to fix once you have the unit dismantled and the correct replacement part. Two screws hold the shroud on, but you need to be careful with an (old) credit card levering it off.
Unit is now working fine.
Posted on Oct 23, 2008
A video backup from Sony Handycam HDR XR520 to a PC running Windows 8.1 fails as soon as it is connected via the USB to the PC. Its back-up program displays a message "Unable to retrieve the manageme
Repar database file.this is a function inside the camera menu. If database is corrupt because of erased files,like photos or videos deleted from a pc, then at backing up is trying to locate lost files. Remeber. Repair data base files. Or "repair DBF" inside menu.
Oct 02, 2014 | Sony Handycam HDR-XR520 High Definition...
Video camera problems - Sony Video Camera problem
Error code 94:01 is an internal memory error. If you still get the error after reformatting the card or trying a different one, it's an electronic issue usually used by component failure and requires replacement of a circuit board within the camera.
Jul 12, 2014 | Cameras
After I formatted using windows explorer Hard drive of Sony handycam ( HDR-XR500VE) message HDD FORMAT ERROR POPPING UP. How to resolve, please?
You need to format camcorder hard drive through Format option in camcorder menu itself.
Please check camcorder menu and hard drive section for Format option, this will delete all files on hard drive and solve your problem.
Thanks.
Feb 20, 2011 | Sony Handycam HDR-SR1 HD Camcorder
Sony Handycam HDR-XR150 - Cannot access data in hard drive. Visible in windows as removable drive E but error message Please insert a disk into drive E: E:31.00 message blinking continuously. Please help....
hi i format my handycam hdr-xr150e(sony) hdd then i see e:31:00 then i insert memory stick and do wht you help(1- Place the memory stick 2- Go to "Home" -> "Manage Media" (or something like that) -> And select the option to change to the memory stick, instead of HD.) now i can record but in top of screen the e:31:00 not removed
Jan 19, 2011 | Sony Handycam HDR-XR520 High Definition...
I have the sony hdr sr11 handycam. The screen just stoped displaying the image. Thr camera is almost new. It has never been dropped. It you look at a certain angle it is possible to see a dimmed display,...
The most likely cause for this is a damaged or defective flexible ribbon cable that connects the LCD to the camera body and can be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to usually be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I
Sep 15, 2010 | Sony Handycam HDR-SR1 HD Camcorder
The lcd screen is almost black/ very dark, but i still see that it works. it looks like the light is out. sony hdr hc1
The LCD screen may be turned OFF. To turn the LCD backlight off or on, press and hold the DISPLAY/BATT INFO button for a few seconds. After the backlight has turned off or on, release the button.
Aug 07, 2009 | Sony Handycam HDR-HC1E HDV Digital...
Video Cameras Logo
855 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
