Question about Vehicle Parts & Accessories
I have a viper 4806v and I want to change how long the run time is but I don't know how. Any help?
2008 toyota tundra 5.7L Truck's electrical system drained drastically. I replaced the battery, and after one start, it went dead again with in 10 minutes. show very little light. on dash board. Voltage of...
is the alternator charging ok is the first thing to check when you've got the engine running if thats ok i'd disconnect the Viper remote as from your description it could be draining the battery/not working properly put back to original factory spec and run like that for a while then you'll know if its the Viper or not keep me updated
May 04, 2014 | Cars & Trucks
Cant get remote to chirp
Is the battery fully charged? Is the remote paired?
Jan 10, 2014 | Remote Start System
My viper alarm rpn 479v p x is not working. When i press the unlock or lock button it doesnt work it just beeps. The remote is also flashing rx. Whats wrong?
I got the Problem that my pager-function doen't work. I try it like the Manual saying (*-Button) but the two ways that gives doesn't work.
- Start the Programmmode while Pressing "P" on the Backside.
- Press the "STAR-Button or Panic-Button (Orange Key) on the Sender"
it Beeps 2 Times. (i try it again with 1 beep as reponse again)
i Wait 5 Seconds
it beeps 2 long times
i try the Responder, Activate the System, disarm the System. But the Pager don't change the state or receive any Signal.
The Transmitter is working perfect! No Problems to control the Viper 690XV.
What i do wrong?
Is there any hidden Feature or needable Programming in the Viper 690XV-Brain?
Thanks alot for any helpful Answer :)
May 02, 2012 | Directed Electronics 479V Remote Gen 2...
Viper remote start system just installed. When I use the remote to lock the car--there is no longer a chirp noise that confirms I hit the lock key. Thanks, Mary
I don't know which remote starter you have, but I have a Viper 5101. To fix this problem, I started the ignition, then turned it off, leaving the key in the ignition. I pushed the Valet button (it has a blinking blue light, mine is near my rear view mirror) and held it. Then, I pushed it 3 times, then held it down a 4th time. Then, I pressed the lock button once. I pushed the Valet button again to take it out of programming mode, and it worked! I got this sequence of steps from the installation manual online: http://www.scribd.com/doc/45065156/Installation-Viper-5101 Hope that helps!
May 12, 2011 | Remote Start System
Remote car starter worked last week but this week it won't start. Changed battery in the remote and still won't start. It will unlock and lock the doors but just won't start.
It probably needs to be re-programed
I have a viper model 5101 and this is how you program it Hope it helps !
Programming the Viper Remote Starter 5101
Unlock the doors before starting
Push and hold f button for 8-10 seconds until amber light is on solid
Push Remote start button for about 4 seconds till amber light flashes 3 times
Put key in IGN to the on position but don
Jan 05, 2011 | Remote Start System
I need instructions on how to use my viper 5101 remorte starter
go to www.directed.com this is the manufacturer of the viper remote starters, there you should be able to download instructions.
Here is how you program the viper 5101 remote.
Dec 30, 2010 | 5101 LE 1 Way Car Remote Starter System
I lost my viper remote starter, i already bought a replacement remote, but how do i progam it? I have the basic five button remote, black buttons and silver borders around the whole remote.
Dec 12, 2010 | 5101 LE 1 Way Car Remote Starter System
Back lighting for my viper 479v remote
you have to go in to the proramming mode of the remote to change this feature. you can access this by holding all 4 buttons on the remote at the same time. (or if you have the P button on the back you can hold it down by itself) you will hear 2 long beeps confirming the programming mode. at this time, you can change the settings by pressing 1 of the 4 buttons., each button will change a different function.
in no order------
1. Beep/vibrate or both
2. page or not to page
3.back light
4. hood, truck, or both
the remote will give 2 long beeps when it exits the programming
Aug 20, 2009 | Directed Electronics 479V Remote Gen 2...
Viper alarm keypad will beep for 30 seconds every time I arm or disarm
Change the battery, 2-way remotes require 2 slim batteries on top of one another. Regular remotes only require 1.
May 10, 2009 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Vehicle Parts & Accessories Logo
254 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
