Question about Remington Precision HC-8017 Hair Trimmer
Took apart and now will not cut - Remington Precision HC-8017 Hair Trimmer
18 v cut out tool got real noisy
The motor comes only as an assembly - it is an easy fix, but the cost of the part may not be worth it.
DeWALT DC550K Type 1 18V Cut Out Tool Parts
Feb 14, 2015 | Dewalt Bare-Tool DC550B 18-Volt Cordless...
Front differential subaru
Check for the axle of the side from where the cutting noise is coming. Axle is mainly responsible for the cutting noise. Or you can check for the camber angle of the tyres.
Nov 15, 2013 | Cars & Trucks
I have a Makita MAC2400, it stopped working, didn't realize where the reset button was, took apart the on off switch thinking there may be a fuse, the spring made it all fall apart as soon as I took the...
The pressure switch is assembled by automation and is basically impossible to put back together by hand. Even if you did manage to get it back together, the adjustment if critical. Easier to replace with generic pressure switch. Order from ebay for about $15. Just pay attention to port size and cut-out pressure. Select a switch that has on/off ,several ports on bottom and cut-out from 125 -135 psi. Factory switch is too expensive and really not any better. Good luck
Sep 04, 2013 | Makita MAC2400 Electric Powered Air...
I used the clippers to cut my dog... once finished I took it apart to clean out excess lubed parts and reassembled...I have done this many times before with no problems... I begin cutting and the blades...
Check your blade latch is working properly. If you took your clipper apart and your blades are not cutting it is one of 2 things. Your blade drive is not assembled properly or your blade latch is not holding the blade on the clipper. If you took your blade apart, check the blade alignment. The cutter blade needs to be slightly behind the comb blade.
Mar 11, 2011 | Andis AGC2 Hair Trimmer
I took it apart to clean, and now I barely cuts
Make sure the blades are even. It sometimes is hard to match when you take them apart. If they are even off a little bit they don't work. good luck
Oct 11, 2009 | Vidal Sassoon VSCL828 Hair Trimmer
Andis Ultra Edge Pet Clipper Assembly Help
I took my andis ceramic edge blade apart to clean. Now my clipper will no longer cut my dog's hair
Aug 13, 2009 | Andis Health & Beauty
Fan keeps cutting off after being taken apart and cleaned
If it was wired wrong it wouldn't run. I would suspect uneven tightening of the motor screws.
Aug 08, 2009 | Patton Electric U2-20 Box Fan
Receiver cuts on and off?
Check the Fuses I Have a sherwood stereo receiver it did the same thing took it apart changed the fuses works great
May 05, 2009 | Televison & Video
I took liners apart n now they will not work
You need to send it in to a Pro like Mannys Sharpening, I had the same problem, and they fix it and it was set to do line ups and Fades.
One thing I do recommend is tell them what kind of hair cuts your doing and they will hook U up. I found them in YahooLoval good rating.
here their phone # they have mail order service and they are fast. 323 263-4697
Jan 12, 2009 | Andis 04603 Hair Trimmer
Need help
Check Cig Plug Fuse and also Accessory fuse in your vehicle
Jul 22, 2008 | ESD-9215 Radar Detector
Remington Precision HC-8017 Hair Trimmer Logo
62 people viewed this question
Top Remington Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Jerry Greenberg
Jerry Greenberg
SHARCNET-USA
SHARCNET-USA
Are you a Remington Health and Beauty Expert? Answer questions, earn points and help others
