Question about Netgear, Inc NETGEAR NeoTV Streaming Player NTV300-100NAS
Connection timeout neotv will not connect to the wireless network it keeps saying connection time out
My acer laptop 7720-6569 wont connect to my wireless router it shows a padlock symbol
Try resetting the router and then type in your password on your browser.
Sep 09, 2014 | Computers & Internet
Netgear streaming player
Sounds as if it has found an open Wi-Fi connection, but the device it is connecting to doesn't have an internet connection.
Make sure the Netgear player is connecting to your wireless network, and that you have a live connection to the internet.
Aug 30, 2014 | NetGear NeoTV NTV300
Network timeout
Restart the computer first. Go ahead and try to connect again.
Jan 26, 2014 | Computers & Internet
Cant connect wireless due to timeout
To connectyour computer to a wireless router, you click the Refresh networklist, then Choose your wireless network and then click Connectto your secured Wireless Network, it will asks for a Network Keybefore allowing you to connect into your wireless network. This NetworkKey is either the WEP, or WPA or WPA2 Encryption key that is used toconfigure the Wireless Router. The Passphrase is an alternate way tosetup the Encryption key.
When you are requested for a Network Key, you can just enter the Passphrasethat was used to configure the Encryption key in the wireless router.http://www.fixya.com/support/r5270415-network_password_network_addressFor information on securing your wireless network,configuring the wireless router and configuring the wireless card in thelaptop/computer, please click on this link and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
Aug 01, 2012 | Computers & Internet
How do i hook up the wierd enternet to my ps3
keep trying if not try tomorrow connection problam
Jul 19, 2010 | Sony Playstation 3 (PS3) Console
I just got a belkin wireless router and i have my computer my playstation 3 and one psp connected up to it and i am trying to connect up another psp but it keeps timeing out i was just wondering how many...
Hi! all wireless routers can connect up to 30 to 50 wireless device. If your computer, your play station3 and the other psp is not timing out.. there is a possibility that there is a problem on the wireless capability of the other psp that ur having a problem.. check the wireless settings of your other psp and match it with the other psp that is giving u a problem. check also the wireless settings of your router, there are some router that you can connect only specifi device by assigning the mac address of the device that u want to connect to the wireless network..
Aug 17, 2009 | Belkin (F5D7231-4) Wireless Router
Centrios internet radio gives dhcp timeout
This is likely because out of the box, the firmware for this unit doesn't support WPA2 and even certain variants of WPA. I recommend: configure router for WEP or even open (i.e. unencrypted) connection, connect unit, go to setup/update firmware and let it update from network, power cycle, reconfigure your router for WPA or WPA2 security, attempt to reconnect unit to wifi. The updated firmware supports more formats and may allow your new router's config to work. You can also try doing the firmware update over the wired LAN port. Hope this helps.
Sep 27, 2008 | Computers & Internet
Wireless network not detected despite all elements seems working
Hello there.
This is a common problem. What i typically do on notebooks that use Intel Wireless, is install the latest drivers and Intel software from their website. 9 times out of 10 this will make it pick up a network that was not previously found, or fix problems with timeouts and so on.
Please click here then choose your version of windows, click 'Go!' and then click "Download" beside the section called "Intel® PROSet/Wireless Network Connection Software for Windows* XP/2000 32-Bit"
When you download and run this file, and install the software, you can then use the Intel utility to connect to the wireless network.
Hope this helps.
Jun 16, 2008 | Intel PRO/Wireless 3945ABG Network...
Loosing wireless connection
It sounds to me like your wi-fi client might be affected by some sort of timeout or overload type kick. Is it just the PC or both the PC and the Xbox?
By "timeout" this could be your "IP Lease" that is too short (look in your ADSL PPP/PPOE configuration)
Otherwise would you be using any P2P software? If so you might want to look in the settings for something called MTU. Set this to something like 1500 then if that doesn't do it reduce it to 1492.
The only other thing I can think of is that your pc might be having authentication problems. Degrade your wi-fi security (go from WPA to WEP) and test to see if that makes any improvements.
Oct 18, 2007 | 2wire 1800HG Router (RG1800HG00)
Netgear, Inc NETGEAR NeoTV Streaming Player NTV300-100NAS Logo
144 people viewed this question
Top Netgear, Inc Computers & Internet Experts
David Payne
David Payne
Are you a Netgear, Inc Computer and Internet Expert? Answer questions, earn points and help others
