Question about Measuring Tools & Sensors
I have a tesa weather pro WS1150 and can not set the time
How to set time and date
We're not the psychic hotline! Model number?
Click on the link, it's La Crosse Tech weather stations. Find your model or one similar to yours. Mouse over and click "more info". Select the "support" tab and then product manual. How to set date and time will be in the manual.
Weather Stations Weather Browse Products
Aug 15, 2016 | La Crosse Technology La Crosse Wireless...
I hear click , but can not lock the door
Need more information. Try lifting up on the handle when you card the lock. A worn or broken clutch assembly is a common issue with older TESA/Onity HT24 locks.
Mar 09, 2015 | Locks & Locksmithing
My portable programmer for Tesa HT20 keeps saying "clear the lock"
disassemble the lock and inside the lock is a small silver reset switch with a reset button with red button just simply press it with fresh batteries and hold it till the lights come on and go out and presto your lock is clear and can be reinitialized...
Sep 06, 2012 | Locks & Locksmithing
I need to program a weather scanner for a pro 2018 weather scanner from rdio shack
Weather frequencies are factory programmed into the PRO-2018. Just press the weather button to start scanning them. You can also program one or more manually if you wish. For a list of NOAA weather broadcast frequencies, follow this link:
http://www.nws.noaa.gov/nwr/indexnw.htm
Need the manual for your scanner? You can download/print it here:
http://support.radioshack.com/support_electronics/doc69/69290.pdf
Bill B
Sep 05, 2010 | Radio Shack Pro-2018 Scanner
The clock on my touch pro 2 keeps going pa time zone and i live in estern
I had this same problem. I thought at first it was a cell tower issue. I called US Cellular and asked. They said it was a known problem with this phone. They had me go into Settings-All Settings-Personal-Phone-CDMA services-Time Synchronization and click "get settings" Then uncheck the "Time Synchronize with mobile network automatically". Then I went and manually changed my time zone (on that same screen click "Clock&Alarm"). It stayed on that correct time zone.
BUT then I did some searching online and someone had said they manually updated "QuickGPS", then updated the weather tab and everything went back to normal. I noticed that I only had 4 hours left on QuickGPS. So I updated it and then updated my weather and everything went back to normal. I turned back on the network synchronization and everything still stayed in the correct time zone. So, maybe it's an issue with QuickGPS when it gets close to the end of it's time before it expires. Just a thought.
Feb 04, 2010 | HTC Touch Pro Smartphone
I have a HTC touch pro 1 and I am having problems when I receive texts with images. The images never load. Why? Also, is there a way to set music for my ring tone? Also, I cannot set the weather option to...
Ok,
for images : check your MMS settings if there's any restriction sizewise.
for music : insert desired music file to phone or memocard root menu. Your phone support .mp3, .wav files. Use built in Music trimmer to make ringtone(should be up to 30 sec.)
for weather: not all town are in database,some countries have only capitals displayed.
Get app called Advanced Config Tool and you'll be abble to do a lot of tweaks in your device.
Jun 04, 2009 | HTC Touch Pro Smartphone
Innovage AM/FM/Weather Radio Problem
I believe it is just a China import; I would give up and just get one from Radio Shack instead - I know how you would like to get it right, but I would send a decent letter to Bass Pro Shops along with a copy of your receipt from Radio Shack and ask them to refund you - it might work.
Oct 25, 2007 | Innovage (1504368) AM/FM/Weather Radio
Measuring Tools & Sensors Logo
Top Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
