Question about Cell Phones
Not able to access play store, sd card and, some settings on kyocera rise after factory reset
My phone detects when the sd card is installed and removed by it still gives me a message that no sd card installed. Goggle play store stops before it starts. Cant access any apps under the settings menu..
You must do a system update to latest software version in order to access play store
Posted on Nov 20, 2013
Vivekt1000
  • 35 Answers
SOURCE: cant find photos on memory card
Your photos must be saved in phone memory. So you have to check all folders of phone memory. After finding your photos in phone memory u can send them to your pc via bluetooth or infrared . Thank you.
Posted on Aug 12, 2007
erone47
  • 458 Answers
SOURCE: Samsung SGH-D600 "Install error"
you need to reset your phone, that might solve the problem. a full master reset should work.
Posted on Jun 08, 2008
SOURCE: LEXAR MICRO SD CARD WITH LG CU 500
I have found that only my 1 gig Micro sd card works, I also have a 2 gig and it does not recognize it at all. I have been told the CU500 only supports up to 1 gig.
Posted on Jun 27, 2008
SOURCE: my nokia 6500 cant detect my micro sd memory 1gb.. plz help
hi, i got the same problem and got to solve it. Try this...
1. the battery cover must be put on otherwise, the hp won't detect the memory.
2. try to fix the cover or hook by bending it.
Good Luck.!
Posted on Feb 24, 2009
SOURCE: i cant access my messaging
i have same problem and rest my phone but has made no differance still cant access messaging ,code is on orange rio website trouble shooting
Posted on Jan 16, 2011
My sharp home theater's usb port suddenly is not detecting my sd card. It was fine yesterday, now I couldn't play my mp3 files in the sd card.
Do a hard reset to this set, and then check. There are two methods to reset. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the device from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand devices are given. Never forget to exit the service mode, after all adjustments have been done.
Aug 28, 2016 | Sharp H.T. HT-DA641PA
How do I hard factory reset my kyocera hydro air
a factory reset will loose all your data
nice phone
try this link a 95 page pdf should have an answer
page 85
Factory Data Reset 1. From the Home screen, tap Apps > Settings > Backup & reset. 2. Tap Factory data reset. 3. Read the factory data reset information, select the Erase SD card check box if necessary, and tap RESET PHONE. 4. Tap ERASE EVERYTHING. Note: The deleted data CANNOT be retrieved.
https://www.kyoceramobile.com/hydro-air/Hydro-AIR-User-Guide-ATT_en.pdf
May 19, 2016 | Kyocera Cell Phones
How do reinstall google playstore app on my android cell phone
Best option is to save any downloaded apps onto a micro sd card or do a dump onto a PC so you can factory reset your phone. I accidentally uninstalled play store from my phone and, even after downloading and trying to install it, it never worked. I had it on the original build of my phone so I just saved all of my stuff and did a factory reset.
Hope this helps.
Dec 20, 2015 | Google Cell Phones
How do you undo a factory reset on a Kyocera hydro smartphone
Most of the time you cannot restore back to before you did a hard reset unless you backed up everything to an external device such as an sd card or to your computer. Unfortunately phones don't normally have restore points incase this happens :(
Apr 11, 2015 | Kyocera Cell Phones
Apps unresponsive kyocera hydro
Try performing a Factory reset on the phone. This will generally fix bugs related to auto shut downs.
Aug 15, 2014 | Boost Mobile Kyocera Hydro Smartphone
Reinstall cellular software
I would suggest a factory reset if you have you are connected to the internet, are logged in correctly, and are still getting this. menu/settings/sd and phone storage, Factory data reset
Oct 22, 2013 | HTC EVO 4G Smartphone
My Kyocera Rise has LOTS of problems! The one I want to ask is why do I keep getting a random message saying, "SD card has been unexpectedly removed"?
There are several possible reasons for this. The Kyocera Rise requires an SD card to be unmounted through the memory option in the settings. If you remove the SD without unmounting, you will receive the error message. The Rise also has several software issues that sometimes cause your SD to stop being read, even while still inserted. If you receive this error message without removing your SD card, it is recommended that you take your phone to a company certified Sprint store to have it checked out.
Jul 01, 2013 | Cell Phones
Kyocera milano is cycling and wont shut off
If you have computer make sure your pictures are on it then the store should reset
Nov 29, 2012 | Kyocera Milano
How do I reset factory settings/SD card on my huawei blaze?
1st you need to format the SD not reset it. As far as the factory reset goes just call your cell phones service provider and they can instruct you how to do that.
Jun 30, 2017 | Cell Phones
Cell Phones Logo
54 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
