Question about Plumbing
Loose dornbracht faucet - Plumbing
How to tighten loose handles on the 2 handle Delta Vessona kitchen faucet model #21925LF
usually have a setscrew in them!! mine are allen heads very small
Feb 11, 2015 | Delta Plumbing
Tip
How to repair a noisy faucet
REPAIRING A NOISY FAUCET
  • A noisy washer-type faucet is usually caused by a loose seat washer. To stop the noise, first turn off the water and take the faucet apart as described previously. If the washer is loose, tighten it or replace it.
  • After threading the stem back into the faucet body, try moving it up and down. If it moves, the stem is worn and the entire faucet must be replaced.
  • Some faucets are noisy due to poor design and construction. The only way to solve this problem is to replace the faucet with a quality one
on Jan 16, 2010 | Plumbing
Fix a loose faucet model 989 the nut underneth sink keeps coming loose
Was this faucet installed recently? Most faucets come with nylon washers that are to be installed before threading on the nut. These act as a lock washer, preventing the nut from becoming loose.
Nov 02, 2014 | Plumbing
Why is my grohe alira kitchen faucet loose
There is a nut up under the counter its hard to see but tighten that . Most faucets come with a special tool fo hat but can be done with wrench
Aug 31, 2014 | Grohe Alira Pull-Out Kitchen Faucet S....
Dornbracht mixing valve
Yes it probably is! Now what is the question?
Nov 26, 2013 | Home
How do I tighten a Delta kitchen faucet that has become loose?
If it is faucet body on sink loose under sink there should be screws and a plate or washers holding it sink. Tighten them up.
Some have a bolt or nut in the middle requiring a socket to tighten.
If the spout is loose remove handle and it has a plastic ring on top to tighten spout up.
Feb 13, 2010 | Delta Faucet Plumbing
We are trying to remove the handle on a delta 172 single handle kitchen faucet. The hex screw won't budge now, but we were able to get the handle a little bit loose. Now not only is the faucet dripping,...
Make sure the exact allen key is in the screw. take a small adjustable wrench, close it onto the allen key, and loose with wrench turning the allen key.
good luck
Oct 09, 2009 | Delta Faucet Delta 172-WF Waterfall Single...
Sprayer loosing presure
If you have a Delta faucet your diverter may need to be replaced. The diveter is located under the spout (see diagram)
Here are the instructions:
  1. Turn off water to faucet.
  2. Remove handle.
  3. Remove top cap.
  4. Turning spout back and forth gently lift and remove.
  5. Remove and replace diverter.
Hope this helps and please remember to rate this!
Dec 09, 2008 | Delta 2402 Classic Single Handle Kitchen...
Faucet Repair
A noisy washer-type faucet is usually caused by a loose seat washer. To stop the noise, first turn off the water and take the faucet apart as described previously. If the washer is loose, tighten it or replace it. After threading the stem back into the faucet body, try moving it up and down. If it moves, the stem is worn and the entire faucet must be replaced. Some faucets are noisy due to poor design and construction. The only way to solve this problem is to replace the faucet with a quality one.
Aug 27, 2008 | Danze D316440DNT Fairmont Two Handle Wall...
Plumbing Logo
73 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
