Question about Standard Registar SD650 Color Copier
Download printer driver sd650 - Standard Registar SD650 Color Copier
I have used Code key by mistake and cannot correct.
Remove the print wheel, look for bent spokes and be sure that the ribbon or correction tape are not tangled in it.
DickyO
Feb 25, 2015 | Smith Corona Typewriter SD650 Refurbished...
Smith Corona SD650 Model 5A Ribbon
This takes an "H" series ribbon SCM #21000
DickyO
Apr 10, 2013 | Smith Corona Typewriter SD650 Refurbished...
Whats the cause of a blank copy in a copier machine Nashuatec,Ricoh or Gestetner machine
can be several causes.
1-Tansfer rollers or wires broken or not charging.
2- no charge to the drum
3-laser unit --could be the shutter not opening or bad laser(should give a code if bad laser)
4-Developper not charging and transferrring toner.
If you can open machine and cheat door to make copier run, make a copy and stop paper as it gets to drum you should see toner on the drum. If there it is not transferring to the paper problem should be the transfer roller or wires(directly under drum. ) If not you need a tech to determine which one is not working.
Sep 05, 2012 | Standard Registar SD650 Color Copier
Our Standard SD650 Duplicator has error code SC07-30. The paper tray is jammed in the down position. Need the reset code to clear the error
Through my own efforts & online research. Your service team never responded. I paid for live chat assistance which was not provided, and was then directed to email assistance which has been a complete joke. Please fully refund all fees charged to my credit card. I will look for other solutions to tech problems in the future.
Dec 11, 2009 | Standard Registar SD650 Color Copier
I have a Konica 7030 photocopier. f-26-1 code came up what does this mean we had just changed the toner cartridge pls adv
F 26 IS RELATED ON DEVELOPER UNIT. TRY TO CALIBRATE THE DEVELOPER USING 47 MODE SUB 25,AND LET THE MACHINE RUN FOR 10 MINUTES
Nov 26, 2008 | Standard Registar SD650 Color Copier
Standard Registar SD650 Color Copier Logo
83 people viewed this question
Top Standard Registar Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Standard Registar Office Equipment and Supply Expert? Answer questions, earn points and help others
