Question about Moen F7425 Chateau Single-Handle Kitchen Faucet with ChoiceFlo Filtration C...
Loose spout on a moen kitchen faucet - Moen F7425 Chateau Single-Handle Kitchen Faucet with ChoiceFlo Filtration C...
jj505
  • 195 Answers
SOURCE: Loose handle on my Moen single handle kitchen faucet
Yes it is fixable and easy.To save you time because I belive you will be needing a new part from Moen I am sending you this easy link to quickly resolve your issue. Just be sure to tell Moen you are original owner of faucet and all parts are lifetime free including shipping. Go Moen!!!
http://www.moen.com/contact.cfm?location=TopNavCustomerSupport
Thanks and Please Rate jj505
Posted on Apr 06, 2009
jj505
  • 195 Answers
SOURCE: handle on moen kitchen faucet is loose after
Posted on Apr 08, 2009
  • 3600 Answers
SOURCE: I have a moen pull out kitchen faucet that leaks
You have a bad internal o-ring or the sprayer o-ring is leaking, if you look under the sink turn it off and then turn it back on, if you see it leaking out the center shft where the water pipes go into then the faucet may have a broken pipe or loose pipe. check and tell me where it's leaking at. You can buy kits to repiar them they are inexpensive.
Posted on Aug 30, 2009
  • 127 Answers
SOURCE: Moen kitchen faucet model 7430 leak
cartridge does not stop that type of leak. If it is leaking from around the base of the spout it is o-rings that are the problem that are onthe valve after you pull the spout all the way off.
Posted on Oct 18, 2009
c7121
  • 160 Answers
SOURCE: moen kitchen faucet spout
there should be a removable "button" on the faucet base below the handle. under there, there should be a set screw. loosen the screw, remove the handle. now u can adjust the base, collar, etc. to ur liking...don't forget to reassemble everything the same way u removed them.
Posted on Dec 13, 2009
Testimonial: "that was one reason I was looking for a diagram to show EXATLY how everything goes back !! will try your suggestion thanks"
How do I remove the cold water faucet cartridge on a Monen high arch, 2 handle w/sprayer, series 7700 Montecello
  • How to Fix Leaking Moen High Arc Kitchen Faucet -DIY blog.trebacz.com/2012/12/how-to-fix-leaking-moen-kitchen-faucet.html Video embedded · Our Moen high arc kitchen faucet started to leak around the base of the high spout. We had the Moen Monticello 7700 series single handle faucet for 8 ...
  • Frequently Asked Questions (FAQs) Regarding Moen Faucets www.moen.ca/consumer-support/faq ... a cold water filtering faucet, ... tighten the cartridge nut or replace the cartridge. If the faucet has a handle connector: ... Remove the faucet handle.
  • Monticello by Moen - Monticello www.moen.com/monticello/_/N-1z141yd Monticello. Chrome replacement handle knob insert ... As the #1 faucet brand in North America, Moen offers a diverse selection of thoughtfully designed kitchen and ...
  • Installation Help / Animated Tutorials for Moen Faucet www.moen.ca/consumer-support/installation-help Moen's animated tutorials provide installation help for many of Moen's ... How to Remove & Install the 1222 Cartridge. ... Removing a Single-Handle Kitchen Faucet ...
  • Contractor John replaces a cartridge in a Moen faucet ... www.youtube.com/watch?v=FqzpRE-MmEo
    • BY CONTRACTOR JOHN
    • 11 MIN
    • 279K VIEWS
    2011-10-26 · Contractor John replaces a cartridge in a Moen ... Repair Moen Single Handle Faucet, ... How to remove an old kitchen faucet and install a ...
  • May 05, 2016 | Plumbing
    How to tighten swivel spout of moen kitchen faucet
    pop the cover off the top of the spout tighten the screw underneath and replace the cap.
    May 11, 2014 | Moen 7065 Vestige Single-Handle Kitchen...
    Leaking CA87681 moen kitchen faucet
    Throw a cloth over the cover to prevent scratching the finish and grab it with a large pair of channel locks and unscrew it.
    Nov 18, 2013 | Moen 7907 Chateau Two-Handle Kitchen...
    Need to replace O Ring but cant pull the spout off
    there might be a allan screw holding it down usually located at the back of the faucet if not there is a chance that there is a screw on escutcheon just above the base of the spout this should screw off with a strap wrench.
    Aug 24, 2012 | Moen Monticello Single-Handle Kitchen...
    How do you get the spout off?
    Information on your faucet can be found here:
    http://www.moen.com/chateau/chrome-two-handle-low-arc-kitchen-faucet/_/R-CONSUMER%3A7907
    The exploded parts view can be helpful is seeing how your faucet is assembled:
    http://www.moen.com/shared/pdf/7906pt.pdf
    First turn off the hot and cold water supply taps. Then to remove the spout you simply unscrew the spout cap counter-clockwise; you should then be able to lift the spout up and off the supply post.
    May 19, 2011 | Moen 7907 Chateau Two-Handle Kitchen...
    Moen cathedral keeps coming loose and it base moves when you rotate the spout from sink to sink.
    tighten the lock down nut under the sink , also,, unscrew the cap (at the base of the spout,, and Lube the O ring ( with either plummer grease if you have it, or if not with vasoline) this should cure your problem
    May 04, 2011 | Moen Monticello Single-Handle Kitchen...
    I have a loose spout on my kitchen faucet it is a moen 7425 how can i tighten it.
    Sorry to read about your problem, I hope this helps you out.
    you have to go underneath the counter... look up and you will see what bolts are loose
    I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
    Dec 25, 2010 | Moen F7425 Chateau Single-Handle Kitchen...
    Moen 7700 leaking at base of faucet. how do you get to o-rings
    Here's a link to show you how to get the spout off using "strap wrenches" The allow you to get the nut off at the base of the faucet spout without harming the chrome finish.
    http://blog.trebacz.com/2012/12/how-to-fix-leaking-moen-kitchen-faucet.html
    There is also a video at the bottom of the blog post showing how I did it.
    Oct 17, 2010 | Moen Monticello Single-Handle Kitchen...
    Trying to change cartridge on Moen single lever kitchen faucet with sprayer. Now that it's been reassembled, gets no water from spout when turned on. When lever is turned on, sprayer goes off and...
    Moen has a diverter built in that will need to be replaced.
    use the same steps as when you replaced the cartridge, but this time you will need to remove the spout, there is a small diverter, you will see it when spout is removed.
    take this part with you to the hardware store, along with the O Rings from the spout, as they will need to be replaced also
    use a non silicone faucet lubricant when putting back together
    Aug 08, 2010 | Moen 7437 Chateau Single Hole Kitchen...
    Moen F7425 Chateau Single-Handle Kitchen Faucet with ChoiceFlo Filtration C... Logo
    32 people viewed this question
    Top Moen Plumbing Experts
    john h
    Donni Steen
    Don Numinen
    Don Numinen
    Are you a Moen Plumbing Expert? Answer questions, earn points and help others
