Question about Bates Power Arm Extra Heavy Duty Stapler 224XHD Staples 240 Sheets
Will not work
Cleared of obstructions, and new staple still will not come out when trying to use it.
How to reload staples.
If this is a staple gun then you need to release the tab on the back of the gun. It will release a long spring with a push rod on it. Insert the new staple bundle and replace the push rod. If this is a desk top stapler then pull the top until it opens. Set staples in and close the top again. Make sure to clear out any staples that may be loose or lodged before.
Nov 29, 2015 | Staples Tools & Hardware - Others
My Optima 45 has stopped stapling. I cleared the area of crimped staples but it won't punch out a staple. What can I do?
There may be a reset button / leaver open it back up have a look around and see if there is any thing like a leaver that needs to be pushed into place for the machine to recognise it has been reset.
Feb 06, 2015 | Swingline Optima 45 Electric Stapler
I HAVE A SWINGLINE STAPLER AND IT JUST STOPED WORKING CAN YOU HELP ME TO FIX IT THANKS
When a stapler stops working it is because it has jammed.Try to open it by pulling on the silver bottom part while holding the top black part there is a release on the bottom.Press the release at the back and unload staples.You should see jammed staple in feed,clear it them.Reload with new **** of staples.It should now function.Use a pin or paper clip to clear pull out jammed staples.
Jan 04, 2011 | Office Equipment & Supplies
I get a Staple Detect error each time I try to scan a page. I've checked all of the rollers; they are fine. There are no staples anywhere in the picture. Can I turn Staple Detection off?
I presume you are using CpaturePerfect3 Scanning software. There is an option to stop checking of 'staples'.
In Canon 9080C staples are NOT detected by any metal detector! You'd notice a set of LEDs on one side and a set of sensors on the opposite side of the scanner wall, just above the paper tray. Incase there is a document thats stapled, while one sheet is going in, the other sheet will get lifted because of staple. Thus when there is obstruction in the LED sensor, it is presumed to be a stapled document. Conversely, even if a document is bent enough to block the sensors, the scanner assumes it as a stapled document. Ensure your documents are fairly flat.
S. Mohan, Chennai, India
Dec 30, 2010 | Canon DR-9080C Path-Through Scanner
I would like to know where I can buy staples 804-809 for my Swingline Professional Saple Gun No. 10011
Hi,you can use any brand staples on your tool..
As an example here is a link on ebay for 5/16 staples..
Take care and please remember to rate me..Regards
Arrow 591188 300 Box 1/4"x5/16" Clear Insulated Stapleshttp://cgi.ebay.com/Arrow-591188-300-Box-1-4-x5-16-Clear-Insulated-Staples-/130360323235?pt=LH_DefaultDomain_0&hash=item1e5a14aca3
Nov 05, 2010 | Staples Swingline® 36115 Staple Guns Tools...
The stapler is fixing two staples instead of one at a time.what can be the defect and how to correct it?
First check and make sure the proper staples are in the gun. Also check and make sure the stapler is clear and no jammed or broken staples are in the gun. If this is a desk stapler make sure the plate is locked in for the staple to hit and bend the ends out or in. if all this is working the driver or the piece of metal that pushes the staple out may be bent. If the stapler is new take it back if it is not a minor problem and get a new one.
Jul 01, 2010 | Tools & Hardware - Others
How do I open the swingline model 900xd
It took me and my boss wrestling with this mongo stapler for 15 minutes to figure it out! :0)
To open the front end, pull up on the handle while simultaneously pushing down on the small black lever on the front. This takes some firmness and be warned, if it's jammed with staples it's going to take some serious force to get it open - watch your fingers!!! I strongly suggest the minute you get a jam, open up the front and clear it. Don't continue to staple in hopes it will work or clear itself or you will have a build up of jammed staples making it almost impossible to open and clear. Also note that when you open up the front end the staples tend to shoot out so be careful.
To open the back end to load staples, push forward and up.
Hope this is of help :0)
Dec 16, 2009 | Staples Swingline® 36115 Staple Guns Tools...
Swingline 520e does not staple
The trick to clearing this is to rn the stapler WITHOUT the cartridge in. We removed several visible jams, but once we ran it with the cartridge out, a huge piece of staple came out, and then we were able to put the cartridge back in and use it. Woot!
Sep 16, 2009 | Staples Swingline® 36115 Staple Guns Tools...
Piece of staple stuck in the trigger section of arrow t-50p
First, remove the magazine pusher / spring and any staples loaded in the magazine.  Then try firing the gun to clear the staple.  Use a small jeweler's screwdriver and small needle nose pliers to get the staple out.  Reload and test.       These are relatively inexpensive staple guns.  If the problem persists it might be less trouble to replace the gun.     Best of luck and I hope this solution works for you.   Michael Mittelsdorf
Jan 11, 2009 | Arrow T50P ARROW STAPLE GUN
Bates Power Arm Extra Heavy Duty Stapler 224XHD Staples 240 Sheets Logo
18 people viewed this question
Top Bates Office Equipment & Supplies Experts
k24674
Are you a Bates Office Equipment and Supply Expert? Answer questions, earn points and help others
