Akai AA-8080 left channel output has filter issue. Garbled and scratchy output
Left channel scratchy and low ouput
  • 83 Answers
SOURCE: No output from left channel after crackling sound
does your unit have a volume knob or is it a paddle type with up and down?
Posted on Jul 12, 2007
robotek
  • 1512 Answers
SOURCE: Kenwood KR-4010 (late 70's vintage) with signal to IF amp but no output
Don't bypass the relay contacts. They serve to disconnect the amp stages from the speaker if a DC condition is present, and in doing that, save your speakers form damage. Check for a DC offset condition on the junction of the emmitter stabilizer resistors to the STK0040 on each channel. They will be 0.47 ohm power resistors(2 per STK) connected to pins 3 and 8 of the STK. Anything substantially greater that 100mv here generally indicates a blown STK. Don't bother to change both, but just the one that is faulty. Another common problem for this age of amp. The high silver content in the legs of the transistors allows for "growth" between legs and internal connections of the transistor. Check for "black death" on the legs of transistors driving the STK. . . I tend to replace them if in doubt. If you need expert advice, comment me back. I am an audio specialist.
Posted on Feb 03, 2008
  • 236 Answers
SOURCE: hi. i have an Akai aa-8080
when you say it turn on-off you're not able to establish your audio out right? the possibility is that you have a bad speaker causing the system (aa8080) to trip. have you tried turning on without the speakers. can you try it first and then find out if it still does the same. because if there is something wrong in your output stage, you should not get that ticking/switching sound, it is not suppose to turn on (output stage) because that switching you can hear is actually your proitection circuit.
Posted on May 03, 2008
SOURCE: i have an akai aa-a25 reciver and right side speakers only work
I had this problem when I first got this receiver back out of years in a box, but it was fixed by pressing the reset button on the back. Hope that works for you!
Posted on Jul 26, 2009
dunnbiker
  • 8546 Answers
SOURCE: Aiwa 8100 amplifier, low output
Aiwa xx8100??? What are the missing letters? Maybe it's a source or preamp problem, eh?
I presume you have proven the channel is dead by trying multiple sources, swapping a different speaker onto it and that the balance control is NOT all the way to one side; headphones don't work either and we're down to proving it's dead before you take it in to a tech, right?
There is the slighest chance that a common control may have developed a high-resistance or 'dead' spot and is causing your symptom. Turn the POWER OFF and operate every control throughout its range a number of times, especially rarely-used ones like Tape Monitors and the Mute control.
If it still doesn't work you might want to prove if its a low-level signal loss or a high level amp failure. One way would be to run an RCA cable pair from the Tape Out to any other device (even a TV with speakers) you might have that accepts an audio input. If IT can't detect receive the DEAD Channel you
Posted on Apr 09, 2011
How to connect s1100 akai sampler to a mixing board music amplier how to connect the jack plug into the right connections
You would come out of the S1100 l/r output jacks into your mixer line input jacks on 2 channels, one panned left, one panned right. Be sure to adjust the input pad on each channel to where you're getting a hot enough signal and that the channels you're inputing to are routed to the mixer's main outputs.
Dec 13, 2014 | Akai Music
Sony str-de185 left channel very scratchy and poor; not speaker, wire, or connections
Could be an open resistor in the amp for that channel. Might have to have a pro look at it.
Mar 26, 2013 | Sony STR-DE185 Receiver
P50s601 sound issue
The model number indicates a Hitachi Plasma (correct?)
If buzz etc one channel is having a problem (not likely the speaker as you have discovered)
RCA HAS A OLDER SET WITH SAME MODEL NUMBER.
Means the left channel in the audio output is defective--If you Google the model number with "service manual" you should be able to find a schematic which will tell you if a single chip is used for both channels for output (this is usual case).
With that information either the chip or the board it is located on should be able to be repaired or replaced outright.
PTS ELECTRONICS DOES REPAIR BOARDS WITH ISSUES LIKE THIS (national company) in case you cannot locate either the part or the complete board.
Hitachi customer service may also be of help if you contact them--one channel low, buzz etc almost always is in output circuit of the audio.
Mar 26, 2012 | Hitachi Ultravision P50S601 50 in. Plasma...
How do i fix my turntable when the output is working on the right hand side but not the left
First - Has the cartridge failed, or has a wire become lose to it? Have you checked the cable comming from deck?
If you have or none of these gives solves the problem, then try reversing the leads on the cartridge so the good ouput gets the missing channel. If you still can't hear it then there's a electronic fault on the left hand channel pre-amp inside the record deck.
Oct 19, 2009 | Stanton T.120 Turntable
Left channels not working
Check out the left channel amp stages - your issue is there.
Apr 30, 2017 | Yamaha RX-V395 Receiver
The output to the front left channel is low
Try adjusting level calibration for the front left speaker under setup. This should solve your problem.
Mar 11, 2009 | Onkyo TX-SR705 Receiver
Right front speaker channel has a lower than usual output...
very basically try swapping over the speaker cables, if this doesnt work i suspect you are in need of a new ouput i.c. these can go if the speaker wires are touched together, unless there is a protection circuit.
Jan 25, 2009 | Sony STR-DE825 Receiver
Akai recording problem
You might have a bad cable to the recorder (try swapping the right and left connections and see if the problem moves to the other channel), dirty tape heads (use a cotton swab and head cleaner or isopropyl alcohol to clean them), or a circuit problem inside the recorder. Hope this gets you started!
Nov 19, 2008 | Audio Players & Recorders
Hi. i have an Akai aa-8080 that powers up OK but starts switching on and off. there is a switch inside thats activating which is wired, connected to the fuse at back of receiver. this switch i think has...
May 03, 2008 | Audio Players & Recorders
 Grubhead
Grubhead
