Home | Hotpoint | 24 in. HDA2000Z Built-in Dishwasher | H2000 WATER DOES NOT DRA...
Hotpoint 24 in. HDA2000Z Built-in Dishwasher
Problem for Hotpoint 24 in. HDA2000Z Built-in Dishwasher
H2000 WATER DOES NOT DRAIN
By jrwillis7708 on May 05, 2009
h2000 WATER DOES NOT DRAIN
Solution #1
posted on May 05, 2009
Somewhat Helpful)
ivanlongcrow
Rank: Wiz
Rating: 82%, 61 votes
There is probably debris in the line or the pump may be seized up. First unplug the power or disconnect the unit. You will probably have to pull the unit out to get to the water pump. Remove the hoses one at a time and run a wire through them to make sure the lines are clear. Then when thats complete remove the pump and make sure it still spins. If it doesn't move you will need a new pump.............. : )
Was this helpful?
Yes
No
Popular Solutions for Hotpoint 24 in. HDA2000Z
Questions and Unsolved Problems for Hotpoint 24 in. HDA2000Z
Do you recommend Hotpoint 24 in. HDA2000Z Built-in Dishwasher?
Answer
Answer
wash cycles not working, load machine, select wash cycle, it then runs but does not clean
Answer
will not wash- not sure if it is the same model, but i turn it on to wash, and it doesnt start a... (More)
Answer
when i turn the dishwasher on the water comes in and it sounds like it is washing but when i open... (More)
Answer
My hotpoint dishwasher leaks every time it starts to drain the water.
Answer
dishwasher starts filling with water, but starts emptying a few seconds later
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Hotpoint 24 in. HDA2000Z...:
Top Dishwasher Experts
Rank: Guru Guru
Solutions: 1303
Experience: 15 years field experience and 5 years navy training
Ask Me
Find more Dishwasher Experts
Top Dishwasher Repair
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 905-9505
A&E Factory Service is a nationwide leader in...
A&E factory service
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
