Question about BSA Optics
Have a problem with ge3*9*50ir bsa scope - BSA Optics
5 Suggested Answers
  • 152 Answers
SOURCE: how do change the battery in a BSA HD42SB
It should be seated inside the windage knob, if not look for a slotted type indentation in one of the knobs, and turn that cap counter clockwise with a coin that fits snugly in the slot while holding the sides of the knob.
It will be a pancake style battery.
Aduz
Posted on Mar 30, 2009
  • 4 Answers
SOURCE: my scope is broken
Return the scope to where you purchased it and ask for it to be replaced. Or check out BSA's warranty page at: http://www.bsaoptics.com/returns.aspx . At any rate, DO NOT DISASSEMBLE YOUR SCOPE! This will void any chance of returning it and make it into a poor baton.
Posted on Jul 07, 2009
Adrian762
  • 425 Answers
SOURCE: 3-9x50 BSA Deerhunter Rifle Scope.
What that means is they are not mounted correctly. The scope mounts should be square with your rifle when fitted, when the scope is placed into the mounts, it should be turned to be square with the rifle.
Firstly, make sure you do not "cant" when you shoot. That is hold the rifle at an angle instead of vertical. Once you are sure that is OK, then put it into a vice using blanket or some other soft material to protect the stock. Get the rifle perfectly square using a spirit level. There should be a flat spot on the top of the action that you can use. Once this is achieved, you loosen off the scope mounts and square the scope up to your satisfaction. Once done, tighten the mounts up and then remove from the vice.
Posted on Feb 10, 2010
  • 243 Answers
SOURCE: cross hairs sideways?!
If you are seeing an X you need to loosen the scope rings, re-level your scope and re-tighten the scope rings. 10-20 in/lbs on the ring screws, 15-30 in/lbs on the mounting screws. Typical configuration of the turrets is one on the top, one on the right side.
Posted on May 31, 2010
How do change the battery in the BSA STRGBD30LL Laser Scope
Take a look here including the Video tab.
I see that Cabela's says one of the scopes has to go back to BSA for battery change.
http://www.bing.com/search?q=change+the+battery+in+the+BSA+STRGBD30LL+Laser+Scope&FORM=HDRSC1
Jul 20, 2016 | BSA Optics
I have a BSA sweet 17, 2X7X35 all The black paint on the Tube has turned really sticky, when you touch the scope the paint gets all over your hand.
The coating that BSA used on their scopes reacts badly with certain airborne oils and softens rubs off and looks scabby
Only thing to do is to rub the rest of the coating off with high acetone nail polish remover
Apr 20, 2015 | BSA Optics
I have age 3by9by40ir scope. it has a illuminator red dot in crosshairs .problem is need to use much strength to turn on.any way to fix? scope is brand new. somewhere to send?was achristmas present. use...
I've never had that problem with my scopes, but BSA's customer service department welcomes questions and comments. I bet they'll have some good advice. Here's their contact information:
954-581-2144 (Monday - Friday 8.30am - 5.30pm EST)
BSA Optics, Inc.
3911 SW 47th Ave. Suite 914
Ft. Lauderdale, FL 3331
Jan 22, 2011 | BSA ® Huntsman Series?? 3 - 12x50 Rifle...
My scope is broken
Jun 22, 2009 | Platinum Memory Bsa Platinum Riflescope...
Need instructions for my BSA Red Dot RD 30/22 Scope
I contacted BSA and they e-mailed me the instructions!
Mar 19, 2009 | BSA Air Gun Scopes
BSA 3-12 x 50 Rifle Scope
But a new scope. Having the crosshair reseated will cost you more than getting a new BSA scope.
Feb 16, 2018 | Science & Laboratory
BSA rifle scope
its a metric 1.5 for the cam adjustments
Nov 11, 2007 | BSA Big Cat 3.5-10X 42mm (3.5-10x42 mm)
Optics Logo
Top BSA Optics Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
NOEL
NOEL
Are you a BSA Optic Expert? Answer questions, earn points and help others
