Not responding to error turn off on machine - Office Equipment & Supplies
    Sergeant:
    Champion:
  • 246 Answers
Try to reinstall the printer dirver
Posted on Nov 20, 2013
Pls . help me experts , i have kyocera km3050 copier but the lcd touchscreen is not responding but days past when it still responding its getting hard to respond. please help me with this experts
A hard reset can clear minor error codes. A lot of times you do not really need to call for your support contractor. Sometimes errors stop the function of a machine, but the machine could still function properly with a hard reset. Perhaps there is a better description than hard reset, as "reset disable function" is a little bit confusing and not a phrase you were likely look for.
Contact your service provider before following these instructions.
Use at your own risk. Perhaps there is a possibility of causing damage. Again, contact your provider.
From our copier service company:
This reset is used for two purposes:
1) reset any data that may be "hung up" in the hard drive.
2) reset an error code and attempt to continue use. (If the error recurs, then you should escalate to whomever supports the copier.
Hard Reset Procedure:
Press Status button
Enter 10871087 - You are now in Maintenance Mode
Enter 906 (do not enter any other numbers!)
Press Start
Press Execute
Press Start
Copier tells you to turn it off/on
Turn off power by switch on right side of copier (hard power off)
Turn on power by switch on right
I have seen to use code 163 instead of 906. I don't know what this does. Again, consult experts before using this code or any others.
Feb 03, 2015 | Kyocera Mita KM3050 Black Toner Cartridge...
What's error 345 with HPOfficejet j5780 all in one while faxing?
error 345 while faxing is related to Communication error. This error is not related to printer hardware issue.
Below are the possibilities ....
  1. The remote machine failed to respond to a fax command from the local machine because the connection was interrupted.
  2. The remote machine failed to respond to a fax command from the local machine because the connection was interrupted.
  3. The remote user pressed the Stop key while the reception was in progress.
    The suggested solution would be as follows....
  • Retryt the fax reception at a different time when telephone line conditions have improved. Call the telephone provider if line conditions fail to improve.
  • Disable ECM. Errors might still occur, and might result in a degraded image quality on the received page. However, the ability to send the entire document will be improved.
  • Try sending at a lower transmission speed.
Jun 02, 2014 | HP Officejet Pro L7680 All-In-One Printer
Fault code 37,what does indicate.
Hi just read your posting.This error code is called PUMP BLOCK ERROR.Now please look under the machine for me to the front right.You should see a red or black fan,This is your pump.Now turn the fan clockwise and anticlockwise a few times to loosen it up if it is jammed.The fan should turn freely.Now put the machine back on its feet and select a spin cycle.The machine should start to drain.Please reply to tell me how you got on or if it still does not drain or if you have the other type of pump.Good luck
Jul 12, 2010 | Fisher and Paykel GWL11 Top Load Washer
Error code c0070
Power off the machine and gentlly take out the toner bottle. Then with the bottle out turn on the machine let the machine go thur its normal routine when the indicator comes on for toner install toner bottle. If the code comes back you have a problem with the Toner Bottle motor, gear, or Main Board.
Apr 17, 2010 | Konica Minolta DiALTA Di183F Copier
Hp printer 6313 all in have problem for fax. error number 351
The machine has a ECM (Error Correction)error.
Could be:
  1. The remote machine has failed to respond.
  2. The remote user has oressed the Stop button.
  3. Incompatability between two machines may cause the remote machine to abandon the call.
Try turning off ECM in the Fax Settings Menu.
Nov 24, 2009 | HP FAX 1250 Fax Machine (Black)
Sharp H4 Error message
Hello sir; The code need to reset;
1, press "#", "interrupt", "c", "interrupt" keys.
2, enter 14 then press start.
3, if machine work, please don't forget to give me a good rating.
THANK YOU !!!
Feb 09, 2009 | Sharp AR-5316 Advanced Digital Imager...
Svchost.exe application error
start the system up in safe mode (F8) on boot up, perform a system restore and restore the machine back to a date before the problem occured
regards
Nov 21, 2008 | Acer Aspire 3000 Notebook
Sharp AR 5316 E photocopier error clearing
try to cancel it by pressing: #-interrupt-C-interrupt simultaneously, then when the panel goes off input 16 then press the COPY KEY <> The machine will restart automatically. if U2 still remains.. try to replace the mainboard.
Jun 21, 2008 | Sharp AR-5316 Advanced Digital Imager...
k24674
