Question about Epson Office Equipment & Supplies
Printer error not responding - Epson Office Equipment & Supplies
Printer not responding?
Try removing the printer and re installing it. Sometimes computer updates can cause errors.
Jun 12, 2012 | Canon PIXMA MP240 All-In-One InkJet...
change ur data cable for trouble shoot
Mar 21, 2010 | Canon PIXMA MP210 Photo All-In-One Printer
Time out error. Locks up..
Hello , I you printer displeyed Error Time-out , You need to load the memory card (flash card with Fingerprint) Pozdrawiam lukas
May 22, 2009 | Intermec EasyCoder® PX4i Label Printer
Will not print. says printer not responding
Canon i320 does not want to print light flashes green and orange alternatively. Please help. I tried the above, but nothing works
Apr 20, 2009 | Canon BubbleJet i320 Printer
My canon MP610 printer is not responding after replacing ink
Try switch of computer and printer if not in printer list of printers. Unplug usb cable and start computer without computer connected. Them switch off computer again and plug in usb cable and then restart and after started switch on printer and Windows should find printer as a new connection and then you may need your driver disc to reset up.
Mar 17, 2009 | Canon PIXMA MP610 InkJet Printer
PixmaiP6700D:error#300. "The printer does not respond. Make sure that the printer is plugged in, powered on, and properly connected to your computer." I've checked all of the connections and...
Error Code300--
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
Sep 05, 2008 | Canon PIXMA iP8500 InkJet Photo Printer
HP Laserjet 1320 Printer doesn't respond
Manual Feed or Continuable
Error
This state can be reached in
the following circumstances:
● Manual feed
● Out of paper for the
specified tray
● General continuable error
● Memory configuration error
● Personality/Job related
error
Solution
To recover from the error and
print whatever data is possible,
press the GO button.
If the recovery is successful,
the printer goes to the
Processing Data state and
completes the job.
If the recovery is unsuccessful,
the printer returns to the
Continuable Error state.
Feb 05, 2008 | HP LaserJet 1320 Printer
CANON PRINTER PIXMA iP 8500 ERROR 300
Thanks for your posting in FixYa.
  1. Turn off printer
Dont forget to vote me.
Regards
Ellin
Nov 08, 2007 | Canon PIXMA iP8500 InkJet Photo Printer
14 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
