Question about Saws
Blade wont turn on wet saw - Saws
4 Suggested Answers
  • 31 Answers
SOURCE: how to change blade
remove the blade guard, should be a big nut holding on blade remove that nut install new blade, make sure the rotation arrow on your new blade is going same direction as old blade reinstall the big nut and washer , put guard back on you should be set! good luck
Posted on Mar 24, 2009
al_kupchella
  • 843 Answers
SOURCE: Looking for shaft lock to change the blade on MK 170 wet saw
Just use a rag and grab the blade. Unless the threads are messed up you don't have to hold the arbor still, just the blade.
Posted on Apr 27, 2010
  • 29 Answers
SOURCE: Cannot keep water on the blade of my 10" Rigid wet
if waters not getting to the blade you will see the powder of what ever your cutting coming off the back of machine,i like to put my pump in a bucket of water under the drain plug instead of puting the pump in the water tray,you can run bigger tubing up to the blade and reduce it down and it will give you better presure,good luck
Posted on Mar 01, 2011
Ridged wet saw beast how to raise blade
Hi John, The link below is a web page about ridged wet saw beast, J Hope this helps.....CHEERS..
Ridged wet saw beast Google Search
Apr 05, 2016 | Saws
Changing the blade on the 3540 wetsaw
Blade should be secured to motor. Make sure bolt is tightened while holding blade with a pair of channel lock.
Nov 07, 2012 | Skil 3540-02 7-in Wet Tile Saw
Ryobi WS721 wet tile saw blade wont turn on start up
I just got one of these and the same thing happened, arbor spun slow and hummed. I fixed the problem by removing the motor mounting bolts I wiggled the motor and the arbor spun like a champ. When I reinstalled the bolts I checked the motor after each bolt. What I discovered was the bolts where the cause of the binding so I relieved the pressure by loosening the bolts a quarter turn each. Saw now works perfect. Design flaw!
Aug 20, 2012 | Ryobi Saw. 3/4 HP 7 in. Wet Tile Saw WS721
The nut that holds the saw blade on is flat like a washer. I can't find a tool to remove it. i want to change the saw blade.
Some of those nuts had 2 holes in them and there is a special tool that fits in the holes and you turn the tool to unloosen it.
Mar 16, 2011 | Wet International Q.E.P 4 inch Portable...
Dec 31, 2010 | Ridgid 10"Wet Tile Saw with Laser and...
How do I take the cutting blade off a Mastercraft wet tile saw model #55-6829-4. I keep turning the ceramic like washer counter clock wise and it doesn't come off.
you have to stop the blade turning. Grip it with some locking pliers but it might damage the blade. Or jam it with a piece of wood/ stone and undo the nut.
Nov 23, 2010 | Saws
Apr 27, 2010 | Mk Diamond MK - 170 Wet Cutting Tile Saw
How to change blade
Mar 24, 2009 | Dewalt D24000S Wet Saw With Stand
Cant get the old blade off
should be a blade lock button, if not i clip vise grips on mine let the table keep the blade from turning put wrench on nut and tap wrench with hammer see if ya can loosen nut good luck billy
Mar 18, 2009 | Husky Wet Tile/Stone Saw with with Laser...
Saws Logo
27 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
