Question about Garmin GPSMAP 5212 Radar Pack w/ GMR 24HD Radome
Wy my radom(gmr 24hd) is work(turning) only for 1second
Error 2 on the screen
How to get rx off screen
This model has a "Monitor Mode" feature that allows you to listen for weak signals on the current channel at the press of a key.
1.) To turn ON monitor mode:
Press and hold the volume/monitor up or down key. The rx icon will blink.
2.) To turn OFF monitor mode:
Press the volume/monitor up or down key. The rx icon will stop blinking.
Jul 15, 2014 | Uniden GMR-325/2 2-Way Radio Walkie Talkie...
Cannot get ctcss off screen ofhand held uniden uh0375x
Fiddled with Mode selector button and found after 100 there is an oF position which removes cctss from screen.Worked fine after that.
Sep 03, 2009 | Uniden GMR-325/2 2-Way Radio Walkie Talkie...
Hello i have a Uniden GMR-325 (7 Channels) Two Way Radio that....
Hi Zachary
I predict that you have trouble with only one unit.
Try to find some one with either the same units ( on same Frequency of course) or a receiver that also covers same Frequency and transmit on one GMR then the other to esablish which unit is faulty!
The faulty unit should then become apparent, the buzzing could be caused by transmisson of the faulty unit, check all Antenna connections, even change antennas over on testing as prescribed above,
good luck John.
Apr 05, 2009 | Uniden GMR-325/2 2-Way Radio Walkie Talkie...
Display
It sounds to me like there might be a video processing problem in the scanner radome, or a break in the interconnect cable that runs from your screen to the radome.
If you did any work onboard recently that might have disturbed the interconnect cable please revisit the scene. If there was any kind of splice in the cable something may have come loose.
If the normal checks of tight, clean connections, adequate power to the display (which feeds the radome) don't revel anything, you may wish to call Raymarine or a local service dealer.
Dec 02, 2007 | Raymarine RL70CRC GPS Receiver
Uniden gmr 10.38-2 manual
Hi, The manual for your Uniden GMR 10.38-2 is available at the Uniden site (Support/Manuals). The file name is GMR1038-2om.pdf. The link is or . Hope this is what you are looking for. Good luck and kind regards.
Sep 07, 2007 | Radio Communications
Garmin GPSMAP 5212 Radar Pack w/ GMR 24HD Radome Logo
23 people viewed this question
Top Garmin Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Garmin Office Equipment and Supply Expert? Answer questions, earn points and help others
