Question about Sole Fitness Sole F60 Treadmill
Cannot find circuit breaker for sole f60 - Sole Fitness Sole F60 Treadmill
Wall breaker trips when power switch is flipped on
find the specification tag on the treadmill and note how many amps it draws...
Jan 16, 2018 | Sole Fitness Sole F63 Treadmill
Sole F60 Treadmill showing LS1 code...Belt won't start
You have a bad controller. You'll need a controller and a walking belt. Should be about $450 for parts.
May 30, 2017 | Exercise & Fitness
Can the motor control board cause the house circuit breaker to trip?
It's unlikely. An internal fuse would blow first, I'm assuming. If you've diagnosed this far you sound capable of continuing. Electricity is dangerous!!! I would remove all things from the board, 1 by 1 plug each component into board until the breaker trips. That should pinpoint what is tripping breaker. I would assume a motor.
Apr 04, 2017 | Heating & Cooling
Sole f60 incline error E2
does the incline work at all. if not try to calibrate the incline. if this fails something could be wrong with the incline motor
Oct 20, 2014 | Sole Fitness Sole F63 Treadmill
After putting together my sole f60 treadmill the display wont turn on, it gets a clicking noice, connections are connected. any idea where to start
Hook up the main harness . Make sure you didn't plug one of the connections up backwards. Hooking them up backwards will cause the incline to go all the way up and the display will not come on.
Aug 10, 2014 | Sole Fitness Sole F60 Treadmill
The circuit breaker for my range is in the "off"
If the circuit breaker can't be switched to on it is either because there is a fault in the range or a fault in the circuit breaker.
There should be a main switch on the wall or near the range. Try switching this off. If the breaker still can't be switched on then the fault is in the breaker, (assuming the breaker is dedicated solely to the range) not a common problem but it can happen. A fault in the range is normally due to a fault in the oven element or the hot plates.
Mar 05, 2011 | GE Profile JB968 Electric Kitchen Range
Put new bulb in baumatic kichen hood turned it on, instantly made a noise like it tripped out, fan and lights now don't work, can not find fuse?
It was probably a defective bulb that tripped a circuit breaker in your house panel. Check the breakers and replace the bulb.
Feb 24, 2010 | Baumatic F60 Stainless Steel Kitchen Hood
Candy Eclipse washing machine blows the circuit breaker
It's possible that the current rating of the MCB is too low to run your washing machine PLUS all the devices plugged into the other sockets on the same circuit. If possible, try plugging in the washing machine on a circuit with fewer or no other appliances plugged in. MCB's are much faster tripping than circuit breakers and are rated to trip at the current rating on them. Circuit breakers, may carry a current slightly over the rated current which may be why it never happened before. The permanent solutions (if the overloaded circuit is the problem) would be to install a circuit solely for the washer and dryer or install a MCB with a higher current rating. The latter solution is not practical, however, since an overload on lower power devices may never reach the current rating of the MCB creating a hazardous shock potential.
May 11, 2009 | Washing Machines
Sole Fitness Sole F60 Treadmill Logo
358 people viewed this question
Top Sole Fitness Exercise & Fitness Experts
Art Wilson
Art Wilson
Level 1 Expert
Ross Metcalfe
Ross Metcalfe
Are you a Sole Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
