Question about Tools & Hardware - Others
Empire #10470 air stapler
Where can I get parts?
2 Suggested Answers
  • 25 Answers
SOURCE: Looking for parts diagram for a unicatch stapler
It does not seem that there are any diagrams online... Try contacting unicatch directly, ask if they will fax or email you one.
The contact link is:
http://www.unicatch.com.tw/contact.html
Posted on Apr 19, 2009
What gage staples do I need for a p300 ryobi air stapler?
Good morning Victoria,
The staple series that you'll need is probably need is a 90 series. These are again an 18gauge wire in several different lengths.
Regards
collatedfasteners
Jul 05, 2014 | Ryobi P300 One+ Stapler Brad Nailer
How do I put the Bostitch B660 stapler back together?
MAYBE THIS IS USEFUL http://www.ereplacementparts.com/bostitch-21680b-industrial-fine-wire-stapler-parts-c-29443_29444_29449.html
Apr 02, 2012 | Air Tools & Compressors
How do I put back together Stanley Bostitch 660 Stapler?
HERE IS A GOOD SAMPLE http://www.ereplacementparts.com/bostitch-21680b-industrial-fine-wire-stapler-parts-c-29443_29444_29449.html
Stapler leaks ouy of top
Try oiling it first. If it still leaks I would check the seal (reference #11) on this parts diagram.
http://www.ereplacementparts.com/senco-sns41-nailer-parts-c-117621_117622_117782.html
Mar 07, 2012 | Senco SNS41 16Ga Stapler 1" 2"
Staple jams by driver blade in gun and I have to dismantle nose to get it out. Empire Rainco 7-16.
The problem is wear on the sides of the driver blade. With the constant up/down movement of the driver against either side of the nose plate, it eventually narrows enough to allow part of the fine wire 71 series staple to find it's way between the driver blade and the inside wall of the nose plate. A new driver blade cures this completely. Rainco tackers have become a bit rare but the good news is, they're actually manufactured by Fasco and the Fasco driver fits into the Rainco piston by the removal of a single pin to allow the old blade out, replace with the new Fasco blade, re-insert the pin into the piston, then re-assemble the gun and you're away.
Mar 06, 2011 | Nailers Empire Rainco R16 Stapler Driver...
Bostich narrow crown air stapler won't work
before going about rebuild get can of carburetor spray cleaner and stray the ram area lots of times the glue that holds the staples/or nails builds up and stops up the ram rod spray the rod a few times than with air hooked up dry fire if it frees up lube rod area
Jan 17, 2010 | Stanley Bostitch Sb 2IN1 2 In 1 Narrow...
Apr 19, 2009 | Air Tools & Compressors
Narrow crown stapler won't fire
If the gun has never been opened, the problem could be a lack of oil or worse, too much of the wrong kind of oil. No oil causes parts to stick. Too much of the wrong kind of oil caused the orings to swell and jamb parts. Carefully open gun to preserve head gasket and check for piston travel all the way down to the bumper. Piston should not be too tight, nor drop to the bottom under its own weight. The driver has a groove on one side that should align with the grove in the nose and it should not be bent. Next check the head valve by pushing the valve into the head with your thumbs. the valve should travel about 3/8 inch. If stuck apply air pressure to hole where gasket sits on head. The valve will pop out. Clean and lube parts replace orings or upper bumper if cracked. Assemble and test. Parts are not expensive at www.toolpartsdirect.com, enjoy
Nov 26, 2008 | Senco SNS41 16Ga Stapler 1" 2"
Tools & Hardware - Others Logo
122 people viewed this question
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
