Question about Vehicle Parts & Accessories
Valet remote car starter 551T OLD
COULD YOU HELP ME. I AM LOOKING FOR AN INSTALLATION MANUAL OF AN OLD VALET 551T REMOTE STARTER IT'S MANUFACTURING DATE IT'S 93 PLEASE BEST REGARDS KARINA
doin12volt
  • 233 Answers
SOURCE: car starter not working
look under the dash for a small silver toggle switch....this is a disable switch for the remote start portion of the system..you may have kicked it / bumped it with your foot, causing the remote start portion to be deactivated. Just flip the switch the opposite way and try again..
Also, there may have been a pin style switch installed under the hood...Check to see if it is bent or broken, if it is, simply disconnect it and insulate the wire that was going to it.
This wire is used as a safety to keep the vehicle from remote starting while the hood is up..to keep people from being injured if the remote start is activated while the engine is being worked on.
Have whatever shop installed the system replace your pinswitch if that is the problem.
Posted on Dec 19, 2008
bunnydawg
  • 5158 Answers
SOURCE: VIPER 160XVL remote start stopped working
sounds like the unit has lost power. i can't tell you where the relay is located for that device but it may have failed.
Posted on Oct 19, 2009
SOURCE: i have a bulldog deluxe
With ignition on push and hold valet (programing) button for 2 seconds or untill remote beeps and z"s disappear.
Posted on Dec 20, 2010
  • 63 Answers
SOURCE: Remote strater is in valet
Try these two possible solutions
Press and hold valet button for 10 seconds. Release. LED should go out.
or
Insert key into ignition. Turn to on position (do not turn on car). Press and hold valet button for 10 seconds. Release. LED should go our
Posted on Jan 04, 2011
raineman_15
  • 273 Answers
SOURCE: I have an auto command remote starter, model
Check your manual, when it honks or blinks at you it is telling you what is wrong (see my tip in my profile) . It usually will tell you what is wrong and is usually an easy fix.
Posted on Jan 20, 2011
Is there another way to program a remote start remote, The way its suppose to work doesnt.:door open, ACC on, push valet then again and hold. I think the door is not hooked up to read open.
563T Your Valet Alarm W/Remote Car Starter - Dr.Detail
www.drdetailshop.com > MAIN > YOUR VALET
Featuring: Viper, Hornet, Directed Amps, Viper Audio, Compx Subs, Your Valet ... 563TYour Valet Alarm With Remote ... A Free Wiring diagram, Installation parts
Sep 24, 2015 | Televison & Video
How can I get instrction book for reprograming avital remote starter for rpn 7111l
If you are looking to sync the remote key fob to the remote starter:
Remote programming 1. Turn key to the ON position 2. Within 5 seconds, press and release Valet button one time. 3. Within 5 seconds, press and hold the Valet button. The LED will flash one time and the horn honks to confirm entry into remote programming. 4. Press the button on the remote control. 5. The horn honks to confirm the remote has been programmed. 6. Release the Valet button, and turn the key to the Off position. 7. The horn sounds one long honk to confirm that remote programming has been exited. The programming routine exits if any of the following occurs: • The ignition is turned off • There is no activity for 30 seconds • The Valet button is pressed too many times
Mar 01, 2015 | Avital Vehicle Parts & Accessories
Need to program additional fob to Avistart 4111
Turn ignition on, press and release valet switch then, press and hold valet switch. Press button on remote. Release valet switch, turn off ignition. Test
Feb 08, 2014 | 4111 4111L Remote Car Starter
I have a prestige remote Audio box starter remote alarm on a 2002 Toyota Camry.I unplugged the sensor and the car still doesn't start.can you help me i am out of the state need to get home.
Locate the valet switch( black push button), turn ignition on, press and release valet switch. the valet switch is plugged onto the main control unit. You can find the main control unit by tracing the harness that you unplugged from the shock sensor. The valet switch is plugged into a two pin plug and has a blue end. Trace the wire to the valet switch.
Jul 10, 2011 | Prestige Remote Start
Led light is always on even when im driving and the remote start does not work....what do i gotta do....thanks
The LED light always on means the system is in valet. The remote starter should still work in valet so, check your hood pin switch to make sure the pin is making contact with the hood when the hood is closed.
Locate the valet swich under the dash. It's a black push button. Turn the ignition on, press and hold the button, count to five. Release the button, the light should go off. If there is a remote starter shut down installed, it should be located near the valet switch. It's a toggle switch that may still have a red boot over it. Flip the switch in the opposite setting. The remote starter should work afterwards.
Jun 28, 2011 | Car APS997A Two-Way Remote Start and...
Car trying to start but wont
put your key in the ignition leave it in the off position and try to remote start it, if it works the transponder loop around the ignition switch will have to be adjusted or if you have a key in the box under the dash it will have to be adjusted
Jan 12, 2010 | Directed Dei Valet 561r Remote...
How to reset audiovox remote starter
REPROGRAM REMOTES BY FINDING THE VALET SWITCH AND
TURN KEY TO ON
PRESS VALET SWITCH 3 TIMES
PRESS BUTTON ON REMOTE
PARKING LIGHTS WILL BLINK ONCE TO CONFIRM
TURN KEY OFF
DONT LET MORE THEN 5 SEC PASS BETWEEN STEPS
Oct 18, 2009 | Car APS921 Remote Starter - Keyless Entry
Valet 561r remote starter wont start my 2004 gmc sierra
You should not have to... Just start it with a key first.... What are the symptoms, please be more specific..
Jan 16, 2009 | Directed Dei Valet 561r Remote...
Vehicle Parts & Accessories Logo
81 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
