Mfx-1820/2010 - Office Equipment & Supplies
How to read meter on mfx-3530?
You can print the machine's information and job report.
1. Press Menu on the control panel.
2. Press the up/down arrow to highlight System Setup and press OK.
3. Press the up/down arrow to highlight Reports and press OK.
4. Press the up/down arrow until the report or list you want to print appears.press OK.
To print all reports and lists, select All Reports.
5. Press the left/right arrow to highlight Yes at the Printing? prompt and press OK
May 28, 2014 | Muratec Mfx-3550 Pro Edition mfx-3550 Pro...
Call servce 18 muratec mfx 2010
muratec mfx 2010 call service 18 problem
Oct 14, 2011 | Muratec Copier
I cannot connect my MFX 1300 printer to my home network. I have it connected to my ethernet hub but do not have the network interface card. do I need that?
Yes...the MFX-1300 was only a copier/fax machine when originally sold, so there was no facility to connect to a P.C.
To connect to a PC there was an Optional Printer Control PCB available.
Oct 19, 2010 | Muratec - MFX-1300 Copier
Muratec mfx 1300>> CAN I reset A "replace
YES....try the following...... Press PROGRAM,*,*,I(thats capital letter i) then press ENTER.
SHOULD RESET IT.
Jun 16, 2010 | Muratec - MFX-1300 Copier
MFX-2830 Black and White Copier: How do you replace a staple cartridge on a Muratec...
Open front door of the Finisher Unit. Over to the left beside the 2 green knobs you will see the Staple Cartridge. Pull slightly down and out and the cartridge will come out. A new cartridge has to be installed...they cannot be re-filled.
May 17, 2010 | Muratec MFX-2830 Black and White Copier
Scanning a photo
Most Muratecs now a days do scan in color. The 2850 is one such model. So to answer your question you are incorrect.
Jan 16, 2009 | Muratec MFX-2830 Black and White Copier
How do you take mirror lock off
There is unlock buttom where the papers comes out, and also you can go to setting and unlock it.
Dec 19, 2008 | Muratec MFX-1600 Printer
MFX -2380 (Muratec) issue with net work printing
In network environments the muratec's usually have to have the setup disk run. They do not work on the standard TCP/IP port. The disk creates a muratec port for the pc to print to.
Jul 21, 2008 | Muratec MFX-2830 Black and White Copier
Muratec mfx 1600
Drivers can be downloaded from Muratecs web site.www.muratec.com
Go to Support/Drivers and you will find them under Legacy machines.
Jun 21, 2008 | Muratec MFX-1600 Printer
Muratec MFX 2500 copies have lines
need to be more specific, printing have both hor. and vert. lines aas well as copying ???
Dec 18, 2007 | Muratec MFX-2500 Plain Paper Laser Fax
24 people viewed this question
jasbo
jasbo
