Question about Maxtor Hard Drive
Need jumper settings for using maxtor 91021u2 as slave,and adding 120 gb samsung as master.the jumper connections on maxtor are not labeled and pin config is different than what i am familiar with. any help greatley appreciated
  • 74 Answers
SOURCE: jumper settings
how many pins in that hard drve?..let me analyze to you this, if the hard is in front of you, you'll see the connection of the ide cable and power cable, then the jumper setting pins is in your left,am i right?..so the pins is figure like this, : : : ., is that right?..the first pin(from top to bottom)is the master, and second one, is the slave and the last is cable select..
Posted on Feb 26, 2008
Beni S-P
  • 1006 Answers
Here you have MANUAL'S
Posted on Mar 24, 2008
msuhelk
  • 106 Answers
SOURCE: slave pin settings
PLACETHE JUMPER IN THE MASTER AT FIRST POSITION AND REMOVE ALL JUMPERS FROM YOUR SLAVE DRIVE IT WILL BE DETECTED AS SLAVE... :-)
Posted on Apr 12, 2008
SOURCE: jumper settings for maxtor
how to setting jumper for external maxtor 80gb model?
Posted on Aug 22, 2008
  • 3 Answers
SOURCE: Master slave jumper settings on 250gb Maxline Plus II SATA
There are no master/slave settings on SATA drives because each drive has its own cable. The drive order is determined by what SATA port they are plugged into, or by the BIOS configuration.
Posted on Sep 04, 2009
I have a maxtor quantum fireball plus as 20.5 hard drive. i want to set it to slave. how do i set the jumpers?
on maxtor drives, you will find the jumper within a cluster of 9 pins. if you look on the bottom of the drive, on the circuit board, the pins should be labeled "ms" "cs" and such. the "ms" and "cs" stand for "master" and "cable select". you rarely use the true "slave" setting anymore, more often than not' "slave" drives are set to "cable select" and are attached to the middle, slave position on the ide cable. in "cable select" mode, the cable decides what device is master and what is slave, depending upon the devices' position on the ide cable.
to set the drive to "slave", set the jumper so that it only has 1 pin under it, and doesnt actually jump any pins, or just take the jumper out. only use the "slave" setting if the "master" device on the same ide cable is actually set to "master".
if the master device is actually set to "cable select" then you will have to set the slave device also to "cable select" and the middle position on the ide cable will set it automatically to be a slave. , instead of using the jumper to make it the "slave".
to set the drive as "cable select", which is what i would recommend, use the jumper to connect the 2 pins which are labeled "cs", the 2nd position from the bottom position on most older maxtor drives, and attach this hard drive to the middle connector of the ide cable.
Nov 25, 2010 | Quantum Fireball Plus AS (QMP20000AS-A)...
I am looking for a user guide for a Black Armor 320 GB Maxtor, ¿can you help?
why would you need one ? Maxtor has a jumper label
on their face that is all the info you'll need to operate
this HDD , the rest is in the OS set up NTFS or
FAT32 , stick with the NTFS and you'll have no
problems , the jumper label indicates using as a
master , Slave or a Cable select , the IDE cable
in your computer if using an ATA HDD has two
connections the top one is the master the lower
one is the slave , if the HDD is a SATA it has its
own special connection which is marked SATA
Jan 19, 2010 | Maxtor Hard Drive
What is the jumper setting for 'Slave' on Maxtor
Look at the picture, I cannot memorize all hardisk jumper but almost all drives have label in it. where you put the jumper for the Cable Select, Master, Slave.
See picture below. Opposite pins has label on it to where you put the jumper.
Oct 24, 2009 | Maxtor DiamondMax 6L160P0 160 GB Hard...
I need jumper settings for maxtor n256 model 96147h6 i wish to run it as a slave pls help. thx
For use as slave there is no jumper connected. (Master on/slave off0
Oct 04, 2009 | Maxtor Hard Drive
Jumper settings for a maxtor N256 master with slave
Select the maxtor HDD as master by setting the Jumper to the extreme left of the hdd; i.e. next to the data cable.
Remove all jumpers from the other HDD which you want to put as slave.
Sep 02, 2009 | Maxtor DiamondMax 80 (96147H6) 61.4 GB...
Setting Maxtor HD as Slave.
Howdy,
First "easy" one I've had in hours....
Just pull the J50 pin out of the jumper block and PRESTO it'll be a slave the OFF position literally reffers to having the J50 pin off of the hard drive. Just a note though, I highly recommend using a peice of scotch tape to affix the pin to a nearby surface cause there a real pain to find if and when you need em again.
Chris,
Armor-IT
Apr 23, 2009 | Maxtor DiamondMax 60 (33073U4) 30.7 GB...
Old maxtor harddrive
Most Maxtor Drives have jumper setting so that if "Jumper 50" is set; the two pins farthest from the power jack, is Master Drive. No pin jumper set, Slave or Cable Select. I hope this helps.
Aug 30, 2008 | Quantum Fireball Plus AS (QMP20000AS-A)...
Maxtor 90845D5 EIDE HDD jumper settings
Connected the 2 pins furthest away from the power connector.
Pin 1
J1 IDE Connector | J2 Power
| .................... || @ * * * || X X X X |
| .......... ......... || @ * * * * || X X X X |
J50 Master/Slave -----+ | | | | | | | +-+12V
J48 Cable Select -------+ | | | | | +---+12V Return
J46 4092 Cyl Limitation---+ | | | +----- +5V Return
J44 Factory Reserved -------+ | +------- +5V
J42 Factory Reserved ---------+
Hope this helps.
Andy
Jun 28, 2008 | Maxtor Hard Drive
Jumper settings
Feb 26, 2008 | Maxtor DiamondMax Plus 6800 (92049U6) 20.4...
Maxtor Hard Drive Logo
115 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
