Question about Jabra BT250 Consumer Headset
Need password I want to pair my headset to my new cell phone and can't find the manual. What is the password t pair the two?
  • Anonymous Nov 23, 2007
    I entered the passwords.. 4 zeros still not working.... what next?
  • nickcoutu Dec 05, 2007
    Changed passkey about a year ago, somehow my Jabra 250 became unpaired. Can't remember my (changed) passkey. Have no instructions. What can I do to reset?
    President:
  • 2,961 Answers
It is 4 zeros 0000
Posted on Oct 08, 2007
Try resetting the headset.  Use the instructions online (http://www.jabra.com/sites/Jabra/GNimages/Products/WirelessHeadset/BT250v/Documents/UM/BT250v_UM_NA_EN_167.pdf) and then see if the default "0000" works as the password.
Posted on Jan 31, 2008
My new phone a Samsung Gusto is not pairing to my Plantronics 233 bluetooth? Is it compatible?
Hi, to be sure if the blue tooth wll be compactible with Samsung Gusto, you will need to use the below instructions first after trying out the instruction and still does not work,that means it's not compactible with it.
instruction:
Read the owners manual for your bluetooth device. You will need to find the code to pair your headset to your phone. This code is usually 0000 (those are zeroes) but verify before you proceed.
Enter your bluetooth option on your cell phone. These can be found in your menu under "bluetooth," "connections," "settings," or something similar.
Turn on your bluetooth headset and put it in pairing mode. Pairing mode means the bluetooth is ready to be found by your cell phone. To pair your headset, follow the owners manual for your specific bluetooth model.
Select "add device" or "search for new device" from your cell phone. Your cell phone will then search for your bluetooth. Once it is found, or discovered, you will need to enter the pairing code (most likely 0000, check your manual to verify).
Select "connect" to finalize the connection if the bluetooth headset didn't connect automatically after the pairing code was entered. Make a test call with your bluetooth in your ear to ensure it is connected properly.
Good luck..
Feb 23, 2011 | Plantronics Explorer 230 Bluetooth Headset
E52 i want pair with my pc i do not know what is the pair password how to do it please clear
Hi, Read the owners manual for your bluetooth device. You will need to find the code to pair your headset to your phone. This code is usually 0000 (those are zeroes) but verify before you proceed.
Feb 13, 2011 | Nokia BH-104 Bluetooth Headset
Trying to add a new bluetooth to a Sony Ericson
Make sure that bluetooth is turned on on your phone and that it is discoverable. Put the bluetooth in pairing mode (usually by holding down the power button for a few seconds), and then tell the phone to "search for new devices". The phone will ask you for a password- it's usually 1234 or 0000, but go by what your bluetooth manual says. That should do it.
Jan 31, 2010 | Ericsson Cell Phones
Lost my manual for my sph-m800 want to hook up bluetooth
turn your headset on and hold the button down until it starts flashing blue and red. go to setting on your phone bluetooth and choose add new device or pair device.
your phone will pik up the new bluetooth and ask for a password it is usually 0000 or 1234
Jun 02, 2009 | Cell Phones
Bh 101 bluetooth headset lost manual and forgot pairing code
Try this: 1. Ensure that your phone is switched on. 2. If the headset has not been previously paired with a device, switch on the headset. The headset enters the pairing mode, and the indicator light starts to flash blue quickly. If the headset has been previously paired with another device, switch off the headset, and press and hold the multifunction key until the indicator light starts to flash blue quickly. 3. Activate the Bluetooth feature on the phone, and set it to search for Bluetooth devices. See the user guide of your phone for instructions. 4. Select the headset from the list of found devices. 5. Enter the passcode 0000 to pair and connect the headset to your phone. In some phones, you may need to make the connection separately after pairing. You only need to pair the headset with your phone once. If pairing is successful, the headset appears in the menu of the mobile phone where you can view the currently paired Bluetooth devices. When the headset is connected with your mobile phone and ready for use, the indicator light of the headset slowly flashes blue.
Apr 14, 2009 | Cell Phones
I lst the instructions for how to program my bluetooth headset h375. I got a new phone and would like to connect it.
pair it, go to u'r fone's bluetooth and find devices and add or pair to your fone... u'r headset has password u'r just going to put it in when the headset ask and phone...gud luck
Apr 26, 2008 | Cell Phones
No connection withe nokia HS-36W bluetooth headset
First check your headset pair with other handsets if ok. your headset is ok. then check your hand set connection is ok.The default password of hs-36w is 0000
Jan 28, 2007 | Nokia 6230
Jabra BT250 Consumer Headset Logo
214 people viewed this question
Top Jabra Radio Communications Experts
Bobby G
Bobby G
Damen Wong
Damen Wong
Jerry Greenberg
Jerry Greenberg
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
