Question about Radio Communications
Bluetooth BH 501 not able to pair windows 8.1
SOURCE: Pairing NOkia BH-207 with Blackberry 8120
Power it off
Press the power on button for at least 10 seconds, until it keep the blue ligth on and then pair it with your BB
Posted on Feb 20, 2009
pshinde23
  • 136 Answers
SOURCE: How To pair Jabra A125s with Nokia BH-604
Turn ON the bluetooth headset (keep the button pressed for few seconds) and bluetooth connection of your Nokia phone. Search for the device from your phone, when found enter the pass key "0000" (its default) when prompted, set this device as authorized to pair it.
Posted on Jul 02, 2009
SOURCE: Nokia BH-213 unable to Pired with Nokia E-63,it stopped suddenly
I also experienced the same problem. After trial and error I realized that the bluetooth device needs to be reset to fix this issue.You may reset the bluetooth device by deleting the pairings from the headset or reseting the headset. Switch off the headset, and press and hold the multifunction key for over 8 seconds. Start pairing the device again. It should work fine now with default passkey 0000
Posted on Jul 19, 2010
  • 4 Answers
SOURCE: trying to pair nokia x6 with nokia BH-214
You have to hold the button down on the headset controller for approximately 6 seconds until the little LED on it flashes blue very quickly. The X6 will see it and match a pair automatically. If you just switch the headset on and the light flashes green the x6 will ask you for a passcode ... it doesn't matter what you put in (it seems) even '0000' ....it won't match the pair. HTH
Reply
Posted on Sep 17, 2010
SOURCE: Bh-105 bluetooth headset not pairing
U must RESET the Headset.
Switch OFF the Headset.
HOLD the answer/end key + power key (for about 5 second).
Red + Green indicators lights start to alternate.
Then Ur Headset is RESET.
Connect / Pair it as normal.
Posted on Jan 08, 2011
Could not connect my Nokia Bh 503 Headset to my windows 8 laptop?
It shows Nokia BH-503 Headset installed in View devices in win8 But it doesn't connect. I tried manually connecting in phones it works by pairing. But doesn't get connected in win8. Can anyone help me solve this?
Dec 17, 2012 | Nokia BH-503 Bluetooth Headset
Need Windows 7 64bit drivers for Bluetiger BH-M20 Bluetooth headset
The driver will be available from the manufacturer. If there is not a 64bit version, it will not work properly. That will be the end of that then.
Jun 18, 2017 | Radio Communications
Nokia bluetooth head set BH-105 can't conect with my nokia C6 mobile
1: SWITCH ON THE BLUETOOTH FUNCTION ON YOUR MOBILE 2: THEN CHANGE MY PHOES VISIBLITY FROM HIDDEN TO SHOWN TO ALL 3; MAKE SURE U HAVE PRESSED THE BLUETOOTH HEADSET SWITCH ON BUTTON FOR AT LEAST 10 SECONDS . 3: U WILL HEAR A BEEP SOUND WHEN THE HEADSET IS SEARCHING FOR PAIRING 4 NOW SEARCH FOR NEW DEVICES ON YOUR MOBILE 5 WHEN THE SEARCH COMPLETES IT WILL SHOW BH-105 6 : SELECT IT AND CLICK PAIR . FINISHED
Jan 26, 2012 | Nokia Bluetooth Headset BH105
I have made connection between nokia BH-503 and my laptop operating windows 7. But after that when i am trying to connect with my nokia x3 mobile and BH-503 the mobile do not able to find the head set.
Try manual connecting. If you have paired your x3 and BH-503 before, you should have your paired devices. So after you connect manually, the headphones should connect to x3 next time automaticly. :)
Nov 29, 2010 | Nokia BH-503 Bluetooth Headset
May 03, 2010 | Nokia Bluetooth-Headset BH-213 2600...
Hi I am unable to pair my nokia bluetooth bh-207 with my nokia 5800 xpress music phome
press and hold the bottom on the bh-207 for about 8 sec you will notace the light remains on, now search for new BT devices whe the phone see it it will ask for passkey enter "0000" and the bh-207 will paiir
Apr 12, 2010 | Nokia 5800 XpressMusic Smartphone
Problem connecting headset via bluetooth on PC
You have to press the button to turn it on and hold the button pressed until it flashes red. Then you go in the control panel , bluetooth options, click it , and then go in the find devices options. When the computer finds the device you have to use the option to put your documentation key and use this default number 0000.
Conclude your installation.
May 04, 2009 | Nokia BH-501 Headset
Bh 101 bluetooth headset lost manual and forgot pairing code
Try this: 1. Ensure that your phone is switched on. 2. If the headset has not been previously paired with a device, switch on the headset. The headset enters the pairing mode, and the indicator light starts to flash blue quickly. If the headset has been previously paired with another device, switch off the headset, and press and hold the multifunction key until the indicator light starts to flash blue quickly. 3. Activate the Bluetooth feature on the phone, and set it to search for Bluetooth devices. See the user guide of your phone for instructions. 4. Select the headset from the list of found devices. 5. Enter the passcode 0000 to pair and connect the headset to your phone. In some phones, you may need to make the connection separately after pairing. You only need to pair the headset with your phone once. If pairing is successful, the headset appears in the menu of the mobile phone where you can view the currently paired Bluetooth devices. When the headset is connected with your mobile phone and ready for use, the indicator light of the headset slowly flashes blue.
Apr 14, 2009 | Cell Phones
Cannot hear music on bluetooth device from PC
Check your sound settings in Control Panel. If your using Win XP, go to Control Panel, than Sound and Audio Devices. Click the Audio tab and make sure, that under Sound Playback the Default Device is set to something with a "Bluetooth". For me it would be "Bluetooth hands-free audio". You might need to re-pair your BH-501 after doing this.
Mar 15, 2009 | Nokia BH-501 Headset
Radio Communications Logo
131 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
