How to get echo effects
Hi, We run a small conference room and use a Inter-M PAM 120 Mixer Amplifier, Public Address Amp to transmit speeches, Is there anyway i could get echo effects on this amp? or how do i go about doing this. I thank you in advance. Regards Koli
  • koli Oct 08, 2007
    try the treble
Try putting the bass down
Posted on Oct 08, 2007
SOURCE:
How do i use the effects loop on peavey xr 600b?
plug the effects out into the input of your reverb/echo unit, plug the out put of the processor into an unused channel in the mixer, do NOT turn up the effects in that channel, to hear the effects in the main use the main level, to hear effects in the monitor use the monitor level. you must turn up the the effect send in the channel you want to hear the effects on and also the effects master.
Jan 23, 2013 | Peavey Xr600b Mixer Amplifier "last One"...
I have a ep4000 amplifier, how can i connect to a mixer
The rule of thumb is you control your audio on the low side. That means you plug your mics, tuners, audio sources into the pre-amp and then the pre-amp into the equalizer/mixer ant finally the mixer into the power amp and the amp into the "large honkin' speakers". The inter connects on the low side (between the source, the mixer and the power amp are usually done with RCA plugs. Use a good quality set of cables to get good tight connections and solid grounding.
AUDIO SOURCE?MIXER?POWER AMP---
heavy speaker wire sized to your SPEAKERS.
Sep 29, 2011 | Behringer EuroPower EP4000 2Channel...
How do you make an echo on this mixer
You will need to buy an effects unit for this, either delay or reverb depending on the echo you want, there are no built-in effects on this mixer, sorry!
Hope this helps!
Jul 07, 2011 | Mackie 1402-vlz3 Compact Mixer - 120v
My husband purchased one of your xr8600 peavey mixer the problem hes having is he cant get the echo settings right.please can you help.
View videos on YouTube regarding "mixer setup". Find the parts of setting up of "effects". Don't worry that you have a different mixer, the principles are all the same for analog mixers. Steps are this: Set the EFX send level for EACH of the input channels (knob above each channel gain) for the proportion you want for each channel. Check that the level you are sending does NOT cause the effect clip light to light very much. Set the effect you want, delay, echo, etc. with the selector knob. Advance the output sent to the power amp with the two knobs in the upper right of the panel. Adjust the "time" knob for the delay or effect depth you want. Then go over the same settings in the same order until you get the sound you want.
Apr 24, 2011 | Peavey Xr 8600 8 Channel Powered Mixer
I have speakers plugged into my phonic powerpod 820 right now but I want also to have the output of the mixer to go through an instrument amp, is this possible? If so, where do I connect the instrument amp...
Yes it's possible. I'm assuming you'd like to use the keyboard amp as a "monitor". In which case, take a 1/4inch TS (instrument cable) jack out of "Aux Send" into the input of your keyboard amp. Make sure the keyboard amp is turned up to a good level and that the Master SEND is turned up on the Desk.
Now you can make your own "monitor mix" for on stage use without effecting the F.O.H mix by turning up the aux pot (knob) on each channel you use.
You can use the CTRL ROOM output also, but make sure it's not giving a "Powered Output" from the internal amplifier in the mixer as you will damage the keyboard amp.
Jan 16, 2011 | Phonic Powerpod 820 / S712 PA Package
I have 2 peavey 2600 amps with 1 pv6 mixer wanting to run subs off 1 amp and sp2s off other amp but only have 1 main output on the pv6 mixer whats my solution
you can run one amp from the main out puts and the second amp from the CTRL Room out puts. The CTRL ROOM are outputs that are linked to the same bus as the master fader. This will work fine...
Best of luck
Sep 02, 2010 | Peavey Pv 2600 Power Amplifier
My powered mixer Behringer is buzzing
Make sure the buzz doesn't happen because of feedback of speakers into mics. When feedback is processed it often goes to a buzz instead of the usual howl.
Also check that you are running adequate inout into the effect since a very low inout will incur digitizing noise and loss of signal=to-noise ratio.
Jun 02, 2010 | Behringer POWERED MIXER, 20 CH, 400 WTS...
Long delay between singing into mic and hearing voice in speakers
Usually delay is associated with "reverb" not echo. If you are in a large room, the room acoustics can add reverb without the benefit of signal processing.
Reverb NORMALLY passes the inout signal as is and then adds in a delayed version on top.
The delay should be less than the room size delay.
Try turning off all effects as a start. There is some "transport" time if it goes through a digital signal processing.
Apr 30, 2010 | Vocopro Da1000pro Professional Digital...
Can You View what the Camera sees through a Computer?
i will connect with microsoft netmeeting just dial in your polycom ip adderss to it and it will connect if you have given private ip address to polycom then connect with private ip if given with public then with public ip adress .
Jul 31, 2008 | Polycom VSX 7000 Video Conference
79 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
