SOURCE: Maytag UXT5230AD Kitchen Hood - Right Hand Light Cycles On and Off
probaby just the bulb holder
SOURCE: Ice maker stopped working
are the "fingers" of the icemaker pointed toward you and slightly up? if not the icemaker is internally broken . is the red light to the right blinking twice and then a one second pause? if not the emmitter is broken. is the black hose coming from the ceiling blocked with ice ? if so the water vave is broken allowing water to seep in hose and freeze. hope this helps.
SOURCE: left power window on 03 chevy silverado quit working
you will need to replace the window regulator. it is the cable operated assembly in the door. it is a very common problem. the dorman number is 741-644 at most parts stores. please rate
SOURCE: no Display on my Samsung 204B monitor
If you know how to open it up and get to the power supply you will find three capacitors 2-820uf and 1-330 @ 25vdc 105o.they will have puffed up tops replace them. FYI the monitor has a 3 year warranty.
SOURCE: what color wires atach to theleft hand 0-31 mth
was able to find the instructions for the swith track
