Question about Homelite 2-Cycle 26 cc Curved Shaft Gas Trimmer UT22600
Trimmer low rpm can not adjust on ut20760 - Homelite 2-Cycle 26 cc Curved Shaft Gas Trimmer UT22600
3 Suggested Answers
#1 Taper
  • 1041 Answers
SOURCE: I have a Homelite gas trimmer model UT20760. It
Check the fuel lines for cracks/breaks. If they are o.k., then:
You will need to disassemble the carburetor and spray with carb.cleaner. Make sure the small screen is free of debris. (Should be able to see daylight through it.) Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152), to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If you need further assistance, just let me know.
Jim
Posted on Jun 19, 2009
#1 Taper
  • 1041 Answers
SOURCE: Need fuel to oil ratio
50:1 2.5oz. of 2 cycle oil to 1 US Gallon of gas.
Jim
Posted on Aug 10, 2011
Ryobi 725r trimmer carburetor adjustment
Turn both low and high adjustment screws carefully clockwise all the way in - do not overtighten.. Then back out each two full turns. Set the idle speed control for highest setting. Prime and start and let it run and warm up for about 15 seconds - then lower the rpms a tad and then adjust the low end screw for highest rpm. Then reset the idle to lower reasonable level. You may have to go back and forth with those two adjustments till it runs fine at low idle speed..
Then accelerate to highest speed and set the high adjustment for highest rpm. Then go from idle to high speed. If not smooth a small adjustment on the high speed screw is in order. Keep doing that until you get a nice smooth transition form low speed to high speed.
Mar 11, 2017 | Ryobi Garden
What tool needed to adjust carb
screwdrivers
low speed adjust (scew in very slowly )untill the fastest idle is obtained.
High speed; Adjust to highest RPM while engine running wide open.
suggest taking line off. I,f while screwing either screw in, the RPM drops, open it (the screw)back up slightly.
Sep 21, 2014 | Garden
What is the proper adjustment for the carburator on the h / l screws
Start with 1-1.5 turn out . Adjust, slowly, high speed first then high speed screw first, screwing until RPM increases then slows open back up, slightly. Do low speed the same way at idle.
Jun 14, 2014 | Troy-Bilt Troy-Built Gas String Trimmer...
Setting the rpm
To identify the idle screw adjustment push in and and out with the gas throttle handle and look at the carburetor for a little finger that moves in unison with your movements. That finger comes to rest against a tapered screw - the latter is the idle adjustment. Clockwise increases the speed and vice versa. Adjust so unit runs smoothly at low speed - too slow and it will stall. Experiment.
Nov 22, 2013 | Craftsman 25cc Gas Line Trimmer
Model ut20760 trimmer engine parts list
Here you go. See page 5 for engine parts. This link has the whole machine.
http://www.odref.com/homelite/string-trimmers/ut-20760-note.PDF
You will need Adobe Reader on your computer to view this parts list.
Apr 19, 2011 | Garden
My Husqvarna 128ld trimmer will run but only at low rpm. I cant find a tool to adjust the carb. If I choke it 1/2 it will run at higher rpm, I suspect a fuel problem. It started in an instant.
If it is a newer trimmer it has a little plastic deal on the adjustment screws to prevent adjusttment.(epa). You have to break that off then a screw driver will work. Some are tough, turn hi speed screw counter clockwise it will rev
Sep 26, 2010 | Husqvarna 28cc Gas Line Trimmer
I need to know the proper gas/oil mixture.
Hello. 40 to 1,or 8oz 2 cycle oil to 2.5 gallon of gas, or 3.2oz of oil to 1 gallon of gas. Joe
Jun 05, 2010 | Homelite Curved Shaft Trimmer Bump Feed...
CLEAND CARB NEED TO KNOW HOW TO ADJUST CARB
Most carbs have the adjustment removed (EPA) but if yours still has the adjusting screws here are the seat of the pants methods:
One Screw Carb: Turn it all the way in and then back out 3-1/2 turns, start the engine and make slight turns in or out until the motor runs smooth from idle to wide open, do not get it too lean, turn in until max RPM is reached then turn out 1/8 turn and go from there.
Two Screw Carb: You adjust the one to remedy either the low or high, high is adjusted until the motor runs smoothly under load at high RPM and the low is adjusted until idle and off idle is smooth.
Feb 27, 2010 | Troy Bilt Tb70ss Gas Trimmer
Homelite 2-Cycle 26 cc Curved Shaft Gas Trimmer UT22600 Logo
54 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
