Question about Sony KDF-E60A20 60 in. LCD HDTV
Screen going black Sony KDF-E60A20
Projection bulb shuting down then coming back on sound also goes out same time too. Thought problem was not enough air flow due to a fan not working but fan was ok. Any help would be helpful.
  • 2 more comments
  • Anonymous Oct 13, 2008
    My tv started turning the screen off, maybe once a week. Now all day long. It will work fine for a few hours then turn off..I get 5 blinks. I can turn it back on and it will work fine for a while and repeat the problem. Is this just an overheating issue?
  • cmage Nov 12, 2008
    I had the exact problem, where the tv lamp shuts off with the sound then comes back by it self after a minute or two. I removed the front cover and cleaned the insde both the buld and the fan and surrounding area. It works for a few days then the issue comes back. I don't see that much dust on the bulb mesh. I am going to try replacing the bulb. I hope this fixes the issue, because the service techs will charge me an arm and a leg.
    Cheers!
  • anthonycrtz Dec 29, 2008
    anthonycrtz, I have the same problem I just cleaned out my lamp like you guy's suggested and I still have the same problem happening do you have eny more suggestions on this problem.
  • kmakatie Feb 23, 2009
    We noticed shortly after we purchased our TV that the screen seemed dark and we couldn't get it to lighten. We lived with it for about a year before the screen would go black and the sound would stop for a minute or two then come back for 20-30 seconds. We pulled the bulb to clean it, but it wasn't dusty. I've just ordered a new bulb.....hope it works.
    Problem Solver:
  • 5 Answers
Remove the lower front panel by removing the 2 large round screw heads at the lower back corners, one on each side. Remove the retaining screw on the right side of the metal horizontal retaining strip in front of the bulb holder, remove bulb retaining screw in the upper left corner of the bulb holder. Pull the bulb holder out towards you and check for dust build up on the top screen on the bulb casing, if there is an abundance of dust it will restrict the airflow across the face of the bulb which causes it to heat up and turn off. Once the dust has been cleaned your bulb should now work as it should without a problem.
Posted on Mar 13, 2008
    Problem Solver:
  • 11 Answers
It works!! First i took off the front panel. Just check your manual for instructions, very easy to do. If you do not have a manual just down load one from google.. The instruction are easy to follow. The screw they have you loosen with a alan wrench is attached to the plastic, so you do not have to worry about dropping it inside the tv. Removing the lamp was simple. once out you will notice on either side are two small mesh screens. One of mine was 80% blocked with dust, the other side was only 30-40% covered. I used a vacuum to remove the blockage, i did not want the dust and dirt to go inside the bulb. i then cleaned all around the lamp. Reinstalled, and we are go to go. The kids are happy and i am happier since my wife not be buying a new TV.
total cost of repair $.00
time required to fix, less than 15 minutes.
Also when my TV was loosing sound and picture and then return. I did turn off my TV, then turned on. I nothiced a red blinking light. Mine flashed 5 times. After some reserch, 5 times is video related, bulb or video board. google red flashing light with the model you have and you will find what all the codes mean.
So if yours is flashing 5 times try the above, it might work for you and it is well worth the time before you call a tech and drops hundreds of dollars.
hope this helps.
Posted on Oct 10, 2008
I just had this exact problem happen to me. I understand the video cutting out with the lamp going off, but why the audio? I am going to clean it out tomorrow,lets see what happens after that.
Posted on Oct 05, 2008
Just had this exact problem with my sony kdf-e60a20. Called tech out to the house to look at it. He replaced the bulb and problem was solved. Save yourself the $440.00 service call and replace the bulb yourself for $200.00. Tech explained it's the tv's way of protecting it self when bulb is going bad. Hope this helps.
Posted on Oct 08, 2007
6ya staff
SOURCE:
Picture goes on for 30 sec. then off for 45 sec.,power/standby lite then blinks.can this be fixed or thrown out.SONY KDF-E50A10
Search Results
    KDF-E50A10 Sony TV - turns off and on - on its own - Sony's ...
    https://community.sony.com/t5/...Picture.../KDF...Sony...off.../442042
    Sep 12, 2014 - Our TV turns off and on without warning on its own. The standby lights starts to blink and the picture and sound go out, then 30 seconds to a ...
    Sony KDF-E60A20 problems - High Def Forum - Your High Definition ...
    www.highdefforum.com > ... > Rear-Projection TVs
    Jan 19, 2009 - 14 posts - ‎11 authors
    I recently got a 60 inch Sony KDF-E60A20 from a friend for around. ... runs for about 1 minutes then goes black(no picture no sounds), then the picture and sound come right back on for another minutes then off for 30 seconds.
Jan 18, 2016 | Televison & Video
Screen and sound problem?
sony 2005 kdf e60a20 tv---turns on and off every 2-3mins...green power lite stays on no blinking
Mar 27, 2010 | Sony KDF-E60A20 60 in. LCD HDTV
Sony 60" Grand Wega has Picture go BLACK and NO SOUNDS!!!
My Sony Wega KDF-55XS955 55" was going on for 1-2 minutes then going black with no sound and after a few minutes would come back on. After reading all the posts and talking with a repair guy I replaced the bulb and that fixed the problem.
Aug 24, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
Screen goes dark, sound goes quiet...
I have a sony KDF-E60A20 projection tv. The picture would go out for about 30 seconds and come back on. It would continue to cycle this way. The green power light would stay on and not flash. The sound would go off when the picture went out and come back on when the picture came back on. I tried taking the bottom cover off the back exposing the fan and blowed it out with a vacuum cleaner, also taking out the bulb and blowing it out. That didn't help. So I ordered a new bulb from Advancedlamps.com and that's what it was. I have now had it on and off for two days and no problems. Cost of lamp was $107.00 including shipping. Good Luck!
May 01, 2009 | Sony KDF-E60A20 60 in. LCD HDTV
I have a Sony TV KDF-E60a20 that keeps going black screened during use. It usually stays black for about 2-3 minutes and then comes back on. It is becoming more frequent.
this is usualy caused by exessive dust on circuit boards ,if the screen goes black and the sound stays on this may be your problem,beware tvs hold charge even when unpluged so would advise taking to shop hope this helps andy
Jun 22, 2008 | Televison & Video
Sony 60' projection model # kdfe60a20
I finally wet out and bought the tv repair manual. Thought the problem had to be more than the bulb because i was losing sound too. Everything in hte repair manual brought me to the bulb or the ballast. I ordered a replacemant bulb. I spent about 150, which included overnight shipping. I replaced the bulb just before Thanksgiving and haven't had any problems as of yet....
Nov 06, 2007 | Sony KDF-E60A20 60 in. LCD HDTV
Projection lamp shuting down
Confirm if this is happening during explosions screenshots or high white tones images. I noticed that my set goes black immediately after an explosion or during commercials (Essurance commercials for example). I'll have a technician tomorrow to replace the power board (another problem), but I'll also show him my observations to get his feedback about the blank screen...will let u know!!!
Aug 27, 2007 | Sony KDF-E60A20 60 in. LCD HDTV
Sony KDF-E60A20 60 in. LCD HDTV Logo
517 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
