Question about Maytag Atlantis MDE7400AY Electric Dryer
Maytag dryer timer issues.
Have a MDE7400AYQ Atlantis model with IntelliDry.S/N 10733087AT. Dryer did not start when pulled "on". Ordered new P/N 33002802. New timer has one less contact blade and will not advance. Original Maytag P/N 6 3721230 does not appear in the search database. What P/N timer should I use? Where can I find it? P.S. Intellidry lights do not work with either Time.
  • 178 Answers
SOURCE: 1999 maytag intellidry gas dryer
The groaning sound seems as if the belt is broaken and the motor is trying to spin a little too fast because it doesn't have a load on it. Take a look to see if the belt is broken and if so, you can purchase a replacement belt at Lowes for approximately $7.00.
Posted on Mar 15, 2008
dmftrucker
  • 1922 Answers
SOURCE: Need help with installing belt in Maytag Electric dryer
if not able to remove rear panel,you will need to start,like most models,take top cover off and hinge back to wall then remove frt cover including door as a whole assy. lift up drum put new belt on drum ( and position in same area as old belt,it will have marks on drum from where original belt was on drum) then put rest of belt over mtr pulley and then idler pulley, turn drum by hand to align belts and put it back together in reverse order
Posted on Jul 28, 2009
  • 278 Answers
SOURCE: intellidry cycles inoperative, regular timed cycle
Howdy: It seems the "smart switch settings" has died. It is in the switching circuit. It all comes in one unit. Take it out and have it tested at an appliance store. Good luck - Doug
Posted on Dec 09, 2009
  • 4088 Answers
SOURCE: Our Maytag Intellidry PYE4558AYW dryer will not turn on
Check the door interlock switch. If it is defective, the machine will not start. If no help, then there may be trouble in the control panel.
Posted on Jan 02, 2010
jumptrout51
  • 3361 Answers
SOURCE: I have a Maytag Atlantis
It would help to know why you replaced the original timer.
Otherwise,you should unplug the dryer,take your wiring diagram and re-check every wire for accuracy.
Take a volt meter after you resume power and start the dryer. Carefully touch the meter leads to the 2 timer wire leads to make sure the timer is getting power.
A bad auto-dry sensor and or a bad control thermostat will stop the timer from advancing.
Posted on Sep 03, 2010
We have a maytag intellidry atlantis gas dryer model #MDG7600 AWQ the timer knob has come off the dryer how can we get this dryer working?
You should be able to purchase a new knob through the website and it is fairly easy to put back on. Check websites such as http://www.appliancepartspros.com/ in addition to the Maytag website
Dec 18, 2011 | Maytag Washing Machines
My Maytag Atlantis Intellidry Dryer won't start unless I move it around
If you have to move the whole machine then I would say you have a bad wire somewhere. If you have to move the timer around then you have a bad timer.
Dec 28, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag Atlantis Dryer pull-knob won't start dryer
sad!! To Say!! It's a bad Timer!!
Maytag went cheap on there Timers!!!!!!!!!!!
I Work on them and have been in a few homes and had to replace them even less then a year old!!!!!!!!!!!!!
Sep 13, 2009 | Maytag Atlantis MDE6400AY Electric Dryer
DRYER WILL NOT STOP
Sounds like the timer motor is bad. You may have to buy a whole timer to get another motor. Save the old timer.
May 01, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Dryer won't start when knob is pulled.
If you push the knob to the left and it makes a good contact and starts the machine, then replace the timer switch. Write down the Name and Model Number of the machine (usually on or below the door)
take it to a local appliance shop and order a new part. When you recieve the new part UNPLUG the machine and remove the three screws from of the top of the electrical compartment and gently pull o the front open, there is only one plug attached to the switch, remove it and dislodge the old switch, then snap the new switch in place and replace the plug, close the compartment and replace the three screws, plug in the dryer, and try it.
Mar 15, 2009 | Maytag Atlantis MDE6400AY Electric Dryer
Only heats on timed drying
Our Kenmore dryer had the same sort of problem (different catchy names.
Problem was that in "smart" modes (by what ever name, the timer motor runs in series with a "dampness" sensor (thermostat, actually, I think) and A RESISTOR.
Resistor burns out--this is the symptom set.
Apr 13, 2008 | Maytag Atlantis MDG7400AW Gas Dryer
Removing Timer Knob on Maytag MDE7400AYW dryer
Can anyone help me? I have a Maytag Atlantis that my parents just gave me and my wife. Unfortunately, they accidently removed the model number sticker in the door area. I need to buy a new timer but no one can find which timer to get without the model number. Via the internet, I think I narrowed it down to either the MDE7400AYQ or the MDE7400AYW....but they both look identical to me. Can anyone tell me what the difference between the two is so I can go get the part?
Mar 03, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag Atlantis MDE7400AY Electric Dryer Logo
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
