Question about Magnavox MDR513H/F7 Player
Does hard reset on Magnavox MDR515H/F7 wipe out hard drive recordings?
Does hard reset erase hard drive?
5 Suggested Answers
Demonic-2011
  • 467 Answers
SOURCE: MDR515h/f7 Dead....Think it is fuse?
You can replace the fuse (if the unit is not under any warranty) by carefully opening the top cover - the fuse is a small glass tube in the power supply (near where the cord connects) check its rating and voltage (the replacement MUST match the original). You should be able to reach this easily without further disassembly of the unit.
If replacing this inexpensive part does not restore any power to your unit, then you have a faulty/defective power supply circuit - this should really be tackled in a fully equipped workshop with adequate facilities by a qualified technician; it is not meant for end-users to repair when it fails due to the potential dangers involved. Experience suggests in many cases a dead unit is not just a blown fuse, but a switchmode power supply failure.
Try replacing the fuse first - then consider submitting unit to a service centre for a quote, then you can decide afterwards if it's economical/worthwhile repairing.
Posted on Mar 21, 2011
SOURCE: 3 month old magnavox mdr515h/f7 is dead. It may be
My unit was dead also.....So I checked outlet first...It was good....Then I tried the 10 minute disconnect and reconnected unit......Saw Unit had power on LCD screen....Hit ON button on remote after changing to HDD and unit works perfectly again....That fix saved me 75 bucks for repair center to do same thing...Glad Funai makes units that shut off before damage occurs...Unit just needed to cool down hard drive or circuitry before it sensed it was ok again....When plugged in it is still technically powered even tho you dont see it on the LCD screen of the unit...
Posted on Nov 04, 2011
ercupa190
  • 12223 Answers
SOURCE: Magnavox MDR515H will not finalize
clean the OPU unit ( objetive LENS ) WITH disk cleaner. and fix it.
otherwise read your instr. manual go to the section troubleshooting
or download your instr. manual www. retrevo.com
If the problem persist you must go to the repair shop TV for fix it.
God bless you
Posted on Oct 01, 2012
swells32
SOURCE: Magnavox mdr515h/f7 will not display video or audio. Was working fine before today.
After reading all the above I took my cover off and found the little fuse. I removed it and it tested ok. I had called Magnavox and they told me there is no fuse or anything like that. I took one last look before throwing it in the trash and there on the circuit board is a little button marked reset. I pushed it and now it works again. So there is both a fuse and a reset button.
Posted on Nov 30, 2012
How connect Magnavox DVDR to Comcast Cable Box ?
You'll need to use the direct input on the rrcorder from the DVR video output.Some channels won't record as they're encoded
Sep 25, 2014 | Magnavox MDR537H/F7 DVD Recorder 1TB Hard...
Magnavox MDR537H/F7 no power
Some surge protectors cut off all power, when they reach the surge protection limit in joules. Power strips have reset buttons to restore power. Try plugging it directly into the electrical wall socket. If it works, then purchase a new surge protector. The DVD recorder may have a internal fuse that has burned open.
Jun 03, 2014 | Magnavox MDR537H/F7 DVD Recorder 1TB Hard...
Magnavox MDR537H/F7 -- DEAD no power
There is usually an internal fuse in all audio/video equipment and it will normally be a 20mm glass one positioned near the power supply or somewher close on the circuit board. There may be more than one so have a good check around. Be sure to replace with the same type and rating, no sticking kitchen foil across it to short it out, this illegal and DANGEROUS.
Need magnavox dvr MDR515H/F7 code for URC WR7 universal remote
Check these codes. To know more, check this link.
0062 0004 0009 0456 0183 0226 0288 0008 0068 0075 0141
Feb 02, 2013 | Televison & Video
Will not finalize disc Error E3 (etc.)
read you instr. manual and see the codes if you do not have it download
www.retrevo.com
God bless you
Sep 30, 2012 | Magnavox MDR515H HDDVD Recorder
God bless you
Feb 25, 2012 | Magnavox MDR515hf7 Player
Mdr515h dosent work
Sounds like you need to do a "Hard Reboot" . . . Unplug the power cord and let it sit overnight, then plug it back in and it should work for you.
Jan 11, 2012 | Magnavox MDR515H HDDVD Recorder
Open Questions:
See all Magnavox MDR513H/F7 Player Questions
Magnavox MDR513H/F7 Player Logo
206 people viewed this question
Top Magnavox Televison & Video Experts
Tom Chichester
Are you a Magnavox Televison and Video Expert? Answer questions, earn points and help others
