Question about Video Game Consoles & Games
Gac 30p pedastal fan, motor is dead
Motor dead
Where is my labcorp in reno , nv. I need the hrs and the locations
890 Mill St Ste 105
Reno, NV 89502
775-334-3562 Monday-Friday 6:30Am-5:30Pm Saturday 7:00Am-1:00Pm **** Screens 10:00A-4:30P Sat **** Scrn 9:00A-12:30P
Apr 22, 2017 | Cars & Trucks
I lost my manual and dont no how to operate my goldair gac 700w cooler
HOW DO I CLEAN THE TANK FROM THE GOLDAIR AIR COOLER (MODEL GAC-700W)
Dec 01, 2013 | Heating & Cooling
Hi, I have an aloha 3 speed oscillating pedastal fan. motor is almost seized. can it be fixed?
What is the estimate rotation rpm at fastest speed ? Normally pedestral fan is a 6 poles or 4 poles single phase motor?
Jun 08, 2012 | Aloha Housewares Dryers
My heater motor stoped turning and blowing but the heat strip kept heating and melted the rotating fan . It is a 20406D7F 077 can I order a whole complete replacement unit
Yes, you probably can. Plus, Dimplex should be made aware of this. Contact Dimplex Technical Service 888-346-7539, Monday -Friday, 8a -4:30p ET. Have the model number, serial number and proof of purchase, handy when you call.
Hope this helps you get the parts you need.
Apr 26, 2011 | ACE Dimplex (r) Compact Electric Fireplace...
I have a HP Pavillion a350n pre 2006/uppgraded 3G of ram, I want to use this computer primarily for gaming, what is the best Video Card to use???
as you already have 3GB ram, you can play most of the gaming now, but to play HD games, you have to buy a good Graphic Accelerator card (GAC), to see few options in GAC , check this link...http://www.gpureview.com/
thanks for rating good luck
Jan 25, 2011 | HP Pavilion a350n PC Desktop
I have a pedastal singing machine that is missing the power cord. Where can i get a replacement?
Nov 08, 2010 | Audio Players & Recorders
How many bolts hold the pedastal to the block on a 1996 f350 turbo charger
there is a total of 4 bolt holding the pedastal to the block and two bolts holding the turbo to thepedastal
Mar 28, 2010 | Ford F-350 Cars & Trucks
Advice on changing 2004 Discovery serpentine belt
Remove the upper fanshroud, it unclips then pull upwards to remove. Remove the fan from the waterpump with a fan wrench. Also becareful not to puncture the radiator. Then remove A/C compressor pulley(some cars have the ACE pump mounted next to A/C compressor which uses the same cover) cover to completely expose the belt routing. Be careful removing the 10mm bolts. They bolt through two pedastals and often fall. So you have to hold the bolt,cover, and pedastals. There's two bolts holding the cover. This next step is important especially if your car is missng the belt diagram. Draw the belt routing on a piece of paper. Then remove beltension at the tensioner. Install belt around all the pulleys in the diagram except the alternator. Use the same step to install belt on alternator pulley which is always the last pulley to fit belt onto. Then reverse procedure and tighten all bolts.
Sep 12, 2009 | 2004 Land Rover Discovery
How remove files from c:\windows assembly (Windows Vista)
REM Remove GAC Entries
gacutil /u Oracle.DataAccess
gacutil /u Policy.9.2.Oracle.DataAccess
gacutil /u Policy.10.1.Oracle.DataAccess
gacutil /u Policy.10.2.Oracle.DataAccess
The gacutil comes with .NET 2.0 SDK
Jun 11, 2009 | Computers & Internet
Video Game Consoles & Games Logo
29 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
