Question about Jenn-Air JSD2695KES Side by Side Refrigerator
Freezer coils frozen fridge frozen - Jenn-Air JSD2695KES Side by Side Refrigerator
Rm4400 freezer working fridge not
move temp sensor that's mounted in coils down or let hang if same replace sensor
Jan 19, 2014 | Dometic Refrigerators
Cant Get fridge and freezer to cool to correct temp
According to the picture posted the freezer defrost is stuck on. Why it would not get cold enough. Contact a local appliance repairman and get professional help as this should require control board repair/replace.
Jan 02, 2014 | Refrigerators
Frozen solid freezer, warm refrigerator. (model Amana bottom freezer abb1922few) Can see frost on freezer foods and back vents (almost occluded). Just vacuumed wads of dog hair/dust off of front half of...
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Aug 27, 2010 | Refrigerators
FREEZER WORKING BUT FRIDGE NOT
Remove the rear panel in the freezer and see if the evaporator coils are frozen over.
If so dethaw coils with a hair dryer.
Reassemble freezer and set controls to the normal position.
Although you replaced the defrost timer if the coils were frozen over in the freezer no air can transfer to the ref. section from the freezer.
If you do not want to dethaw the coils unplug the ref. for 1-2 days and leave the doors open .The coils will dethaw by then.
Jan 17, 2010 | Kenmore Refrigerators
American fridge/freezer - fridge stopped cooling, freezer side ok
Have you pulled out the refrigerator and cleaned or used a vacum cleaner to get out the dirt and dust off the back of the coils, or if the coils are underneath, you need to get an inexpensive appliance brush for fridge, and clean the coils under the fridge, pull off the panel on the front bottom of the fridge, get a flash light and look to see if the coils are covered in dust....may just need to vacum and use appliance brush underneath...this should be done at least one a year, you will notice your fridge running much better and cooling back to normal.......hope this helps......
Jan 05, 2010 | Refrigerators
I left my freezer door open by accident on a beko cda540w fridge freezer freezer defrosted now when i turn the fridge back on it does not seem to freeze and the fridge stays warm i can here the fridge...
you may need to manually defrost the evaporator coil. If condensation built up from the door being left open, it may have frozen the coil solid. At that point even the evaporator defrost bar won't be able to remove the ice. Remove the cover, if it is frozen solid, unplug the unit and use a hair dryer to defrost the ice.
Nov 13, 2009 | Refrigerators
FRIDGE NOT COLD FREEZER WORKS FINE
Make sure the freezer fan motor is running. Remove the rear panel in the freezer and check for frozen coils. If coils are frozen replace the defrost heater and thermostat.
Check the air vents to the fresh food section,are they frozen closed?
Jul 17, 2009 | Hotpoint HTS16HBMWW / HTS16HBMAA Top...
GE TFX26KRDA WW 2001 side by side refrig/freezer w warm fridge
Cleaned the condenser coils which were dusty but not severely so. Checked the evaporator coils which were NOT iced. Reset the fridge to coldest setting and freezer to #5 (mid range of temperature) and waited a full 36 hours. Fridge temp is 40 F and freezer is about 0F. Not sure what is different except coldest setting on fridge. Warm weather is here but not warm enough to require AC. Temps in late afternoon in house about 77-80F. Any thoughts are appreciated because I suspect this problem is not completely resolved.
Jun 20, 2009 | GE Hotpoint Top-Freezer Refrigerator
The coils are frozen solid in freezer behind back wall
frozen coils not always means freon problem. low air flow across evaporator coils could cause freeze up. if door is opened and closed an abnormal amount could cause a freeze up or even something pushed up against the air intake in the refridgerator. i would thaw it out completely and restart it, theres a chance it was nothing major. good luck
Jan 12, 2009 | Hotpoint HTS20GCNWW / HTS20GCNCC Top...
Hi, I have a Beko fridge freezer. It was delivered flat and when plugged in 24 hours later the freezer seems ok but, the fridge is not cooling the light is on. It's a second hand fridge. Thanks
hi. thanks for the question . Check , the freezer fan motor, to see if its ok. check the coils at the back, and fan at the back . if all ok. check behind the freezer wall to see if all coils are frosting up .If all te coils are not frozen you have a faulty compressor .thanks the appliance doc
Oct 01, 2008 | Refrigerators
Jenn-Air JSD2695KES Side by Side Refrigerator Logo
16 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
