Splitting a 80 gig hdd into 2 sections
I have an 80 gig hdd. The C:/ hdd has about 5 gig, and the G:/split has 75 gig. How do I orginise to change the C:/ into 60 gig and the G:/ into 20 gig? Thank You
    Genius:
  • 1,139 Answers
Hello douglasc, You will have to repartition your hard drive. I would suggest the use of an application called partition magic. It will allow you to partition your hard drive even though the OS is present on the system. It does this by first defragmenting your hard drive and the putting the unused sectors together and the used sectors together this way it makes the division of the sections easier. Now once the hard drive is defragmented it allows you to section the drive into different logical hard drives. Follow the instructions from the documentation and you will have a successful repartitioning. Thank you, Shuttle83
Posted on Oct 08, 2007
SOURCE:
Aircondition builds ice on coil
Either lack of refrigerant, stopped up metering device or capillary tube/s, or lack of air flow (due to bad blower motor, or dirty indoor coil) Good luck.
May 19, 2014 | Rheem Complete Split System Gas Furnace 5...
Tip
PS3 models, and what they can do
The 20 Gig
Pros
Full PS2 Compatibility
HDMI Port
Pretty good Cooling System
4 USB Ports
£220
Cons
Super Small HDD
No Wireless Card
Discontinued (They don't make them any more)
The 40 Gig
Pros
£250
HDMI Port
Built in Wireless
Medium HDD
Amazing, New Cooling System
Cons
2 USB Ports
Cannot play PS2 Games
The 60 Gig
Pros
SD Card Slots
4 USB Ports
Built In Wireless
Big HDD
HDMI Port
£280
Cons
The *OLD* 80 Gig
Pros
Massive HDD
4 USB Ports
Limited PS2 Compatibility
SD Card Slots
HDMI Port
£280
Cons
The *NEW* 80 Gig
Pros
Massive HDD
£250
HDMI Port
Built in Wireless
Cons
NO PS2 Compatibility
The 160 Gig
Pros
Mammoth HDD
HDMI Port
Built in Wireless
Cons
£350
on Jan 18, 2010 | Video Game Consoles & Games
My old 40 gig ps3 died, so we bought an 80 gig, but when 40 gig hdd is inserted in place of 80 gig hdd, it wont accept the hdd, and i had 9 months worth of saved games on 40 gig hdd. how do i get game...
Unfortunetly the HDD's can't be swapped like that. The only way to get the old stuff is to some how get the 40gb working so you can back up your system. Tell me what happend to the 40 and I might be able to help you get it up long enough to back it up so you can get all your stuff transfered. Another way is if you can get the 40gb machine to work the PS3 has a mode to hook a CAT5 cable from the new to the old and transfer that way.
A little more on the HDD swap. The HDD's are machine spacific and can only be recognized by the machine they were in and any other PS3 you try to put them in won't recognize the device without a format will saddly enough wipe the drive clean.
Let me know what's wrong with the 40 and I will see if I can help getting it back up so you can get your saved stuff off of it.
Sep 25, 2011 | Sony PlayStation® 3 (80GB) Console
80 gig maxtor not reconized in computer bios cmos
check the cable & more better way use duel usb cable which occupy 2 usb & i Normal Hdd connector
Dec 05, 2009 | Maxtor Personal Storage 3100 (M01B080) 80...
Need to increase size of split hard drive
I would say the best way is to compress your files on your selected drive by going to my computer right clicking on the drive that you want to increase the capacity, click properties, then the tools tab. U should be able to defrag, compress from there. But I am pretty possitibe that the 15 gig drive is for backup of files for your computer incase the bigger drive crashes.
Apr 24, 2009 | Sony Computers & Internet
External hard disk
the Hatachi 80 gig looks the same as the 120 gig verbatum 47558
also had the same blue flashing light and no recognition by XP
I open the case and removed the drive from the pc board. cleaned the contacts and reconected the PC board , the fault was oxidisation
May 30, 2008 | Computers & Internet
No booting
The problem is Operating systems are co-dependent on hardware.
If the motherboards, processors, ram, video adapters, etc don't match you would not be able to swap hard drives and expect to boot.
You could try pressing F8 on boot and try to access safemode.
If it does boot into safemode immediately it will want to reactivate windows.(because of all the hardware changes.
If it still can't boot, you may want to put the 80 gig in as slave to the 40gig and ghost the 40 gg hard drive over to the 80.
If you don't want to lose your data on the 80 gig then reboot with an xppro cd and reinstall windows in the same partition overlaying the installation on top of existing windows directory.
the new windows will have to be activated but all data will still be there.
Apr 15, 2008 | HP PSC 2210 All-In-One InkJet Printer
PS2 HDD Partition Error
A Partition error is the amount of segments that the hard-drive is split into.
For example we have 1 hard-drive Named C:/ Which Is 20 gigabytes. Then we decide that we want to use A Quarter of that drive, solely for saving games On. So 5 gigabytes Will Now Be allocated For Game-saves, This Will be known as Partition 2 Or D:/ So we now have 2 Partitions 1 is C:/ And 1 Is D:/ Partition C:/ is Currently 15 Gigabytes, And Partition D:/ is 5 Gigabytes.
Making a total Of 20 Gigabytes. So if your getting a partition error, it,s either because the game your attempting to transfer Is larger than the Partition, thats trying to receive it. You may be sending 4 gig to a 3.5 gig partition. Or your attempting to send it to a partition that is incorrect or inadequately lettered/numbered.
I hope this enables you to understand, the basics of Partitions on drives.
Mike @ Compurepair.
Mar 04, 2008 | Sony PlayStation 2 (PS2) Console
Screen split into 2 colours - vertical split
I think it is degaussing problem if any thing is lying which has magnet please remove it. &then put of monitor for 15 minutes & then put on again.do not move when it is on. please let me if it gets ok good luck
Sep 09, 2007 | Philips 170B4MG 17" LCD Monitor
53 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
