Question about Jwin JL-707 Clock Radio
Projection getting dim - Jwin JL-707 Clock Radio
I have a sony 52 inch wegagate dlp ty that has a dim picture what could be the problem?
If its a Sony and a DLP a lot of times just before the lamp life ends it gives a darker or dim picture---if it gets dim enough set will shut down.
Nov 06, 2012 | Hitachi 50UX57B 50" Rear Projection...
Epson powerlite 84 dim projection dim projection
check them :
The lens
the lcd panels
the polarizer
May 18, 2012 | Epson Corporati PROJECTOR, EPSON,...
HITACHI 53FDX01BA THE PICTURE IS GETTING DIM. ALL THE COLORS LOOK GOOD EVERYTHING IS JUST GETTING DIM
This is a common problem on this Hitachi model. You can get the parts and repair instructions from www.TvRepairKits.com. In most cases the TV will look real dim or have no video...but audio will work,
Jul 18, 2011 | Hitachi 53FDX01B 53" Rear Projection...
Screen is dim. Have brightness turned up to max setting. Does the lamp get dim with age? Mitsubishi WD-Y577 dlp rear projection tv
Yes... from the moment the lamp is put into service, it begins to deminish in brightness. You should order a replacement lamp to have on hand.
Mar 15, 2010 | Mitsubishi WD-Y577 Television
Magnaovox rear projection tv has too much red in the picture and it is blurry
Sounds like a coolant issue with the CRTs. Look into the lens of the green and blue CRTs and you should see what looks like bacteria if the coolant nees replacement. Usually the green and blue get contaminated which dims them and makes the red become dominate and the picture will get dim and out of focus.
Jan 22, 2010 | Philips Magnavox 51MP392H Rear Projection...
Very Dim Picture on Sony KP-61s70
Have you had the projectors dusted? They'll acculate a lot over the years and you'll notice some dimming as time goes by.
Sep 21, 2009 | Sony KP-61S70 61" Rear Projection...
The TV brightness dims when the we get a dim scene
This is probably normal and called "Dynamic Contrast". Maybe this company has some other proprietary naming.
Basically, the Backlight (LCD) or Bulb (Projection) will be dimmed during dark scenes to allow the TV to make a deeper black.
Apr 26, 2009 | Televison & Video
HCL4715W Rear projection "Red" color is dim
screen adjustment,remove front bottom cove and find the focus block the screens are also on the same block,if your not sure don't try.
Aug 28, 2007 | Samsung HCL4715W 47" Rear Projection...
Projection TV is Dimming...Getting darker with every hour its on
hi rouge. my name is mike wilson. i have a panasonic 50 in that has the same problem as you had on your tv. the screen got halfway dark today. did you ever get yours fixed, if so, would you mind telling me what the problem was? my problem is listed (by mistake as a 53 in) on 04/04/07. thanks in advance
Dec 03, 2006 | Panasonic PT-56HX40 56" Rear Projection...
Jwin JL-707 Clock Radio Logo
Top Jwin Audio Players & Recorders Experts
 Grubhead
Grubhead
Oloyede Monsuru
Are you a Jwin Audio Player and Recorder Expert? Answer questions, earn points and help others
