Question about B&K Plumbing
I have a b&k (mueller maybe) tub faucet that is leaking in the wall (slow drip) and I want to replace the seals and springs and ball inside...(does any other brand of repair parts also work for this brand of faucet? I have a lowes store nearby but do not see the b&k brand repair parts. It is a single lever faucet and is leaking just behind the collar which is behind the screw on chrome dome.
    Master:
  • 586 Answers
My advice: With a pipe wrench, SLOWLY remove the faucet. Pitch it. It's done. Clean the pipe with a wire brush - especially the threads, wipe them off with a wet cloth. Before all this you will have to choose a new faucet which will fit the pipe. When it's dry and you have the new faucet, wrap the pipe with teflon tape IN A CLOCKWISE DIRECTION FRONT TO REAR. Screw on the new faucet until it is is the proper position. Wait 30 min. and check for leaks. Good luck!
Posted on Sep 18, 2017
blueextc3221
  • 15935 Answers
SOURCE: my price pfister tub valve leaks
there is an o-ring inside the valve that seals. It has failed. They should sell a rebuild kit where you bought it, or dis-assemble, and take the failed oring in to have it matched to a new one.
Posted on Dec 26, 2008
  • 14 Answers
SOURCE: Leaking tub spout single handle volumne/thermostat
See if you can give me a head on picture.
From the top it looks like it could be a Kohler or Grohe.
Thanks,
sanray
Posted on Dec 28, 2008
  • 297 Answers
SOURCE: kohler shower diverter leaks (behind the wall)
if you have a closet behind the shower or a wall you may be able to get to the diverter without damage to the tile ,are you sure you can't just change the cartridge? most times this is all that is needed to fix a problem like yours.
Posted on Jul 24, 2009
  • 12866 Answers
SOURCE: Water leaks from around the stem when I lift the
ur cartridge needs service or replacement u can turn off water supply remove lever and retaining nuts pull up cartridge and inspect the o rings for debris and or damage if good inspect cartridge for damage if looks check gaskets/o-rings in stem for same add a little vasline around o-rings and reinstall test for leak if leaking still replace all o-rings or if cartridge order and replace
Posted on Nov 04, 2009
Testimonial: "thank you so much."
SOURCE: I have a Moen single
I have had the cartridge replaced in my moen single handle faucet with sprayer in the end and now it turns off by itself. Any suggestions on the problem
Posted on Aug 19, 2010
My Delta 16997-sssd drips how can I fix it
there are either springs and seals that need replaced or a cartridge
Jan 24, 2018 | Plumbing
How repair leak classic delta tub faucet
Change the seats and springs. If it is single handle, replace the ball too.
May 21, 2014 | Water Pik WATERPIK SHOWER HEAD COMBO PACK...
I have a vintage clawfoot tub with a mueller taps (one for hot and one for cold) and a single needle like faucet. There is a constant drip, which seems to be coming from the cold water tap. I have no idea...
if it is more than one turn it will be a washer
if it is 1/4 or 1/2 turn , it will be ceramic insert
replacement of either is a simple process but if in doubt get in a plumber
Nov 01, 2017 | B&K BK Mueller 122048RP Single Lev Kitchen...
Fix b & K leak tub faucet
I think some super glue would work in my opinion
Jun 03, 2012 | B&K BK Mueller 122048RP Single Lev Kitchen...
How do i stop a slow drip in a tub faucet?
A drip is caused by seepage from the water supply. Remember the water supply enters your home under pressure, so there must be a watertight seal holding back the incoming water when the faucet handle is in the OFF position. That seal is usually created by a washer pressed tightly against the faucet seat. Obviously, when the washer or the seat is not functioning properly, a little water can seep through and drip out of the faucet spout. To stop the drip, all you usually have to do is replace the washer or repair the seat.
Jun 01, 2012 | Home
HOW DO I INSTALL A SEAL KIT
A metal ball controls the temperature and flow of water from the spout in the vast majority of Delta single-lever faucets. That ball rests on three rubber seals, each seal suspending the ball with a single spring. Over time, wear on the seals, the springs and even the ball itself typically results in leaks. Thankfully, repairing the faucet is relatively simple, and Delta even makes repair kits with the replacement parts needed for each model.
Turn off the valve that controls the main water supply. The valve is located next to the water meter, inside or outside the house, and must be twisted in a clockwise direction.
Remove the plastic cap from the center of the faucet's handle by prying the cap free with the blade of a dull knife or a flat-head screwdriver, then remove the screw in the center of the faucet handle with a Phillips-head screwdriver. Pull the handle off the faucet assembly to remove it
  • Remove the single bonnet nut that surrounds the faucet valve with an adjustable wrench. Grip the bonnet nut at the base, which is ribbed to give the wrench a surface to grasp, and turn in a counterclockwise direction to remove it.
  • Remove the circular, white plastic cam that surrounds the top of the faucet, pulling it off and revealing a rubber seal, which you also remove. Next, pull the metal ball out of the faucet assembly and pry out the ball's supporting rubber seals and their springs with a screwdriver (the springs slide onto the bottom of each seal, so they will come out along with the seals).
  • Slide one replacement spring onto each of the three replacement seals that come with the Delta repair kit for your faucet model, then insert each seal into the assembly. Insert the replacement ball from the repair kit, then cap it by putting the replacement rubber seal over the ball, followed by the plastic cam
  • Place the bonnet nut over the faucet valve, then tighten the nut with an adjustable wrench. Position the handle onto the end of the faucet, then insert a screw into the center of the handle, tighten it with a Phillips-head screwdriver and, finally, press the decorative plastic cap over the screw.
  • Turn on the valve that controls the main water supply by twisting the valve in a counterclockwise direction to complete the repair
  • Jan 28, 2011 | Delta & Single Handle Shower Faucet
    Delta Faucet Company 467-SSSD-DST Palo Diamond Seal Technology Pull-out Kitchen Faucet, Stainless, 3 years old and is beginning to drip unless we position the handle just right. Is there a washer? I've...
    I hope this will help please go to this web site for a downloadable parts link. If it is leaking from the spout replace the seats and springs to correct the problem. Turn water off and remove handle with a 1/8" allen wrench and remove retaining collar to access the ball assembly to remove the seats and springs.
    The parts page on this link will give you a break down and hope this will help.
    http://www.deltafaucet.com/kitchen/details/467-SSSD-DST.html
    Dec 30, 2010 | Delta Faucet Delta 467-SSSD-DST Palo...
    Delta single lever faucet leakingafter bing shut off.
    Will need to get delta faucet rebuild kit. Available at home depot, lowes or hardware store. It consists of valve stem seals & springs. The larger kit will contain ball assembly. Turn off water to faucet. Unscrew handle via set screw under plastic cap. Unthread cap over ball assembly. Pry out valve seals & springs. Reverse procedure to install.
    Jun 26, 2010 | Delta & Single Handle Shower Faucet
    My Delta Faucet Leaks
    Check that we were looking at same parts diagram, but I would say RP-70 Ball assy., as well as RP-4993 Seats & springs . If it's only dripping, just seats and spring will usually get you by, but if they are sending parts, free of charge, or ball assy., isn't too expensive, I'd change it too. I have had some luck with removing ball assy, cleaning it well with fine steel wool, then removing seals, and springs, stretching spring slightly, to add more pressure to seal, clean seal, then dab on a little vaseline to seals, and re-assemble.
    Jan 06, 2010 | Delta Model 470: Signature Kitchen...
    To turn faucet handles off
    Re seat the tap and replace the washer with a half ball round washer , will close easier.
    May 24, 2009 | Plumbing
    Plumbing Logo
    392 people viewed this question
    Top B&K Plumbing Experts
    Tom Chichester
    Bill Boyd
    Daryl Gleaton
    Are you a B&K Plumbing Expert? Answer questions, earn points and help others
