Question about Wireless Ground LG Optimus G E970 Flexible Gel Skin Case - Black
Half bottom of my phone screen doesn't work
Half the bottom of my screen doesn't work and I can't remove my battery
Screen doesn't work
Try turning the phone off and remove the battery. Wait about 30 seconds or so and put the battery back in and turn it on. This is one way to reset phones or devices with removable batteries.
Sep 18, 2012 | T-Mobile HTC MyTouch 3G Slide...
My screen on the lg vx5500 cell phone is making strange shapes. When the phone starts up, the bottom half of the screen shows what should be on the top, and the top half is just a white screen. When I...
Your problem is caused by the communication foil between the LCD and the mainboard of the phone. This foil contains a number of circuits that makes data transfer possible. The one or more circuits do not communicate anymore, the phone displays odd images.
Nov 07, 2010 | LG VX5500 Cell Phone
LG VX5300 Flip Phone broke in half.
Your phone can work again, all you need to do is to get the flexi cable and fix it back in place.
It is not expensive.
It is about $15.
To fix this, these are the processes to follow;
  1. Get the appropriate screwdriver,
  2. Turn your phone over so the battery cover is facing you. Remove the battery cover and battery.
  3. Next remove the 2 rubber stoppers and unscrew the aerial.
  4. Remove the 6 screws,
  5. Next remove the 2 rubber stoppers & screws above the main screen,
  6. Prise the back part away from the rest of the phone by running your fingernail between where the two parts meet,
  7. Unclip the ribbon,
  8. After removing the ribbon cable, carefully lift the metal part that is beneath the phone. Another ribbon will be attached which should be carefully removed.
  9. Take the circuit board & keypad out and you'll be left with what's below it.
  10. Next remove the top part of the phone by pushing the housing in whilst pulling the hinge, which the top part is attached via, away from the phone. This is the hardest part and you'll need to bend and manipulate the housing the get the hinge out. Be firm but be careful so you don't snap the housing.
  11. To open the top half of the phone and get to the screen, run your fingernail between where the two parts of the housing meets,
  12. Try to open up the top part by splitting it open with a credit card,
  13. replace the ribbon and,
  14. Reverse the procedure for reassembly and it's finished.
Take care
Jun 21, 2010 | LG VX5300 Cellular Phone
How do you remove the battery cover for the compartment under the phone? I've tried sliding, lifting, etc., but it doesn't budge.
On the back of the phone bottom half, push down where it meets the top half and at the same time push (slide) it down away from the top half. It's very tough but it will work.
Oct 08, 2009 | GE 27980 Cordless Phone
The touch screen on mym phone wont work its jst not working all together it just stoped
hi friend,
  • Issue – Bottom half of iPhone touch screen does not work.
    Solution - Standard troubleshooting steps in order are power the iPhone off and on, Reset, Restore from backup, Restore as a new iPhone or not from backup and if no change after any or all, call Apple Care – (800) 694-7466 or make an appointment at an Apple Store to have this checked if there is one nearby.
  • Issue - iPhone “touch screen” dead.
    Solution - Connect your phone to iTunes and do a full restore, it will replace all information on your phone prior to your last syn. If it doesn’t help call Apple Care – (800) 694-7466.
  • Issue - The top half of my iPhone screen is not working at all
    Solution - If restore doesn’t work – you could schedule online an appointment with a genius at an Apple store
    http://www.apple.com/retail/
  • Issue – My screen cracked. How much would it cost to get it replaced?
    Solution - Terrible situation but Apple doesn’t warranty the glass. This would be a minimum of $250 to get fixed out of your pocket.
Hope one of the solution helps…
thank u for using fixya
please rate me..............
regards
sivaranjini
Sep 12, 2009 | Samsung Tocco F480 - Pay Monthly Cellular...
Samsung tocco touch screen not working
The software of the phone must have gone corrupt. Take it to the authorized person and may also have to change your scren curcuit or the whole software.
Aug 14, 2009 | Samsung Cell Phones
Screen is not readable- thinking it's the battery
Have you tried to adjust the contrast on your display? If that doesn't help chances are its your battery.
how to change battery:
Remove the battery compartment door, the bottom half of the back, should slide down.
Disconnect the cord attached to the battery pack and remove the battery pack from the handset.
Insert the new battery pack and connect the cord to the jack inside the battery compartment.
Put the battery compartment door back on.
Jun 18, 2009 | Uniden Cordless Phone
Front screen only shows the time
I have had a simular problem with mine and just fixed it. My phone was doing simular things, but it would also sometimes not show the outside display, or half would be upsite down. Also occasionally when I opened the phone I only saw a white screen. **FIX** There is a small ribbon cable that comes from the top half (w/ the screen) and connects into the circuit board in the bottom half (under battery). It came loose which caused all of my problems. If you clean that connection and put the phone back together it should be good as new.
Jun 25, 2007 | Motorola Mobility RAZR V3
Wireless Ground LG Optimus G E970 Flexible Gel Skin Case - Black Logo
213 people viewed this question
Top Wireless Ground Car Audio & Video Experts
xxxxxx xxx
Are you a Wireless Ground Car Audio and Video Expert? Answer questions, earn points and help others
