Question about Epson Stylus CX4200 All-In-One InkJet Printer
Won't Print My black ink is full, colors are empty. I'm trying to print a black and white document but it still won't let me. It says "communication error" when I try cleaning the heads. It also says "information not available" when I try to check the supply levels, unless I go through utility>open printer utility>status monitor>continue. I don't know if they're connected, but either way it won't let me print anything. Advice?
    Problem Solver:
  • 28 Answers
IF THE COLOUR INK IS EMPTY THE ERROR LED TURN ON AND THE PRINTER IS OFFLINE.YOU HAVE TO CHANGE THE COLOUR INK CARTRIDGE
Posted on Nov 20, 2013
  • 624 Answers
SOURCE: Black ink print failure after cartridge replaced
The Edge, -Clean the electrical contacts on the printer where the cartridge connects with alcohol. After it dries clean the same contacts with a regular pink, non-abrasive pencil eraser making sure you remove all the debris when done. -Its also possible there is an air bubble preventing the flow of ink. You can try inserting a full cartridge of ink in the printer and letting it sit overnight then running a nozzle clean job or two. Another alternative if you have a syringe you may want to try gently forcing ink into it. If you?re really desperate you can try drilling a small hole into the cartridge to give gravity feeding a hand. BE WARNED the air hole will let ink flow pretty well and you run the chance of making a mess. Before you pull the cartridge out of the printer make sure you cover the hole with tape so the ink doesn?t make even more mess. -Check the cartridge alignment making sure the contacts are mating to the printer. -If it still doesn?t work I would try cleaning your nozzles. Even though I doubt you have clogged nozzles its worth a try because of the following: If you search the Internet you?ll find that this specific model is know for failing to print some or all colors after about 1 ½ to 2 years of use, even with Epson inks. Most of the posts I?ve seen blame it on clogged nozzles but I suspect a good number of them, like yours, have another explanation for their failure. Ink jet printers use resistors to create heat to create a bubble in the ink to eject it out of the nozzle (Bubble jet) or in the case of Epson, vibrating crystals push ink into and out of the nozzles (piezoelectric). We?ve already cleaned the electrical contacts and cleaned the nozzles so what remain are defective nozzles, short between the nozzle and the controller board or a defective controller board. Since the printer is only worth 1 or 2 hundred dollars repairs at a shop or buying these repair parts can easily exceed ½ its cost. Hope something here works for you, I just recently had to toss a great printer too. Let us know what happens and please don?t forget to rate the posting.
Posted on Jan 20, 2007
SOURCE: can check ink levels on epson r800 or cx4200
I just off the phone with Epson and one problem with Leopard is that it uses Apple's drivers for printing instead of Epson's.  I couldn't print directly to CD because of that.
To see if that's your issue, go into system setting -> printers & faxes and then select the Epson printer from the menu.  On the right, it will give information about your printer including KIND.  If it has your printer name followed by GUTENBERG, that means it discarded the epson drivers in favor of the Leopard ones.
You have to delete that printer (hit the minus button while it is highlighted).  He then had me go to Macintosh HD-> Library->Printers and delete the entire Epson folder to prevent it from automatically reloading... this may be overkill, but...
Next, REBOOT.
Then go to Epson.com and download the latest mac drivers for your printer and install them.  Go back to System Prefs->Printers and Faxes and click on the + button to add a printer.
When I did this it, my r1800 came up, but it had a drop down menu to choose the KIND and it still had the Gutenberg option, but it now had 'EPSON SP 1800'-the actual epson drivers.  I chose that option and now it works flawlessly and I can again print to CD.
Posted on Jan 17, 2008
eagle338
  • 4889 Answers
SOURCE: R200 will not print black color
Sounds like maybe the chips on the cartridges aren't making proper contact. Have you tried removing the black cartridge and reinserting?
How long did it take you to replace all the color cartridges? If it sat uncapped for very long, the black may simply be clogged. Often a few drops of Windex with Ammonia D (not the lemony stuff!) on the purge/park pad will do it.
With the lid up turn it on, and as soon as the heads are unparked pull the plug. Very gently, slide the print head out of the way. With an eyedropper, put a few drops of Windex with Ammonia D on the park pad, enough to make it obviously damp but not overflowing. If it is all gummed up, you'll need to clean it. In that case look here for more detailed instructions:
http://www.polyphoto.com/tutorials/PrintHeadCleaning/
My printer cleaning site is kind of rough, I wrote answers to others and got tired of retyping and just saved a few.
If the park pad is not all gummed up, then gently slide the print head all the way back over the park pad. As you do, the park pad automatically comes up under the print head so don't worry about it drying out. Leave it for a few hours or overnight before plugging it in and turning it on again, then run a cleaning cycle and try a nozzle check.
Never run more than 3 cleaning cycles in a row without printing -something-, even if it is just a nozzle check. And never -ever- move the print head manually while the printer is plugged in.
Posted on Nov 06, 2008
pagebor
  • 2785 Answers
SOURCE: Won't print with only 1 cartridge empty
sorry you can print unless all your cartridge are having some ink
Posted on Dec 17, 2008
tigertail
  • 163 Answers
SOURCE: epson stylus C88 won t print color ink black is
If you have carried out 4 to 5 head cleans, waited about 8 hours and done another 3 or head cleans doing nozzle checks after each clean (as recommended by the manual) and there is still no improvement then you will need a third party head cleaning solution such as this one:
http://websites.uk-plc.net/UK_Inkjet_Cartridges_PLUS/products/Print_Head_Cleaner.htm
Other makes & brands are available just google "inkjet head cleaning solution" Hope this helps.
Posted on Apr 03, 2009
The printer's lying to me
The printer requires both cartridges to have ink before the printer will initialize and operational. Even if you are only printing black and white both cartridge have to contain ink or the printer will error out. This is standard on all ink jet printers from every manufacturer. You will have to get ink before you can print.
Apr 28, 2013 | Canon Pixma MX410 All-In-One Printer
I have a Lexmark Pinnacle Pro 901 printer and its set up to print using black ink only, but it keeps telling to replace color cartridges and it won't let me print at all, how do I print using blac
The printer would need all cartridges to have sufficient ink levels to continue printing - that's to prevent damaging the printhead. Every time a cartridge is replaced, all colors are primed simultaneously thus the need for all cartridges to have ink.
To save on your ink investment, try printing in draft mode and by making sure that your printing preferences is set to print using black ink only.
Oct 25, 2012 | Lexmark Pinnacle Pro901 All-in-one Inkjet...
I have enough black ink to print a few pages in black, but the printer won't print. What do I do?
I had a Epson printer that would not print or even allow me to use the scanner because the colored ink was out. Even though I had full black ink, it still would not let me print until i replaced the colored ink.
Sep 25, 2012 | Lexmark 90T6005 Prospect Pro205 All-in-One...
How to turn off color ink in Epson Stylus R300
There is a place in the printer driver (epson part) that hays checkboxes for "color" and "Black & White". If you are trying to do this becasue you are out of one or more of the color inks, and can't print- you still won't be able to until you replace the empty ink(s), even though you told it black & White
Aug 30, 2012 | Epson Office Equipment & Supplies
The printer won't print. It says replace the color ink cartridge. All I want to do is print black and white.
You can only use the black ink cartridge without the color ink. But no need to replace them in your printer.
When you print just choose black and white for the printed text must be black not colored. But if you still received such notification...just try to replace the color ink cartridge to continue printing
Note: As per my experience. printer with exclusive black ink alone will damage the printer easily due to unbalance printing of ink
Sep 20, 2011 | HP OfficeJet 6210 All-In-One InkJet...
I have to print a word document in black. Because I have no yellow ink, the printer won't print anything. I have tried everything and just want to print a simple one page document and I have plenty of...
here's a solution i came across when dealing with the same problem. apparently the printer expects all of the cartridges to be full and has a sensor to make sure they are even when only printing black. hope this helps!
http://journal.drfaulken.com/trick-your-brother-inkjet-into-working-when-an-ink-cartridge-runs-dry/
Jul 13, 2011 | Brother MFC 490cw Color Inkjet...
Dec 17, 2008 | Epson Stylus Color 740 InkJet Printer
When I print, only the color cartridge is used. I'm printing documents that are all black and white. How do I print with the black cartridge? I have a full black cartridge, but my printer won't let me...
if your document only black and white , the machine only use black ink, no going withdraw the color ink. but you have had to leaved the full color ink in the machine.
Dec 09, 2008 | Lexmark X2600 InkJet Printer
Wont print
some printers share the ink from color to black but you can select if you wants to use only black just go to printer than properies than select to use only black but you probably have to remove the empty color one
Dec 18, 2007 | HP DeskJet 3940 InkJet Photo Printer
Epson Stylus CX4200 All-In-One InkJet Printer Logo
110 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
