Question about Home
Need schematic for advanced industries board #116220-d
Location of vertical output or schematic
You did not post the model of the set. That is normally required for information but as a follow up you should get a magnification lens and closely inspect all the joints. It is also very unusual to burn a trace on a pcb without knowing it. The boards on older items are tough and resilient to that. Not withstanding though is the fact that if you used a soldering iron that was too hot, it will cause the foil to come off the board. The industry standard for schematics is here: https://www.samswebsite.com/photofacts.html and you have to pay for them.
Apr 07, 2014 | Sylvania Televison & Video
Need circuit diagram for 2033001
this is a highly advanced motor with multiple inputs giving it its variable speed capability. Schematic wont help. Sorry. Motor shot or main board shot. Both expensive
Feb 10, 2014 | GE 1/2 Hp Ecm Blower Motor Hd44ae121...
I need a schematic of the motherboard in my gateway m275 tablet laptop
Gateway M275 System Board
  • Includes Pentium M 1.4 GHz, 1.5 GHz, 1.6 GHz, or 1.7 GHz 1 MB cache CPU.
  • Two 200-pin industry standard DDR-SODIMM sockets
  • Up to 2 GB system memory
  • UMA shared video memory
Jul 06, 2011 | Computers & Internet
Power supply data spec psf 168 212 replaced bad fuse still no power
Never will get any schematics to any tvs.Tvs corporations,don't release it to the publics.Only to it authorize shops,related to it section devision have schematics and designs of the related to that products.Shelf doer,must have to trouble shoots and experience by fixing it or in the tvs industries before.Power supply board problems are the most common to LCD,Plama tvs are leaking gases capacitors.Check the power supply board for those capacitors for bulges up onto it tops or puffing up onto it tops,these capacitors are dead or dying,that why the tv have flashing power LED light indication or no LED light up at all.Replaced these dying or dead capacitors.Tries Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Jul 31, 2010 | RCA L26W11 26 in. HD-Ready LCD Television
Need a schematic diagram
I'd love to help, but without the make amd model, there is little I can do. Please update this with that info.
Also, just in case the schematic isnot available, please list the circuit designations of the parts that are burnt. These are the numbers listed under or next to the parts on the circuit board.
Thanks,
Dan
Apr 22, 2009 | Audio Players & Recorders
Schematic and parts location
check ac coming in, then go to the rectifier and check for dc volts on the plus and minus, check voltage at 25 volt 10,0000 uf cap should have voltage present. check positive solder joint at the cap and print board.
the mosfet guy
Jun 03, 2008 | Bose Wave Radio
Sony drs-11
I have 2 of these units and have not seen a schematic in either manual
Apr 18, 2008 | Sony DSR-11 DV / Mini DV VCR
Home Logo
128 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
