Question about OKI Pacemark 4410 Matrix Printer
Abnormal printing with continuous tone
Hi, my oki microline 4410 printer prints at times on its own when no document is sent to it:it gives a continuos tone and prints odd characters.i switched it of for an hour and when i switched it back on it was ok but when it was idle fo some time in started printing on its own again with the same continous sound.My oki printer uses parallel port cable...pls i need a solution to this problem
Your problem is either a bad parallel cable(maybe just loose) , or the printer port is is sending out noise. These units tend to do what they are told...and something is telling it to print these characters. Try pulling the cable off and see if it ever prints anything.
Posted on Dec 11, 2007
  • 64 Answers
This sounds like it is doing something called a "hex dump" basicaly printing all ASCII characters. okis tend to do this from time to time if l;eft on for a significant period with no data sent to it. the only advice given by oki is to switch it off when not using it unfortunatly Hope this helps Cops Pete@wedotoners.com
Posted on Oct 08, 2007
Can we print Courier New font with print quality UTL: Utility in OKI3320 printer
the printer normally prints the font set in the computer as it replicates the document
Mar 30, 2015 | OKI MICROLINE 3320 Matrix Printer
Oki microline 320 form feed
Am afraid the Power Surge (when the power came back on) has damaged the unit and there is no "Reset" to these printers. You would need to replace the control board but as its a power surge there is a reasonable chance that the power supply will have been damaged/weakened and this will lead to a shortened life span of the printer. I would throw it away and replace with new. sorry, ( I am not a salesman either)
Jul 18, 2017 | OKI MICROLINE 321 Turbo Matrix Printer
Oki 321 turbo in PPR emulation mode, does a form
Generally the form feed character is sent by your software. Try setting the page length in the printer setup to be the length of one label.
Sep 28, 2009 | OKI MICROLINE 321 Turbo Matrix Printer
OKI DATA MICROLINE 320 TURBO PRINTER PROBLEM
Hi Charles,
Use the IBM proprinter driver for this printer and select IBM in the menu of the printer.
Hope this helps.
Dezzi
Sep 10, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
Oki microline 280 feeds paper continiously after a file print, and won't stop till i pull power cable
First, reinstall the driver and be sure it's the correct driver for this printer. If you drive a word document does it do the same? If not, chanses are the db application is constantly sending form feeds to the printer and the printer will do whatever it's told to do. Try a different printer setup in the db application.
Aug 27, 2008 | OKI MICROLINE 280 Elite Matrix Printer
Oki Microline 320 Turbo page alignment
This sounds like a problem in the computer program that is sending the prints to the printers....especially since it is happening in several of them.
Jan 23, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
OKI MICROLINE 591
You need to set and store paper size, width etc in printers internal menu and on print driver on pc.
See Oki manual for printer settings its written on the front of the machine i think menu and set power on, then print to see settings then read manual...
Jan 04, 2008 | OKI MICROLINE 591 Matrix Printer
Font size
You can change the dfont size from the menu, but that setting afects the entire page of print. You different size fonts are controled from the codes sent to the printer from the software. Recreate the document, or create a document with a sample of that small print and see if the printer prints it.
Dec 04, 2007 | OKI MicroLine 420 Matrix Printer
OKI Pacemark 4410 doesn't print it correct spots for some forms
I found the service manual for this, which should come in really handy for you when performing maintenance on your printer (which is most likely what you need to do to the printer) http://www.feedroller.com/Store/Service%20Manual/SER4410.PDF Funny thing is that there are a lot of people trying to sell these manuals, so I'd save this one for future use (it might not be on this link for long)
Mar 29, 2007 | OKI Pacemark 4410 Matrix Printer
OKI Pacemark 4410 Matrix Printer Logo
193 people viewed this question
Top OKI Office Equipment & Supplies Experts
Steve Allison
Steve Allison
Clive
Clive
Timothy Van Der...
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
