Question about FAIP Vertical Shaft Pump MTPV90480
Need check valves for MTPV 90480 Faip pump - FAIP Vertical Shaft Pump MTPV90480
Water won't go through pressure washer, even with the water on and the pressure hose off the machine, no water comes through the pressure washer.
Back behind the water outlet tube are components that have small orifices that become clogged from lime, clay, mud and other contaminants. Mud and clay mostly from well water. I've had over 60 pressure washers in the past three years. I bought them because they didn't work and I would repair the pumps unless they were cracked, then I would buy new pumps to install. It would help to know the pump model details or even the make. Faip, Himore, Annovi Reverberi etc...or even the pressure washer model number as long as it is the original pump. If it is an Annovi Reverberi then it could also be a bad shutter valve. Now there is a revised design of the shutter valve. The part number for that valve is AR42497.
May 20, 2015 | Garden
What will couse the pump not to build pressure
To many things to list.
i recommend giving our free tech support person ell a call when you can be at the washer and they can walk thru the process of diagnosing it.
1-888-279-9274
Oct 21, 2014 | FAIP Vertical Shaft Pump MTPV93501
Location of pump oil input valve
Hi
Im surprised that this model pump has a oil refill. Most pumps of this size arent refillable. This looks to be a pump made by FAIP. Its an ok pump but I would recommend using it until it fails and then replace with an AR RMW pump. Much easier to get parts for. Here is a diagram of your pump...The oil refill plug is on the side of the pump...that is located under your engine. You want to get the recommended oil for your pump. Most pump oils are 30 weight non-detergent but these small pumps take an oil specific to only them. So follow your specs...your diagram is here http www searspartsdirect com Craftsman Power washer Parts Model 580752330...
and your manual is here 580752330 CRAFTSMAN PRESSURE WASHER Manual
Hope this helps
Sep 20, 2014 | Craftsman Garden
How to set a high pressure unloader valve on a FAIP 1500 H120 washer
Are you talking about the electric switch that shuts off the motor when the trigger is released?
If so, there is an arm that comes out of the high pressure side of the manifold and is connected to a spring loaded piston. The piston extends under high pressure (spray trigger released) and retracts when spraying. At the opposite end of the arm is an allen screw and locknut. The allen screw bears on the microswitch arm to control the electric motor. When properly adjusted, the motor should turn off when the trigger is released. If it doesn't, loosen the locknut and adjust the allen screw slightly outwards toward the switch. Pull the trigger a few times and verify the motor starts up and shuts down when you release it. Tighten locknut.
Hope that helps.
Jul 11, 2014 | FAIP 1500 PSI Electric Power Washer
Power washer not spraying hard
Hi Mike
You could have one are two problems with the pressure washer.
1...pump for pressure washer worn and needs washer/seal replacement.
2...Need to adjust the pressure discharge relief valve to the needed pressure.
Please take time to rate me
Bud
Mar 28, 2013 | FAIP Powerwasher Universal Pressure Washer...
I need a user manual for FAIP-1500 Pressure Washer
Is this the one?
http://www.power-washer.us/images/stories/manuals/H150.pdf
Oct 23, 2012 | FAIP 1500 PSI Electric Power Washer
What type of oil is used to fill the a FAIP PV93501 pump and what quanity.
I don't know about that brand of power washer.
We used several types of power washers over the years, and they each called for 20 or 30 weight non-detergent oil in the pump. SAE 20 or SAE 30
The pump oil comes about half way up inside the pump.
The engine oil is 10W30
Do not turn a power washer on its side or upside down or oil will run into carburetor.
Oct 14, 2010 | FAIP 2100psi 2gpm Faip Power Pressure...
Where can I get seal rings and o rings for my pressure washer pump without buying an entire seal kit? Faip 193490.
Alot of people have tried doing this as the genuine o-ring and seal kits are so expensive and sometimes hard to source, but many companies make orings and seals that are unique and cannot be found aftermarket,
If you are lucky you may find some but the only way of doing so would be to take the actual seal and orings down to your local bearing and seal supplier and they will measure it up and do their best to find some for you...
Regards
Brad
Dec 17, 2009 | FAIP Garden
I have a pressure washer with a faip 3 piston pump. the other day i was using it and it stopped unloading. i cleaned the unloader and it didn't help. I bought a new one and it still won't work. I e-mailed...
I think your main problem is that the unloader valve needs to be lubricated. Use the very best water resistant bearing grease you can find. If you can e-mail me a pic of your unloader assembly I can try to explain how to set it up. firehead@roges.com
Sep 14, 2009 | Honda Garden
FAIP Vertical Shaft Pump MTPV90480 Logo
97 people viewed this question
Top FAIP Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a FAIP Garden Expert? Answer questions, earn points and help others
