Question about Tablets & eReaders
Making my DVD/CD-ROM drive multi-regional
To whom it may concern I want to make the DVD/CD-ROM drive on my laptop multi-regional. There does not seem to be information on-line relating to the model I own. Please help. Paul.
  • vollin Oct 08, 2007
    The model is TEAC DV-W28EC. (Although entered in the field, it didn't appear in the posted message.)
    Paul.
    Problem Solver:
  • 11 Answers
This is not possible without a 3rd party utility.
You can buy such a utility (AnyDVD) from http://www.slysoft.com/en/
Posted on Apr 28, 2009
SOURCE:
Toshiba 3505 not booting from usb cd rom
OK, Do 1 thing, start pc press del go in side of BIOS.
Set the 1st booting drive as USB CD ROM. and save that. then restart your system.
Jan 30, 2010 | Toshiba Portege 3505 Tablet PC
I have compaq 738 tu laptop. ''my computer'' is not showing cd-dvd drive in my laptop. how can i resolve my problem?
If you have formatted your laptop without backup then it will not show CD-DVD drive
1) Please update the drivers.
2) Please get the data cable checked, it can also be the problem, in most of the cases data cable melts and disconnects the CD-DVD drive from the system.
Sep 04, 2009 | Tablets & eReaders
Reset bios
There's no need to reset your BIOS, only you do is to set in your BIOS Setup to boot priority like for example First Boot Priority is your CD/DVD Rom Drive, if you got some Bootable System Disc then the Second Boot Priority is your Hard Disk Drive. Good luck!
Jul 26, 2009 | Compaq tc4200 Tablet PC
Missing boot manager
go to system bios (using F10 key on the start "Commanly") then press F9 for restore defaults, and insert the Bootable Vista DVD into the drive, it will solve your prob.. otherwise in bios mode make sure that all the drives (HDD & CD/DVD Rom) are properly installed.
good luck
shafky
Jun 19, 2009 | Tablets & eReaders
CD DVD drives
try antoher cd-rom to see whether it's the optical drive or the pc>>>
May 25, 2009 | Tablets & eReaders
Install new os on motion le 1600
You can use an external USB drive, either CD or DVD dependent on your OS media.
I used a Phillips drive, with external power supply, to restore to factory settings using their restore CDs. I also installed Windows Vista Ultimate from DVD, without issues :)
Mar 30, 2009 | Motion Computing M1400 CENTRINO 1.1G 512...
Boot up problem
NOTE: Ususally when computers DO NOT find any startup information on the SELECTED DRIVE (like when you click a key) it goes to the default drive.
WHICH IS YOUR HARD DRIVE.
Meaning it is probably your Harddrive is broken, or your connection from hard drive to motherboard is broken
Burn a Live CD bootdisk of some linux distribution
liek Slax, google it.
Burn it to a bootable CD and put it into your drive, then select to boot from it.
If it boots only using your CD ROM drive, if that works then its probably not your BIOS/rest of computer, which is good.
And while in the live cd, you can see your harddrive and see files, that means its not broken its just your connection to it....either way im guessing youll have to send it in.
Jan 10, 2009 | Toshiba Portege R100 Tablet PC
Disk error
Does the laptop have a usable cd/dvd rom drive?
May 13, 2008 | Toshiba Portege 3505 Tablet PC
Bootable cd / dvd
one possible way around is to copy the entire cd (make a new folder named "CD COPY" or similar) to your hard drive (assuming you have enough space...about 800 Mb), then run the install from setup.exe from the hard drive, then delete the copy (to make room) when you are done.
Mar 24, 2008 | Toshiba Portege M205-S810 Tablet PC
Cannot Load Windows/Windows Setup Does Not Detect Hardrive
Harddrive is most likely bad get another and install windiws... if you found the right place they could "ghost" your information onto the new one!
Feb 01, 2008 | Compaq tc4400 Tablet PC (RL875AW#ABA)
Tablets & eReaders Logo
213 people viewed this question
Top Tablets & eReaders Experts
Marvin
Marvin
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
