Question about Dryers
NVL333 Hotpoint Dryer (2002)
I am a senior lady, 97 lbs and need to replace this dryer. Can you tell me if it gas or electric? I can't see behind it. Thanks for the answer to this silly question. Patricia
  • 11 Answers
SOURCE: hooking an electrical dryer to a breaker
You will typically need a 40 amp 220V circuit for this ( check with local building inspectors).  You will need to run some hefty wire probably #8 three wire  (again check) and install the type of plug receptacle that is on the  dryer cord.
Inside the breaker box you will need a dual breaker 220V breaker rated at 40 amps.  The wire coming into the breaker box will need to be clamped in place with appropriately sized wire cable clamp where the enter the box through a knockout- available at any hardware store.
Now the big question-  why are you switching to electrical?  Gas is pretty much half as expensive as electricy  and will dry the clothes faster (usually gas dryers generate more heat than electrical ones).   Just wondering..
Posted on Oct 21, 2007
Amigaman
  • 248 Answers
SOURCE: Gas dryer is not heating up
Could be a bad set of burner coils. Does the glow come on for a bit then goes out. And after a bit does same?
Probably bad coils. If you were able to change ignitor, you can do the coils. Unplug first! The coils are the 2 black cylinder shaped devices on burner. They are held on with a bracket that has 2 phillips screws. You can probably take them to your parts house and they can ohm them out for you. Make sure to write down their position before removing them.
Posted on Nov 07, 2007
Amigaman
  • 248 Answers
SOURCE: Hotpoint dryer NLL113-NVL333
This is often caused by the front bearing assembly.
Posted on Nov 08, 2007
jumptrout51
  • 3361 Answers
SOURCE: Hotpoint Electric Dryer Model NBXR453EVOWW squealing when turned
Replace the drum support bearing at the rear of the drum.
Posted on Jun 11, 2009
SOURCE: ge hotpoint dryer nvl333 very noisy. Drum is
No, there are shims that the drum most likely sit on that need replacing. I had the same problem with mine. It made a horrid sound before the fix. You will have to go to an appliance repair shop to get the shims or you can order them online.
Posted on Dec 06, 2009
Is it gas or electric?
Your post lists it as a "Hotpoint TDC32 Electric Dryer"...that tells me it is electric. Where did you get the information to post this? That would confirm for you.
Nov 20, 2013 | Hotpoint TDC32 Electric Dryer
Dryer not getting hot hotpoint dryer model#dlb2650bslwh
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Mar 28, 2011 | Hotpoint Dryers
My hotpoint dryer spins but does not get hot. What is wrong?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 21, 2010 | Hotpoint NWSR483GBWW Gas Dryer
Hotpoint dryer will not heat still tumbling but not heating what is the cause
heatman101
Sep 27, 2010 | Hotpoint NVL333EY Electric Dryer
Hotpoint wd420 washer dryer dryer is not heating up
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Mar 07, 2010 | Hotpoint Ariston Aquarius WD420 Front Load...
Heats up slightly hotpoint condenser TDC32
heatman101
e76jy
Feb 18, 2010 | Hotpoint TDC32 Electric Dryer
Ge hotpoint dryer nvl333 very noisy. Drum is rubbing. Other than that it works great. Is this a big expensive fix?
Dec 06, 2009 | Hotpoint NVL333GY Gas Dryer
Hi my dryer just quit heating up ?its a hotpoint any ideas
heatman101
34yt
Nov 21, 2009 | Hotpoint NBXR463GBWW Gas Dryer
Kenmore Dryer Model 417.80042990 problem
Could be just that. Thin coins like that can get into the drum baffles (those 3 "vanes" inside the drum that lift the clothes). It's a simple matter to open the top, remove the baffle(s) and clean them out.
Dec 29, 2007 | Frigidaire FEQ332E Electric Dryer
Nov 07, 2007 | Hotpoint TDC32 Electric Dryer
Dryers Logo
16 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
