Question about Proform iLog 750 Treadmill
Light Does Not Work On Display Weslo G-40
Does The G-40 Have Batteries For Display?
Console does not or light up on weslo lx15
adjust the REED switch, see the diagram attached.
Tight the ribbon cable and clean it. inside from display board. Tight and clean the upper+lower connector very well.
3) replace the old batteries( if you system have it) and put a new ones.
God bless you5af4d81e-1cdd-4727-aa39-d0fbf60d1aee.gifa1b4fbb5-ba42-4e49-90f8-b9255d027dbc.gif
Oct 15, 2013 | Exercise & Fitness
My console doesn't work at all on weslo lx15
adjust the REED switch tight the connector, and clean it. see the diagram attached.
2) tight the ribbon cable and clean it inside the display board. tight and clean it the upper +lower connectors.
3) replace old batteries( if your system have it) put a new ones, clean the contacts batteries.
God bless youa493a90c-7dda-4398-b16b-db46bc3a2567.gifae2b83f7-8ce7-478b-b27b-877ee04d3c9b.gif
Oct 15, 2013 | Weslo Cadence Lx15 Treadmill Walking Deck
Weslo g-40 won't come on
see the videos and LUBE the deck belt +rollers bearing .
Feb 04, 2013 | Weslo Cadence G-40 Folding Treadmill Sale
The reset button is on reset, the elect outlet has electricity. Put the treatmill together according to booklet directions. Panel displays 0's but the start, stop, nor any of the numbers work....
adjust the reed swtich, see the diagram attached,clean it, and tight very well the connector
2) replace the batteries and clean the contacts battery very well.
God bless you
Nov 11, 2012 | Weslo Cadence G 5.9 Treadmill
Where do I change the batteries for the weslo pursuit e45?
normally the batteries is under the compartment from display board underneath. see the instr.manual download from www. fitness.manualsonline.com or www.weslo.com
God bless you
Jul 12, 2012 | Exercise & Fitness
Weslo cadence g-40 display comes on but treadmill dosent move
Dear SIR:
Attached the reed switch diagram adjust it, clean very well and tigh the wires
After That RUN the software calibration for easy diagnose and troubleshooting.
See my personal TIPS FOR HELP
sincerely. God bless you
Apr 12, 2012 | Weslo Cadence Ct 5.8 Treadmill
My weslo momentum 7.0 ex elliptical machine display stopped working. It won't power on even with new batteries.
Removethe bolts or screws securing the console to the upright assembly. Lift theconsole and confirm that the cable connections are secure. Remove the coverfrom the console's battery bay and install a fresh set of batteries. Replacethe battery cover.2
Detachthe ends of the pedals from the crank axles. Remove the left and right discshields and side shields. Inspect the interior of the base unit and locate theflywheel.3
Inspectthe flywheel as it turns. Locate the magnet installed on the flywheel. Turn theflywheel until the magnet passes in front of the nearby reed switch. Loosen thescrew securing the switch in place. Rotate the switch to reduce the gap betweenit and the magnet. Tighten the screw.4
Replacethe left and right disc shields and side shields. Reattach the ends of the pedalsto the crank axles.
ernesto cuadramanagua, nicaragua
Mar 07, 2012 | Exercise & Fitness
I have a weslo cadence 200 cs treadmill. I changed the batteries but the display keeps blinking 0
You probably need a new treadmill display screen but one thing you can try is to get a 6 volt power suppply and use the power supply instead of the batteries.
May 20, 2010 | Exercise & Fitness
Proform iLog 750 Treadmill Logo
18 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
