Question about ASUS Tablets & eReaders
Asus authentication problem - ASUS Tablets & eReaders
MY POLOROID TABLET WILL NOT STAY CONNECTED TO INTERNET. SAYS AUTHENTICATION PROBLEMS
Android tablet wifi authentication problem [Solved ...
www.tomshardware.com/.../43704-43-android-ta...
Tom's Hardware Guide
Nov 23, 2012 - 20 posts - ‎9 authors
Hello, every wireless device works except my new tablet from Acer running Android 4.1.1. ... Yes, I try to connect to the network router. ... You can hide the SSID - once your Android has it as a saved network it will ... gefraenk said: ... Hello all, I have the same authentication problem, worse, I m not sure what ...
Authentication Problem to Connect Android Tablet - YouTube
? 3:05
https://www.youtube.com/watch?v=2wul81jM7Ts
Apr 2, 2013 - Uploaded by Meroy Diniz
If you have Authentication Problem connecting you androidtablet. ... i got a different problem i cant even turn the wifi on, on my hudl 2 it blocked ...
Dec 25, 2015 | Tablets & eReaders
I have bought a new asus memo 7 and i cannot connect it my wifi, it keeps saying authenticating problem
The issue isn't with the tablet, it is something in your Wifi...there are a number of things that it could be, try simply rebooting your router, that would be the easiest thing to try. If that doesn't work, try switching your tablet to "airplane mode" , and then try to connect...
Oct 08, 2014 | ASUS 16GB MeMO Pad 7" Tablet Cherry Pink
How do I unlock have Athentication proble can not connect to Google
So, did you forget your lock screen password? You will probably need to do a factory reset.
Sep 20, 2014 | ASUS Google Nexus 7 8GB Tablet Unlocked...
Trouble with authentication
Authentication means the password is wrong.
May 07, 2014 | Acer Iconia A3-A10 10.1" Android Tablet -...
Authentication problem
trying dumbing down the authentication on your wifi router. Try these:
turn off 40mhz wide channels
try wpa instead of wpa2
try tkip instead of aes
if all else fails, try wep.
Feb 11, 2014 | Craig CMP741d Tablet
Help for nexus 7 tablet
Are you trying to connect the Nexus to the internet via your computer? using ad-hoc wifi connection?
I followed these instructions and was able to make the connection.
Hope it helps.
Dan
Sep 05, 2012 | ASUS Google Nexus 7 8GB Tablet Unlocked...
Authentication problem connecting to wifi
Can't get unit to connect to my home wifi , keeps giving message Authentication Problem
May 12, 2012 | Polaroid Tablet Computer PMID701
Tablets & eReaders Logo
18 people viewed this question
Top ASUS Tablets & eReaders Experts
k24674
Are you an ASUS Tablet and eReader Expert? Answer questions, earn points and help others
