Channels missing Hi we have a ZINWELL-ZMX-75000 Freeview box & we lost the Signal so i reset it but now wer cant get TV1 or TV2 & Prime can u hlop please
chrispurs1
  • 372 Answers
SOURCE: setting up my freeview box- NO CHANNELS FOUND
Hi.
The cable & wireless system is not capable of picking up the digital freeview frequencies.
Idealy you need to put a new aerial on the roof,
If this is not possible try an indoor aerial that you to plug in to the mains electrical supply.
http://dysonmanuals.inc.io/
Chris..
Posted on Dec 12, 2007
  • 2336 Answers
SOURCE: Remote Sensor Problem
Given that both remotes work with TV2, more likely the IR sensor on TV1 is defective.
The problem could also be in the microprocessor itself as well.
Posted on Feb 17, 2008
SOURCE: Lost ITV channels and C4
I have the same problem, can anybody help?
Posted on Jul 08, 2008
rapanSF
  • 150 Answers
SOURCE: game systems
Try channel buttons on TV, if it doesn't work then you'll need a cheap universal remote control.
Posted on Dec 21, 2008
SOURCE: problem jumps back and froth from tv1 to tv2
One of the inputs on the back of the 322 box is bad. usaly 1 wire runs from the dish into a seperator that splits the signal into 2 at the back of the box. you will need to call dish and have a new 322 sent out. 1-888-333-3474
Posted on Apr 25, 2009
Which device button on a signalex 10 in 1 remote control do I press to set a freeview box
Signalex Universal Remote - instructions? ' AVForums
www.avforums.com > ... > Remote Controls
I have the instructions for this model URC22B (SK012) 15-in-1, if you can ... hi jeff,i need to control a goodmans tv, model no 295ns, hope u can help me, ... Press and hold button "SET" and press selected equipment button (ie TV1, .... iv just bought a poundland signalex universal remote which wont pick up my freeview box.
signalex 10-1 poundland remote simplified instructions ' eBay
www.ebay.co.uk > ... > Remote Controls
eBayTo Set Code Find your TV model (or other appliance) code; then you press and holdbutton "SET" and press selected equipment button (ie TV1, TV2, AUX, ...
Dec 21, 2015 | Televison & Video
Dual control noted on Dish tv screen but cannot change stations separately on both tvs
Each TV receiver has to be fed with a separate cable from the lnb. They can not be bridges or split.
Mar 09, 2015 | Dish Network/Pansat Dish Network Dish 500...
Dish remote 2 changes channels on both tvs and dish remote 1 changes channels on both tvs
Is the receiver in dual mode? Go to the receiver, open the door, and hit the mode key. If both TVs are still showing the same thing, then the issue is not the mode.
Go to TV 2 (the one without the receiver) and make sure the TV is tuned to channel 60 or 73. If it is still showing the same thing, go to TV1 (the one with the receiver) and hit Menu, system setup, Installation, modulation (menu 6-1-5). make sure the modulation for tv2 matches which channel you put your tv2 on.
Still showing the same thing? check the back of the receiver, the RCA cables (red/white/yellow) are plugged into the TV1 ports not the TV2 ports.
Showing different things but the remote still changes channels on both tvs? Go to TV1, hit menu twice, near the bottom there are two boxes each with a number. This is the address for each remote (tv1 and tv2). On the TV2 remote hold sat until it stays lit, choose a number different than on the screen, touch pound (#), the sat light blinks three times, hit record, the number on the screen should change to match the one you typed in.
Still being silly? Call a priest, you have a poltergeist!
Oct 24, 2013 | DISH Network IR Remote Control
I turned the living room tv on this morning and it is black and white and says no signal. The other tvs are working fine. I have turned it off and turned it back on still nothing
Hi my name is Mike Houston of DISH Network and I see youturned on the living room TV and it was black & white and had no signal.Depending if it's a Dual receiver and if the issue is TV1 or TV2 but there issome thing's you can check to make sure it is on the right channel. I will sendyou two links to help with the setup for both TV1 and TV2, if you have anymorequestions or concerns please e-mail me back at Michael.houston@dishnetwork.com;http://www.dishnetwork.com/SupportSection/bbs-screenand http://www.dishnetwork.com/SupportSection/black-blue-tv2.
Sep 04, 2011 | DISH Network 322 DTV Receiver
When I change the channel on tv2, it also changes the channel on tv1. I have changed the address for tv2's remote, but it still changes tv1's channel.
Hi my nameis Mike Houston of DISH Network and I see your TV2 changes TV1 as well, thereis an easy fix to this problem. You will want to make sure the receiver is inDual Mode and then make sure the TV2 connection on the back of the receiver isin the right port. I will send a link to help with these steps, http://www.dishnetwork.com/SupportSection/same-video-2-tvs.I will leave my e-mail if you have any questions Michael.houston@dishnetwork.com.
May 22, 2011 | DISH Network DVR-625 DTV Receiver /...
I have a Dish receiver 322. TV1 is set on channel 3 and TV2 is set on channel 116. Everything worked. We moved the receiver and TV1 into another room (right next door to where it was). We triple checked...
Hi hartbettinaI see where your TV2 has a blue screen, there are a couple of things you can doyou can do. The first things you want to do is press the buttons of MENU-6-1-5and see if TV2 is set to channel 60 or 73 and make sure TV2 is on that channel.Once TV2 is on the channel on the Modular Setup page you will want to unplugthe receiver for 10 seconds and plug it back in and it will reset itself. Iwill send a link that will help with these steps. http://www.dishnetwork.com/SupportSection/black-blue-tv2
Feb 27, 2011 | DISH Network 322 DTV Receiver
My tv2 only shows one channel on dual mode and i cant change the channel with the remote
Hi billabongwanmy name is Mike Houston of DISH Network and what you will need to do isreprogram the remote. You will need to take the TV2 remote to the TV1 location,on the TV1 remote press the MENU button two times and it will take you to theSystem Info screen. You will then press and release the SAT button and pressthe record button one time on the TV2 remote. I will leave the link to helpwith these steps. http://www.dishnetwork.com/SupportSection/setup-remote
Feb 10, 2011 | DISH Network ViP722 DTV Receiver /...
No picture and the fan will not stop running,
Are you receiving no picture on TV1 or TV2?
If it is on TV1 you will want to verify your television is on channel 3 or 4. In some cases with the VIP receivers it may be 65 or 72 as well. I would also suggest going through the inputs on the receiver. Most tvs would list it as a "tv/video", "source", or "input". You'll also want to make sure all connections are tight and secure. At last resort you can try a hard reset by unplugging the receiver for 10 seconds.
It no picture is on TV2, you will want to confirm what channel the TV should be on by using TV1. On TV1 go to Menu then press 6-1-5 and change TV2 to the channel showing in "TV2 out".
With the fan running that is completely normal as the DVR function is always in use. It always has the capability to be paused and to use the rewind function so the fan is always cooling the hard drive.
Nick Franta
DISH Network Customer Service
Feb 07, 2011 | DISH Network ViP622 DVR DTV Receiver /...
Can't get my westinghouse tv to recognize dish network
Happy to help get that fixed right away!
You mentioned that your TV is not recognizing the DISH Network signal, since wedo not know how many TV's your receiver is able to support, or whether it's theTV1 or TV2 having the issue I will address them both.
The first thing we want to do is ensure that all connected components arepowered on (VCR, DVD Player, etc.). Check what channel or input your TV iscurrently on by powering the TV off then back on and noting the channel orinput that appears on screen when the TV is powered on.
If TV1:
Check what type of cable is used to connect the TV to the receiver. If you areusing a Coax Cable to connect the receiver to TV1, check the receiver'sback panel for the output name. If your receiver has a "TV CH 3/4Out" (non-ViP Receiver): Tune TV to channel 3 or channel 4,if it has "Home Distribution" output (ViP Receiver): Tune TVto channel 62 or 75. If using non-Coax (RCA, Component, orHDMI) to connect receiver to TV1, cycle through the inputs until pictureappears; most TVs have a "TV/Video", "Input", or"Source" button. If the issue persists, check that theconnections between your DISH receiver and your TV are secure then reset thereceiver by unplugging it from the outlet for 10 seconds then plugging it backin. If not fixed then connect another component (VCR, DVD Player, etc.) to thesame TV, using same cable, same input, and same channel to see if it works. Ifit works with the other component then call us at 1-800-333-DISH (3474) foradditional troubleshooting, if it still doesn't work with the other componentthen the cable should be replaced.
If TV2:
Access "Modulator Setup" from TV1 by pressing the menu button(on the top left of DISH remote) then pressing the numbers 6-1-5. Tune TV2 tothe channel that appears under "TV2 Out" on screen. If stillno picture, verify the mode (air or cable) that TV2 is on. Then change themodulator setup to match this mode (air or cable). After changing modulatorsetup, tune TV2 to the channel that appears under "TV2 Out" onscreen. Check that the connections between your DISH receiver and your TV aresecure then reset the receiver by unplugging it from the outlet for 10 secondsthen plugging it back in. If not fixed then connect another component (VCR, DVDPlayer, etc.) to the same TV, using same cable, same input, and same channel tosee if it works. If it works with the other component then call us at1-800-333-DISH (3474) for additional troubleshooting, if it still doesn't workwith the other component then the cable should be replaced.
Phillip Chang
DISH Network Customer Service Representative
Feb 06, 2011 | Westinghouse SK-32H240S Television
Problem jumps back and froth from tv1 to tv2
Apr 22, 2009 | DISH Network 322 DTV Receiver
Televison & Video Logo
14 people viewed this question
Top Televison & Video Experts
